Lab Gruppen FP14000 clone amplifiers - Page 192 - AVS Forum | Home Theater Discussions And Reviews
 211Likes
post #5731 of 5748 Old 02-07-2017, 09:53 AM
evoryder's Avatar
Quoted: 54 Post(s)
Liked: 44
Ive had my 2 Sanway fp14k for about a year now I guess with no issues, I recently took the time to replace the fans as per the instructions and part numbers provided by Notnyt. I very much appreciate the time you spent finding the correct fan combination. I had the newer version with 2 80mm and 3 60 mm, and I only installed two 80 and 2 60 since I only ordered 4 and 4 not knowing they changed it. I just did one so far to see the difference in temps. Mine are in a full rack, not out in the open. The fan mod makes it soo much quieter, it is very much worth the effort. These things are on at least 6 hours a day on the weekend and 14 on weekends usually at moderate levels.
Here is my question, the unmodded amp runs at 100-103 degrees, the one I replaced the fans runs about 115-117 now. Do you think that is too high of a temp for the amp to remain stable and reliable?
evoryder is offline
post #5732 of 5748 Old 02-07-2017, 10:37 AM - Thread Starter
notnyt's Avatar
Quoted: 2151 Post(s)
Liked: 1980
Should be fine. I ran mine for like 5 years without any problems.
notnyt is offline
post #5733 of 5748 Old 02-07-2017, 10:39 AM
evoryder's Avatar
Quoted: 54 Post(s)
Liked: 44
Thanks for the quick response and being such a helpful resource on this board! I thought it would be alright, just wanted to be sure.
evoryder is offline
post #5734 of 5748 Old 02-07-2017, 07:25 PM
Quoted: 93 Post(s)
Liked: 30
Are the 5 fan versions 48 volt? I have not opened my newest amp up to see.
cellarnoise is offline
post #5735 of 5748 Old 02-07-2017, 07:35 PM
chrapladm's Avatar
Quoted: 822 Post(s)
Liked: 286
Has anyone ordered the 10Q in a while?
Just curious how the success rate is going on that model. FP14 seems to be great and the 10Q seem to have the issues. So I am hopeful that everything has improved since then.
chrapladm is online now
post #5736 of 5748 Old 02-08-2017, 03:38 PM
evoryder's Avatar
Quoted: 54 Post(s)
Liked: 44
I'm not sure, they are already back together and I can't hear them spinning anymore so I'm overjoyed! I used the same fans as the op in the first post.
evoryder is offline
post #5737 of 5748 Old 02-08-2017, 04:17 PM
bpgunning's Avatar
Quoted: 23 Post(s)
Liked: 56
My Sanway FP14k just arrived today. Communication with Johnson was very good despite the time difference. It was packed well - a single outer cardboard box, a double-thick inner cardboard box, and additional sheets of cardboard on the top/bottom inside that. The padding was admittedly a little unorthodox - Sanway catalogs which were rolled up and taped, arranged around the amp as support. No damage whatsoever, perfect condition. This amp will be driving a ported sub with a Pierce 2k series driver, with a second in my eventual future. New fans and wirewound resistors arrived at the same time, as recommended by notnyt in the fan mod post. Good thing too - I fired this sucker up once on my lunch break and it is super loud, especially when it's flying full speed right on power-up.
bpgunning is offline
post #5738 of 5748 Old 02-08-2017, 08:06 PM
BBLV's Avatar
Did you get the enhanced version? Any photos of the rear panel and/or insides to share?
BBLV is offline
post #5739 of 5748 Old 02-08-2017, 08:12 PM - Thread Starter
notnyt's Avatar
Liked: 1980
Sanway doesn't have an enhanced version.
notnyt is offline
post #5740 of 5748 Old 02-08-2017, 09:00 PM
Quoted: 93 Post(s)
Liked: 30
The newest version of the Sanway FP14000 is supposed to be a bit "enhanced" compared to older models. Noty tested on his bucket and they can sustain more max / sinewave power compared to the "older" Sanway versions.
They have gone from 4 to 5 fans (I don't know the rated fan voltage yet (old models are 24v - new models may be 48 volt - I might open my new one up and see this weekend) I have an older Sanway FP14000 and a new 5 fan version that is also supposed to be 2 ohm capable. The older versions are 2.66? ohm capable according to Sanway. I have never tested one below a rated 4 ohm subwoofer though.
If you are pushing these to the clip lights you will likely need more than a 20 amp / 110 volt circuit to power them and are likely pushing some serious woofage!?
post #5741 of 5748 Old 02-08-2017, 09:24 PM
chrapladm's Avatar
Quoted: 822 Post(s)
Liked: 286
From what Notnyt stated the Sanways are not "enhanced," versions. The version he tested that had more sustained voltage was the BT audio version I believe. Not the Sanway. Although I have never seen anyone else order anything from BT Audio so I think most will just continue to order from Sanway.
post #5742 of 5748 Old 02-08-2017, 09:46 PM
bpgunning's Avatar
Quoted: 23 Post(s)
Liked: 56
Like notnyt said, there's no enhanced version from Sanway. The new version with 5 fans has 3x 60mm 24V fans and 2 80mm 48V fans. The 48V fans were not soldered into the Fan+/Fan- contacts, presumably in order to get higher voltages. Instead, the positive leads were both soldered into a single Fan+ contact, and both negative leads were soldered onto a different contact nearby that was not labeled. When I probed between these two contacts, I got ~53V on start-up which settled to ~21V at idle. On the other hand, the Fan+/- contacts provide ~26V at start-up and 11V at idle. So when I installed my new 24V fans I used those Fan+/- contacts. Some pictures attached. Also my power board says 10000Q v7
Stock fans
60mm fan soldering locations near the front transformer
Original 80mm fan soldering points
New solder points after fan mod
post #5743 of 5748 Old Yesterday, 06:51 AM
rhodesj's Avatar
Quoted: 852 Post(s)
Liked: 470
I could have sworn you said that the newer 2-ohm-stable Sanway performed similarly to the enhanced BT Audio?
dsl1 likes this.
rhodesj is online now
post #5744 of 5748 Old Yesterday, 07:43 AM
bpgunning's Avatar
Quoted: 23 Post(s)
Liked: 56
I believe he did - but it's not necessarily using the same "enhancements" that the BT Audio version has. If you take off the lids, a new 2-ohm stable Sanway FP14k and a BT Audio enhanced FP14k still look a bit different. The Sanway has 10 caps on the front left while the BT has 14, plus I'm sure there are other differences I don't know about. Sanway might have just started sourcing higher quality components in order to achieve the 2-ohm stable version. For example, the majority of the output transistors on mine are ON Semiconductor (who also owns Fairchild), a major player in the semiconductor device world rather than some no-name off-brand.
post #5745 of 5748 Old Yesterday, 08:57 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
the new one isn't "enhanced" like the Bt one with a pile of extra capacitors. The new sanway one just has a different power supply
Bassment is online now
post #5746 of 5748 Old Yesterday, 10:12 AM
rhodesj's Avatar
Quoted: 852 Post(s)
Liked: 470
Okay, but if the performance is about the same, what do the differences matter?
post #5747 of 5748 Old Yesterday, 02:36 PM - Thread Starter
notnyt's Avatar
Liked: 1980
PS isn't even much different, just some different transformers.
notnyt is offline
post #5748 of 5748 Old Yesterday, 02:37 PM - Thread Starter
notnyt's Avatar
Liked: 1980
It's not one of the "enhanced" amps is all. Their amps have been supposedly 2 ohm stable for a while, it's their main design, it's not an option.
notnyt is offline
Lab Gruppen Fp 14000 , Sanway Fp 10000q
