New Funkywaves High Efficiency Monitors? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 98 Old 06-24-2011, 02:00 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
Originally Posted by Funky Waves View Post
The goal is to reduce its affects overall, at any distance.
I understand that that's the goal; I'm interested in why you think it's possible to achieve it.
Noah
noah katz is online now
post #92 of 98 Old 06-24-2011, 03:03 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Measurements look good?
Nathan, is it possible to use one of them as a CC and lie them down horitontally, or will that muck up the response?
Also, what size room are these recco'd for, and you mention a sealed vs ported option. Are you going to make them ported, and offer some sort of plug and way to adjust the x-over if needed to seal them? Or will it be either or (i.e., you'll just close up the box)? Probably a dumb question, and I'm guessing I'd want sealed given my multiple sealed sub setup.
Too bad you guys are out West, would love to compare them to my Sig S2s.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #93 of 98 Old 06-25-2011, 05:31 AM
Funk Audio's Avatar
Quoted: 87 Post(s)
Liked: 151
Not sure what you mean by "achieve". No I don't think it can be eliminated, the goal is to "reduce"
PBC, we may at some point do a center, with the tweeter vertical, midbass on either side. What we are doing first is an MT with a smaller/similar tweeter and the same 8" midbass. I would not recommend them for under 8' to LP, for that the new MT would be better, and still be capable if high output. We would build them either rear ported (as tested) or sealed if someone likes. Depending on where you plan to cross over ported or sealed would make very little or no difference.
Nathan Funk
Funk Audio
Funk Audio is online now
post #94 of 98 Old 06-25-2011, 06:21 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Main LP would be about 13/14 feet from the speakers, though one couch would be 5 to 10 feet. I'm currently running dual AV15H dual opposed sealed subs. But would definitely need a center as I'm not a 2 channel guy.
pbc is offline
post #95 of 98 Old 06-26-2011, 07:05 PM
Funk Audio's Avatar
Quoted: 87 Post(s)
Liked: 151
The MT would be a great match as a center with the MTM's for L/R.
Nathan Funk
Funk Audio
post #96 of 98 Old 06-26-2011, 09:39 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
Not sure what you mean by "achieve". No I don’t think it can be eliminated, the goal is to "reduce"
You don't understand this?
What about the fact that even with the same tweeter height, different listening distances result in a different freq for the floor bounce notch?
Maybe you're not doing what I assumed, which is to put in a bump in the response at some assumed freq, which if in the event it's different, will give you a bump there as well as the notch.
Noah
post #97 of 98 Old 06-27-2011, 09:42 AM
Funk Audio's Avatar
Quoted: 87 Post(s)
Liked: 151
That is right, not doing that.
Nathan Funk
Funk Audio
post #98 of 98 Old 02-27-2012, 11:29 PM
Eternal Velocity's Avatar
Quoted: 30 Post(s)
Liked: 61
Nathan, if I may ask, is the broad midrange dip just part of your voicing preferences, or is there something I'm missing?
Eternal Velocity is offline
