New Funkywaves High Efficiency Monitors? - AVS Forum | Home Theater Discussions And Reviews
Old 05-26-2011, 10:37 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
These look quite nice ...
http://www.funkywaves.net/
Wonder what the cost will be as their current 7.1R is $3k a pair!
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
Old 05-26-2011, 10:46 AM
stgdz's Avatar
Is that a ribbon peaking out if that waveguide?
stgdz is offline
Old 05-26-2011, 11:02 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Looks like one to me.
Wonder how "stable" those would be without being affixed to a stand or some sort. Hard to say without dimensions, but they do not look deep or wide...
pbc is offline
Old 05-26-2011, 11:28 AM
exojam's Avatar
Liked: 33
Those look like the driver's Seaton uses in his.
James
exojam is offline
Old 05-26-2011, 12:24 PM
t6902wf's Avatar
With nothing to give it scale it is hard to say how large they are. They look pretty large.
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
Old 05-26-2011, 12:30 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
They do look nice, maybe ~32" x ~12"
I'm guessing they're a limited bandwidth sub required type piece,..but who knows. I too am not familiar with the HF element. One thing I'm sure we can count on, the cabinetry is likely first rate.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
Old 05-26-2011, 12:51 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
I'm happy with a "sub required type piece".
pbc is offline
Old 05-26-2011, 01:07 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Their 7.1 is $1200 pair. I can't imagine it's more than $2500/pair.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Old 05-26-2011, 02:19 PM
Quoted: 911 Post(s)
Liked: 490
The woofers, it's safe to say, are 8" models. B&C and a couple others I think use those octagonal-flange baskets.
No doubt. Nathan's a first-rate artisan.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Old 05-26-2011, 02:36 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Hmmm ... wonder what makes the 7.1R's so much more expensive?
http://www.funkywaves.net/catalog.cfm?item=fw7_r
Outside of the 1" thick aluminum baffle that is. Don't know enough about ribbon tweeters and cross-overs to gauge the cost.
In any event, I love the high WAF of the black ones posted above.
pbc is offline
Old 05-26-2011, 03:05 PM
Quoted: 911 Post(s)
Liked: 490
That baffle can't be cheap to buy or machine.
And that speaker is also translam, which adds considerably to materials cost. As well as finishing time, most likely.
The new one looks like traditional wooden board construction, but with good attention paid to minimizing diffraction with large roundovers.
Serious Audio Blog
DS-21 is offline
Old 05-26-2011, 03:27 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
i wonder if this is the horn:
http://www.tradekool.com/selling-lea...-RT-62041.html
and my guess on the driver is the b&c 8NDL51.
the coax used in seaton's has the tweeter firing through the woofer. since this one has a tweeter, the coax would be redundant.
Listen. It's All Good.
LTD02 is online now
Old 05-26-2011, 03:36 PM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Translam?
pbc is offline
Old 05-26-2011, 04:30 PM
Quoted: 911 Post(s)
Liked: 490
Translam?
Stacks of machined ply loops (in this case, could be MDF in other cases) glued together.
Serious Audio Blog
DS-21 is offline
Old 05-26-2011, 05:01 PM
WiSounds's Avatar
It looks to be something else, that model uses inverted dustcaps:
I just built a pair of tops with the MDN 8":
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
Old 05-26-2011, 05:34 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
What kind of horn and what's the compression driver?
gpmbc is offline
Old 05-26-2011, 06:19 PM
WiSounds's Avatar
Selenium D3305Ti-DPD 2" Titanium Horn Driver, Goldwood GM-450PB 2" High Frequency Horn.
WiSounds is offline
Old 05-26-2011, 06:46 PM
LTD02's Avatar
Liked: 2578
"It looks to be something else, that model uses inverted dustcaps"
nice catch.
that does not look like a compression driver in that horn wi...more like a ring radiator tweeter. is that driver that different?
sure looks like one of these to me:
LTD02 is online now
Old 05-26-2011, 06:48 PM
Billy p's Avatar
Quoted: 300 Post(s)
Liked: 662
Those monitors are nice but not what I had in mind. Having recently talked to him regarding some speakers, he told me they plan on building a 2.5 tower version of the ht7.1 but right now it's not a top priority... it sure sounds like they're busy expanding the business.
Ascend Acoustics Towers: STC w RAAL, 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo BDP-103D,
Apple TV+ Giga 1800
Sub FA 18: (Santos RW)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is offline
Old 05-26-2011, 09:07 PM
mayhem13's Avatar
Quoted: 44 Post(s)
Liked: 29
And that's a good thing as the C to C spacing of the two midwoofers suggests a serious design flaw.
mayhem13 is online now
Old 05-26-2011, 09:13 PM
WiSounds's Avatar
Can't you overcome phase and dispersion issues by using different crossover points for the mids?
WiSounds is offline
Old 05-27-2011, 06:39 AM
penngray's Avatar
Liked: 43
That is not a good generalization. You do not know the XO point, the slope or the listening angle where the null is. Those will dictate if the C to C spacing is an audible issue.
penngray is offline
Old 05-27-2011, 08:17 AM
Funk Audio's Avatar
Quoted: 87 Post(s)
Liked: 151
The 7.R is expensive for a couple reasons, the biggest is the solid aluminum baffle, fyi they can be built with a plain wood baffle for $1000 less per pair. The enclosure is stacked laminated plywood, this used a lot of material and time to build. It also uses premium crossover components.
For the MTM we are basically done the crossover design and should have some final response measurements in a week or two, both on and off axis, in the vertical and horizontal planes, so far they are doing very well. The crossover point is ~1350hz. Overall size is 30"h, 11"w, 10"d. They are ported with an f3 of 60hz, they can also be sealed for an f3 of 120hz, f10 60hz. The tweeter is a Planar.
Price per pair is expected to be 2000-3000 depending on finish.
Here is a picture of the 8" mid bass.
Nathan Funk
Funk Audio
Funk Audio is offline
Old 05-27-2011, 08:42 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Nathan,
Very, very nice,...is the HF element the Beyma pleated diaphragm/waveguide combo? If so, it's nice and very tightly controlled vertical,..almost line array like. Regardless which HF driver, this thing appears very nice.
FOH is offline
Old 05-27-2011, 10:24 AM
AudioJosh's Avatar
Quoted: 248 Post(s)
Liked: 228
That's a Faital woofer.
JoshK on most other audio forums
Quantity only when quality is ensured.
AudioJosh is offline
Old 05-27-2011, 11:25 AM
coctostan's Avatar
Liked: 135
Nathan,
I'm pretty sure that is not the TPL-150H unless they built their own waveguide. The screw holes are different. I doubt they'd use a $500 HF driver and sell them for only $1000-1500 each. The woofers are likely $150-200ea.
coctostan is offline
Old 05-27-2011, 12:05 PM
Quoted: 911 Post(s)
Liked: 490
Yeah. Likely the same one Danley uses on the 3-way molded horns, and possibly elsewhere as well.
Serious Audio Blog
DS-21 is offline
Old 05-27-2011, 12:12 PM
A9X-308's Avatar
Quoted: 1300 Post(s)
Liked: 964
W8N8-200 by the look of it.
A9X-308 is offline
Old 05-27-2011, 12:18 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Yes, you're right,...the mounting holes are quite different. My wishful thinking perhaps. I'd love to see a commercial offering, or diy for that matter, using the Beyma design.
FOH is offline
Old 05-27-2011, 12:34 PM
A9X-308's Avatar
Liked: 964
There have been several DIY uses of the TPL150 that I can recall. Dig around at diyaudio and some will pop up. Google too. Klang and Ton (IIRC) also did some measurements of it about 3 or 4 years ago.
A9X-308 is offline
