Behringer Inukes @ B&H - Possibly shipping soon - AVS Forum | Home Theater Discussions And Reviews
Old 06-27-2011, 01:29 AM - Thread Starter
Troll
ufokillerz's Avatar
Liked: 47
On all the models at b&h it says ships in 7-10 days, could that be a sign that they are coming soon.
anyone planning to order one?
ufokillerz is offline
Old 06-27-2011, 04:43 PM
TJHUB's Avatar
I was holding out to buy one to power my dual LMS's, but when I called a different vendor in late May, the status was "late Summer or early Fall." I'd call and get the real story from B&H. I went another direction with my amp purchase.
TJHUB is offline
Old 06-27-2011, 05:19 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1041
I wouldn't mind trying one out but I'll wait and see how they test first.
N8DOGG is offline
Old 06-27-2011, 05:27 PM
noah katz's Avatar
Quoted: 882 Post(s)
Liked: 304
Or get the amp it's copying, the Peavey ipr series, though it does cost a bit more.
Given that Peavey is essentially selling these to gain market share and not to make money (I have some inside info), I wonder what corners Behringer cut to be able to sell them cheaper.
Noah
noah katz is online now
Old 06-27-2011, 06:17 PM
Looneybomber's Avatar
Liked: 25
I'd like to see how they test too. For $50 more than an ep4000 it's rated to put out 3kw x 2 @ 4ohms, yet only consume "620w @ 4ohms"? I have my reservations.
YID DIY
Looneybomber is offline
Old 06-27-2011, 06:48 PM
stgdz's Avatar
stgdz is offline
Old 06-27-2011, 08:42 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1041
ya, I'm in no hurry. I'm still debating on what I should do with the money I got for my RMX5050. I could buy 2 marathon 5050's or a couple LG clones. I don't really need the power right now, my stack of EP's are still working great but I'll be in a new place as soon as they build it and would rather have 8 marathons or LG clones than 16 ep4000's lol
N8DOGG is offline
Old 06-27-2011, 08:53 PM
spanish68's Avatar
I might end up buying the Behringer DSP3000 or Peavy DSP3000 to power my just acquired JBL GTI 15" subs which will go in a dual opposed sealed box. I do have the Yamaha P7000S/SMS-1 combo right now but might end up replacing them with one of the above units which should add more flexibility/simplicity to my system.
spanish68 is offline
Old 06-27-2011, 08:57 PM
Warpdrv's Avatar
Been really hoping that these would be worth their weight - they would offer a huge value for heavy duty subs IMO. Still hoping!!!
Warpdrv is offline
Old 06-28-2011, 05:31 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Originally Posted by stgdz View Post
They may also roll of below 20hz
This is what I'm concerned with. Noah mentioned in the Peavey thread that they made some sort of adjustment (changed a component) to reduce the impact of the roll-off below 20hz.
So if Berry is copying the Peavey, not sure if they'd have made this same adjustment as of yet.
Would be nice to know when the Peavey's are coming out with the 6k unit.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
Old 06-28-2011, 08:27 AM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
I'll let someone else be the Guinea Pig on this...
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
Old 06-28-2011, 02:07 PM
NEO Dan's Avatar
Some food for thought:
Originally Posted by Sickneedhelp View Post
There are other things they will not figure out that will yield inferior results. I fully expect Beheringer to put out another lame attempt at a copy. If typical, theirs will not have safety agency approval nor comply with FCC part 15 or EMC Directives.
From the Behringer web page:
Dan
NEO Dan is offline
Old 06-28-2011, 02:57 PM
Liked: 25
What's the FCC have to do with an amp? Does it transmit or receive wireless signals?
YID DIY
Old 06-28-2011, 03:09 PM
Quoted: 911 Post(s)
Liked: 490
Radio frequency interference.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Old 06-28-2011, 04:23 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
The Inuke ratings are peak not RMS from what I understand.
Manic1! is online now
Old 06-28-2011, 07:34 PM
Liked: 25
Maybe I am underestimating how much RF interference an amp could produce...
I figured it would be negligible.
YID DIY
Old 06-28-2011, 08:25 PM
noah katz's Avatar
Quoted: 882 Post(s)
Liked: 304
These amps are class D, switching high currents at high freq
Noah
Old 06-28-2011, 09:51 PM
Audiophile34's Avatar
In my experiance a class d amp is fine for subs, the high current at high frequency will not effect your subs one bit, just make sure that they are not in a area that could influence your mains, or surrounds. Don't want to introduce noise into your highs...
My first DIY project. A dual, dual opposed setup
www.avsforum.com/avs-vb/showthread.php?t=1345494
Audiophile34 is offline
Old 06-28-2011, 10:21 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
A couple of years ago, Behringer imported a number of products into the USA without the requisite FCC certification. After ignoring repeated requests to provide documentation and/or come into compliance, they were hit with a $1,000,000 fine. Not appealable. They're a bit more cautious nowadays.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
Old 06-29-2011, 04:02 PM
lbaccoustics's Avatar
It seams its now available over the pond here-
http://www.dv247.com/pa-systems-and-...6000dsp--81807
Cheap price!
lbaccoustics is offline
Old 06-29-2011, 07:54 PM
NEO Dan's Avatar
Cheap price!
What a tease... You!
It's not in stock
It's also $550 USD, that's not cheap.
Dan
NEO Dan is offline
Old 06-29-2011, 09:23 PM
stgdz's Avatar
So its basically half the advertised values. Chuck measured the ep4k(2500 at the time) and got 2kw out of of the amp.
The rolloff keeps me away from this at the time.
stgdz is offline
Old 06-30-2011, 03:13 AM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Behringer now rates at peak power not RMS.
Old 06-30-2011, 01:26 PM
It's not in stock
-didnt notice the 'not in stock' note- damn!! got all excited at the prospect of getting somthing before you lot for once!
$550 is cheap for us!! I find gbp to usd is 1:1 when buying electronic goods- so if you pay $500 for an amp over there, we usually pay £500 (approx 40% more!)
we need to grow our population or somthing to increase our buying power methinks....sucks!
Old 06-30-2011, 05:26 PM
stgdz's Avatar
I guess that was my point though. Its not rms so the values can be taken at half.
The roll off on the ipr and possibly the i-nuke make me wonder why these high watt amps would be good for sub duty
stgdz is offline
Old 06-30-2011, 06:06 PM
noah katz's Avatar
Quoted: 882 Post(s)
Liked: 304
I get full power at 10 Hz on my ipr 3000.
Noah
Old 07-12-2011, 02:28 PM
Need4spdnb's Avatar
I checked with one of my distributors, here is the date I got for the Inuke DSP versions as to a ship date: 10-18-2011
Looks like they are still a ways off.
Theater design at Audio Video Interiors of Chicago, Inc.
Right across from the Oakbrook Center Mall.
Noah B.
Need4spdnb is offline
Old 07-12-2011, 05:11 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Most PA subs only go down to 30hz or so.
Old 07-13-2011, 02:47 AM
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Any idea on noise level on the Inuke series? I'm thnking fan noise.
clausdk is online now
Old 07-13-2011, 10:52 AM
stgdz's Avatar
No they don't. They go all the way to 10hz with little rolloff.
stgdz is offline
