Yet another dual opposed mfw 15 build (my first ever) - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 141 Old 08-01-2011, 07:31 PM
Mpray1983's Avatar
Originally Posted by Audiophile34 View Post
Oh yeah? Lfe a plenty in battlefield?
Got to pick a good one for adult movie night.. Any other suggestions?
I wouldn't watch battle:LA with the kids around. It is one of the most heavy LFE movies this year. Got 5 stars on the Movies with bass list. Check out that thread...all movies are rated on their amount of bass. Definitely get a blu ray copy tho to take advantage of the dynamic range of dts-MA.
Mpray1983 is offline
post #122 of 141 Old 08-01-2011, 07:32 PM - Thread Starter
Audiophile34's Avatar
Lol I used some trim from home depot for the frame, and then glued magnets into the wood frame.
I think it's all on page 2.. maybe 3..
edit.. It's on 3..
My first DIY project. A dual, dual opposed setup
www.avsforum.com/avs-vb/showthread.php?t=1345494
Audiophile34 is offline
post #123 of 141 Old 08-03-2011, 07:35 PM - Thread Starter
Thinking tentatively that Fri is the day to watch movies that the kids are not going to be watching...
What are everyone's else's suggestions....
As far as what movie to pick..
post #124 of 141 Old 08-03-2011, 07:37 PM
Mpray1983's Avatar
Inception...just got my dual opposed rolling today and it's incredible.
post #125 of 141 Old 08-03-2011, 10:43 PM
Scott C.'s Avatar
War of the Worlds is the standard I think. I'm especially partial to LotR. If you have the extended editions, the part where Gandalf speaks the language of Mordor during the Council of Elrond is pretty intense (among others).
Sounds Good to Me... keeping track of my audio projects.
Scott C. is offline
post #126 of 141 Old 08-06-2011, 06:23 PM - Thread Starter
would over extending the woofer cause a loud, almost crack type sound? I was playing pods emerge scean in wotw at minus 5db and towards the end of the scean I heard a crack from one of my subs. But it seemed in place with the soundtrack... so I and confused as to I over drove, or if that was part of the experience.
post #127 of 141 Old 08-06-2011, 06:27 PM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 192
If it sounded like a loud crack fart then it probably was.....
NicksHitachi is offline
post #128 of 141 Old 08-06-2011, 06:28 PM
Kanaris's Avatar
Try to reenact the scene see if it does it again... stay close to the sub to see if it is indeed a physical crack sound of something actually hitting or just a sound emitting from it... it could also be the amp clipping on and off..
Kanaris is offline
post #129 of 141 Old 08-06-2011, 06:42 PM
Mpray1983's Avatar
I was clipping my amp on that scene set up one way....does it sound more like a BWAK sound? The problem was my BFD was clipping also when it was set up a different way. It's driving me crazy.
post #130 of 141 Old 08-07-2011, 06:08 AM - Thread Starter
I was watching the clip lights and I was driving the amp into clip a couple of times. The amp clipping doesn't make its own sound does it? it would just clip the signal... right?
post #131 of 141 Old 08-07-2011, 10:25 AM
Th3_uN1Qu3's Avatar
Clipping the signal does make its own sound... Which also depends on whether the limiter is on or not.
Originally Posted by Ivan Beaver
The nice thing about standards is that there are so many to choose from.
Th3_uN1Qu3 is offline
post #132 of 141 Old 08-07-2011, 11:41 AM - Thread Starter
Well I guess in the simplest most basic sense, anything that is not the exact copy of the original signal is "its own sound".
But this was an audible "crack" but it coincided with the ripping of the concrete during the earth quake...
And for your information, I do not have the limiter on.
post #133 of 141 Old 08-07-2011, 12:16 PM
Quoted: 182 Post(s)
Liked: 192
Does not having the limiter on mean it will not "soft clip"? I think most of these amps tout soft clipping but I'm not sure how soft it really is or what having the limiter off means.
post #134 of 141 Old 08-07-2011, 12:22 PM - Thread Starter
Neither do I all I know is what the manual states..
So the manual states that the limiter prevents the high frequency clipping.. but what if you are only sending 120hz and below to the amp?
post #135 of 141 Old 08-07-2011, 12:30 PM
Mpray1983's Avatar
Do you have the low cut set to off? Also what are your gain controls set at? I was having the same problem and found a few solutions that solved it.
post #136 of 141 Old 08-07-2011, 08:05 PM - Thread Starter
turned the gain down, and watched terminator salvation on blu ray tonight, damn what a movie. explosions and lfe all over the place. the best part, with the gain turned down, no weird noises.
post #137 of 141 Old 08-08-2011, 12:00 AM
Mpray1983's Avatar
Terminator doesn't have the same real heavy low LFE that is found in WOTW. You may still clip even with the gain turned down. Hopefully it works for you though.
post #138 of 141 Old 08-08-2011, 12:08 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5973 Post(s)
Liked: 5036
I find that part to be the hardest on my system. I usually cringe a little bit right there now after I clipped my ep2500 real good the first time I pushed that part with my LLT's. Doesn't happen anymore but I still think that is the most intense part of the whole sequence.
Scott Simonian is offline
post #139 of 141 Old 08-08-2011, 08:06 PM - Thread Starter
Yeah it seems that scene will have more for me once I get the mini inline. For now, it just seems to lack oomph.
post #140 of 141 Old 08-09-2011, 04:45 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
So .... when are we going to see some inroom measurements!?
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #141 of 141 Old 08-09-2011, 04:54 PM - Thread Starter
soon as I get the radio shack SPL meter and all the nessesary cables... fundage is a little tight after the 2 weeks off with the baby....
