Little help here.... - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 43 Old 08-08-2011, 06:15 PM - Thread Starter
Audiophile34's Avatar
here is a cool article I found..
http://www.alexandermagazine.com/rec...q0104/bass.htm
It's a bit of reading, but it talks about subwoofers, and what type of content the normal songs have.
My first DIY project. A dual, dual opposed setup
www.avsforum.com/avs-vb/showthread.php?t=1345494
Audiophile34 is offline
post #32 of 43 Old 08-09-2011, 02:43 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2887
so are you good to go?
Listen. It's All Good.
LTD02 is offline
post #33 of 43 Old 08-09-2011, 03:57 PM - Thread Starter
He is still thinking, talking, he is worried about speaker protection, as he has dogs, and small child..
Told him that we could face the speakers torwards the wall, but he is worried about shaking the drywall/sheetrock off of the walls. lol.
Any ideas?
post #34 of 43 Old 08-09-2011, 04:03 PM
Mpray1983's Avatar
Any ideas?
Downward firing...check out diy rhythmic for the idea.
Mpray1983 is offline
post #35 of 43 Old 08-09-2011, 04:26 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5034
Thanks, John, for posting up those spectral graphs of music. Makes me feel better about how the sound will be of my uber mains. Should be wicked!
Scott Simonian is offline
post #36 of 43 Old 08-09-2011, 04:43 PM
LTD02's Avatar
Liked: 2887
np scott, 4 15's might be dissed by many, but not by me... :-)
if you want a rock concert in your room, something like that is what it takes...
LTD02 is offline
post #37 of 43 Old 08-09-2011, 04:50 PM - Thread Starter
Umm, he asked about downward firing, what's the benefit of those over other than built in protection?
post #38 of 43 Old 08-09-2011, 04:58 PM
Mpray1983's Avatar
No negatives and no positives. It works exactly the same. The only thing is you have to have clearance on the bottom.
post #39 of 43 Old 08-10-2011, 12:06 AM
LTD02's Avatar
Liked: 2887
"Umm, he asked about downward firing, what's the benefit of those over other than built in protection?"
it can create a little bit of a low pass filter depending on how much air cushion there is between the sub and the floor.
also, there are many options for protecting drivers.
just choose something that your buddy likes:
http://www.google.com/search?hl=en&b...og&sa=N&tab=wi
LTD02 is offline
post #40 of 43 Old 08-15-2011, 04:28 PM
LTD02's Avatar
Liked: 2887
just curious if you decided to proceed to chose something else? :-)
LTD02 is offline
post #41 of 43 Old 08-16-2011, 05:26 AM - Thread Starter
It seems like he is going to go with your design there John, but its still fantasy until he gives me the real go ahead... I think we are going to go downward facing with the drivers, and face the ports at the lp.
I think he would benefit from room gain much more should we face the ports at the wall, but his concern is shaking the wall apart.. lol..
post #42 of 43 Old 08-16-2011, 01:14 PM
LTD02's Avatar
Liked: 2887
good luck with your project. not sure how the front firing ports would work in this application. post a build thread if you guys decide to proceed. i still think that just two drives and a good amp will slaughter his bose sub, but if he goes for four, how can that be argued with? :-)
LTD02 is offline
post #43 of 43 Old 08-17-2011, 12:43 PM - Thread Starter
Thanks again for all your help. If he decides to go with this, I definitely will be posting a tread.. I want my whole family (avs) taking the journey with me.
Did you have any internal bracing or sound influencing structures inside that box?
Thanks again..
