Budget Eminence Coaxial surround build!!! - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #1051 of 1053 Old 04-03-2017, 12:57 PM
xumbug's Avatar
Which one are you wanting info on, the beyma, or the emmy?
Sorry, the Beyma
xumbug is offline
post #1052 of 1053 Old 04-03-2017, 01:09 PM - Thread Starter
Point Source
beastaudio's Avatar
Quoted: 4023 Post(s)
Liked: 3338
In the .6 sealed cabinet they measured well to below 100hz or so in-room. Excellent performing setup IMO when I Demo'd them in stereo with a sub to supplement the bottom end.
If you wanted to go ported, you could build the box to a tuning of down to 60hz or so but I wouldn't go much lower. That would give you a little more extension if you needed it. Dimensions etc. are kind of up to you.
I can get you however many of the custom XO's that you would need, just PM me and I will discuss pricing with you.
beastaudio is offline
post #1053 of 1053 Old 04-04-2017, 10:48 AM
xumbug's Avatar
Double post
xumbug is offline
