Sealed dual LMS 18" 5400 build - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 176 Old 12-02-2011, 03:48 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5285 Post(s)
Liked: 4169
Might just be cuz you're using the RS meter that the numbers are down that much down low.
Scott Simonian is offline
post #122 of 176 Old 12-02-2011, 03:59 PM
chrapladm's Avatar
Quoted: 826 Post(s)
Liked: 286
I haven't a clue but I would have thought your room would not have a huge negative affect on 13hz and lower but maybe I am wrong?
chrapladm is offline
post #123 of 176 Old 12-02-2011, 05:39 PM
notnyt's Avatar
Quoted: 2156 Post(s)
Liked: 1984
take close mic measurements and see what you're actually outputting.
notnyt is offline
post #124 of 176 Old 12-07-2011, 11:01 AM
bodhisafa's Avatar
Any more listening impressions?
Compared to your captivator setup are you impressed with the new system enough to justify the extra expense of these 1k drivers?
bodhisafa is offline
post #125 of 176 Old 12-09-2011, 07:58 AM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
Originally Posted by lukeamdman View Post
My initial thoughts:
- Wow this thing is heavy! I weighed the box before putting in the drivers and it was just over 100lb's
- Wow these drivers in a sealed box are power hungry
- WOW the FP14000 is powerful!!!
- Wow the 5400 + VMP design is much more efficient
- Wow this thing sounds good
At first it sounded good, but not great. The punch and weight of the bass was missing, and it didn't play well with the VMP sub AT ALL. Both sounded much better playing by themselves. I inverted the polarity on the MiniDSP for the sealed sub and bingoDANG it sounds good!
I can see how a Marathon MA-5050 would come in a little short for powering one of these. The FP14000 seems endless for power. It just keep going and going, and my ears say stop when trying to find its limits. I haven't seen the clip lights yet, and for me that's a first.
The cost of these two weren't too far apart. The dual sealed setup was about $150 more expensive, but theFP14000 was 3x the cost of an EP4000.
As I get some time to listen, and for the new drivers to break in, I'll post some thoughts on the sound differences between the two. Even at this point with only a couple minutes of listening, I prefer the sealed setup.
how do you invert the polarity on the MiniDSP?
kutlow is offline
post #126 of 176 Old 12-09-2011, 08:03 AM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Inverting MDSP:
Click on "Delay/Gain/RMS-outputs 1 & 2" (Or outputs 3 & 4, whichever you are trying to invert)
On bottom right corner of output channels is the button to click on. If it is glowing green it is inverted.
MX48 is offline
post #127 of 176 Old 12-09-2011, 08:53 AM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Very interested in your impressions here as well as I LOVE my JTR t-12's and can imagine the caps are just as high quality of a build as they are
beastaudio is offline
post #128 of 176 Old 12-09-2011, 11:27 AM - Thread Starter
lukeamdman's Avatar
Quoted: 1080 Post(s)
Liked: 1200
This setup is almost twice the cost as my dual Cap setup, but it is a improvement in every way.
Earlier this year when I was looking to upgrade from my DD-18, I wanted more low end output but didn't want to lose the clean and crisp punch of the DD-18.
A single Cap had the output down to 20hz, easily more than two DD-18's were capable of, but the bass reflex design wasn't as clean down low. There was also the inherent problem with bass reflex designs which is port noise. Even without the the Peavey 4080hz, a EP4000 could drive a Cap hard enough to produce port noise. I will say this though, it was the least noticeable amount of port noise I've ever experienced with a ported sub.
Because of the cost between the two setups, it's not really a fair comparison. The quad 5400s are cleaner, louder, and play much much much lower. At 40hz and up I had no issue with the Caps, but when we're talking about 10hz to 25hz performance, there's no comparison, and considering the price difference there really shouldn't be.
This to me is really the best of all worlds. Bass that extends to 10hz and below depending on the room, a crisp and powerful punch at 50-60hz, ultra low distortion, zero port noise, and with the FP14000's they have what seems like limitless output.
lukeamdman is offline
post #129 of 176 Old 12-09-2011, 01:01 PM
Point Source
beastaudio's Avatar
Liked: 2826
Overall do you think this is more a product of the rediculous amounts of power you have going to the LMS's vs the caps, or more the specific design? Obviously sealed will go lower, but further up in the passband?
post #130 of 176 Old 12-09-2011, 05:33 PM - Thread Starter
lukeamdman's Avatar
Liked: 1200
The sealed design obviously eliminates any port noise, and that's a major annoyance of mine. Also, according to my ears, sealed subs play clearer/cleaner for sub 30hz material.
The ridiculous amount of power is kind of necessary considering how inefficient these drivers are when sealed. However, the FP14000 just happens to be ridiculous enough to even over-power TWO of these drivers at once. I'm sure something like the QSC RMX 5050 and Marathon MA-5050 could push these loud, but probably not as loud as dual Caps with a EP4000...
post #131 of 176 Old 12-09-2011, 05:48 PM - Thread Starter
lukeamdman's Avatar
Liked: 1200
post #132 of 176 Old 12-09-2011, 06:14 PM
notnyt's Avatar
Liked: 1984
Imagine 8
Are those in phase? might just be the angle/video but they looked out of phase.
notnyt is offline
post #133 of 176 Old 12-09-2011, 06:15 PM
filtor1's Avatar
Quoted: 71 Post(s)
Liked: 73
Whoa!!!
filtor1 is offline
post #134 of 176 Old 12-09-2011, 06:15 PM - Thread Starter
lukeamdman's Avatar
Liked: 1200
Originally Posted by notnyt View Post
Imagine 8
They're in phase. I'm not sure why they look like that in the video but I noticed the same thing.
post #135 of 176 Old 12-09-2011, 06:43 PM - Thread Starter
lukeamdman's Avatar
Liked: 1200
Imagine 8
For the heck of it, I took some slow motion video of the drivers in action.
http://www.youtube.com/watch?v=hfqcmfP3gjU
post #136 of 176 Old 12-09-2011, 06:52 PM
notnyt's Avatar
Liked: 1984
Hah, that's cool, but the left looked out of phase to the right, or at least the top driver.. probably illusion.
notnyt is offline
post #137 of 176 Old 12-09-2011, 06:54 PM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
Please post more videos of your quad sealed LMS 5400 ultra 18" subs powered by dual FP14000s on some bass-heavy scenes or musics btw, where did you hide your FP14000s
WereWolf84 is offline
post #138 of 176 Old 12-09-2011, 07:12 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Lovely sight!
gpmbc is offline
post #139 of 176 Old 12-09-2011, 10:29 PM
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Quick question for ya, how inert are those cabinets??
edoggrc51 is offline
post #140 of 176 Old 12-09-2011, 10:39 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
Those cabs were a rocking! literally!
N8DOGG is online now
post #141 of 176 Old 12-09-2011, 10:45 PM
chrapladm's Avatar
Quoted: 826 Post(s)
Liked: 286
Wow four of those must be a blast. I really cant even imagine 8 of those like Not's. Someday maybe someone around me will have a pair so I can have a listen.
post #142 of 176 Old 12-10-2011, 01:58 AM
robertcharles's Avatar
robertcharles is offline
post #143 of 176 Old 12-10-2011, 10:43 AM - Thread Starter
lukeamdman's Avatar
Liked: 1200
Got all four in slow motion
http://www.youtube.com/watch?v=diwXHF3HrWw
The drivers in the right cabinet appear to be perfectly in sync, but in the left cabinet, the top driver seems to have a little more loose suspension?
post #144 of 176 Old 12-10-2011, 10:48 AM - Thread Starter
lukeamdman's Avatar
Liked: 1200
There's 9lb's of polyfill in each cabinet, and I can't hear any noise/resonances from the cabinets at all.
In terms of cabinet vibration, you can obviously feel it if you crank it up, but it's MUCH less than any commercial sub I've ever had. My DD-18 had WAY more flex in the cabinet.
post #145 of 176 Old 12-10-2011, 11:22 AM
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Thanks for the info.
Btw, that slow-mo of all 4 drivers pumping looks WAAAAAY COOL!
post #146 of 176 Old 12-10-2011, 01:08 PM
Looneybomber's Avatar
Liked: 25
What camera did you use for the slow-mo shots and what frame rate?
YID DIY
Looneybomber is offline
post #147 of 176 Old 12-10-2011, 01:52 PM - Thread Starter
lukeamdman's Avatar
Liked: 1200
Canon 300 HS. The mode is called "super slow motion" and is 240fps.
post #148 of 176 Old 12-11-2011, 02:21 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Cool stuff, they appear in phase to me.
It would be quite interesting to catch the manner in which the surrounds de-form, which I've seen in not's vids. At gig excursions, they pull in asymmetrically.
Always neat to see vids, especially the super slo-motion. So thanks for that.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #149 of 176 Old 12-11-2011, 09:16 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
wow I love the subs video. Id love to hear those!
kutlow is offline
post #150 of 176 Old 12-12-2011, 10:29 AM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
No doubt your system sounds great, Luke. Thanks for the vids.
I do have a comment on the most recent slomo video of all four subs. I think it may be optical illusion, but depending on where I focus during the video, I find different things. I've thought the top two drivers were equally out of phase with the bottom two drivers, but in phase with each other, when looking at the top of the center speaker. I've thought the top left driver was out of phase with all the others when staring at the midpoint between the two drivers on the right. I've though the bottom right was out of phase with all the others, and significantly, when focusing on the light reflection on the top right driver.
Maybe I'm crazy, but try it for yourself. If it's of serious concern to you, a good way to see would be a direct-on camera view (from the front, equidistant from the stacks) with strong side lighting.
nube is offline
