Behringer iNuke NU3000 first impressions (I need replacement fan suggestions!) - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 194 Old 11-06-2013, 06:21 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Originally Posted by noah katz View Post
why's that?
Will rack mount and must have front to back ventilation................I have a 90 CFM blower at the ceiling of my rack which is hooked up to make-up air damper. Is there an amp available with ability to vent as such? Thinking the Yamaha has propensity not use fan much........................
doublewing11 is offline
post #182 of 194 Old 12-22-2013, 08:20 AM
vinodk's Avatar
Quoted: 87 Post(s)
Liked: 33
Modified iNuke 3000DSP using NMB fan from Digikey. Still audible but not as bad as stock fan but with program material playing its not objectionable. My amp is located 5-6 ft away from my main seating position. Will try to remove the shroud completely & place heatsinks on transistors to see if it makes a difference. Forgot to check which way the original fan was oriented before removal. Does the sticker side on the fan face in or out?
Vinod
vinodk is offline
post #183 of 194 Old 08-06-2014, 06:46 AM
Mr. Electric Wiz's Avatar
Quoted: 79 Post(s)
Liked: 39
Originally Posted by lilmike View Post
The iNuke DSP works great for me, taming some peaks in the response and making things smoother. The iNuke software limit is 20 Hz, to work below that requires something like the balanced MiniDSP.
Wait, what???
You can't EQ below 20hz with the iNuke?
I almost bought one of these yesterday before I saw this post.
My subs are IB and are very capable of going into the single digits. I would think I would really need <20hz equalization.
Dang. Back to the drawing board for amp selection.
Mr. Electric Wiz is offline
post #184 of 194 Old 08-06-2014, 08:47 AM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Originally Posted by Mr. Electric Wiz View Post
Wait, what???
Pick up a mini-dsp, and buy a non-dsp inuke.
I don't think any pro-style amps with DSP have functions under 20hz...
Stumbo is offline
post #185 of 194 Old 08-06-2014, 09:00 AM
Quoted: 79 Post(s)
Liked: 39
So glad I found this out now!
post #186 of 194 Old 08-06-2014, 09:04 AM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
Wait, what???
MiniDSP offers several plate amps with integrated DSP. I've not used one yet, but I do intend to.
I wouldn't choose the iNuke series for chasing the single digits either, there are far better choices. Mine starts to roll off below 10 Hz if I recall. Again, in the current configuration, this is of no consequence to me, as the amp rolls off considerably lower than my desired highpass.
lilmike is offline
post #187 of 194 Old 08-06-2014, 09:06 AM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
None that I am aware of, in fact some stop at 50 Hz. The DSP implementation in the iNuke is excellent, save for the 20 Hz limit.
lilmike is offline
post #188 of 194 Old 08-06-2014, 12:25 PM
Quoted: 79 Post(s)
Liked: 39
I've asked this before a while back, but you guys have had a lot more MiniDSP experience since then.
Which MiniDSP unit would be the best fit for a Pioneer Elite SC-65 AVR?
Would I be better off contacting someone at MiniDSP about an answer to this question?
post #189 of 194 Old 08-06-2014, 06:48 PM
noah katz's Avatar
Quoted: 1095 Post(s)
Liked: 380
Unless you have a very large room you won't have any room modes <20 Hz, so the workarounds noted elsewhere to get some control down there may be sufficient.
noah katz is online now
post #190 of 194 Old 11-01-2014, 11:44 AM
Steve Smith's Avatar
Quoted: 72 Post(s)
Anyone else having reliability problems with these? I bought an NU3000DSP in June and had to send it in for repair in July, no output from either channel. They replaced a diode. Now I have another problem. The signal and limit lights come on sporadically, even with no signal and make strange noises on the output, sounds sort of like a hard drive but louder.
Steve Smith is online now
post #191 of 194 Old 11-01-2014, 11:55 AM
Quoted: 109 Post(s)
Liked: 37
A buddy and I each bought a inuke 3000 dsp about a year ago and they are still going. They both have the fan mod...
I have ran mine in bridged 4 ohm and in dual 4 ohm. Now only using 1 channel in 4 ohm to drive aura shakers. I don't have the on or off thump either. Has worked well so far.
Did the early version of these have the same diode problem as the 6000?
cellarnoise is offline
post #192 of 194 Old 02-15-2015, 05:40 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
what was the turn around time for the warranty repair?
Who needs 4K?... just go see your optometrist.
NODES is offline
post #193 of 194 Old 02-15-2015, 05:52 PM
Quoted: 72 Post(s)
About 3 weeks.
post #194 of 194 Old 02-15-2015, 07:33 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
About 3 weeks.
Darn..that is a while. My first one is buzzing when in bridge mode with LFE OFF.
NODES is offline
