Behringer iNuke NU3000 first impressions (I need replacement fan suggestions!) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 194 Old 09-07-2011, 06:10 PM - Thread Starter
Jerry Parker's Avatar
I just got my iNuke NU3000 today. I have it hooked up to an old 18" prosound sub driver which can no where near take the full power of this amp. The final subwoofer driver build has yet to be built.
First of all, this amp is pretty loud. Not as bad as the EP2500 that I have stock, but still bad. I need to replace it ASAP. Does anyone know what kind of fan it takes? Is it a 24v like the EP2500? Or a standard 12v?
The amp is ridiculously light. It is smaller and weighs less than an old Sony 40wpc reciever, and puts out at least 25 times more power.
It is kind of cheap looking, with lots of plastic. That's not really a big deal though, it will just be sitting on my equipment rack.
One thing I dislike is that the amp only has Neutrik Speakon outputs. I do not have any on hand, nor did the amplifier come with any cables. So I had to really ghetto rig it with some standard speaker wire and electrical tape temporarily to test it out.
Is anyone else running one of these?
Jerry Parker is offline
post #2 of 194 Old 09-07-2011, 06:25 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
I was planning on getting one to drive a pair of ported 15"s, which I'm about to start building. So I'm really looking forward to all comments! I'm going to get some of these to hook it up to binding posts.
Jay1 is offline
post #3 of 194 Old 09-07-2011, 06:34 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 166
Well? What do you think? Does it seem to put out good power? How is the noise floor, any hissing or thumping at turn on? Did you get the straight iNuke or did you get the one with DSP?
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #4 of 194 Old 09-07-2011, 06:46 PM
Mpray1983's Avatar
I don't think the dsp is available yet
Mpray1983 is offline
post #5 of 194 Old 09-07-2011, 06:51 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
it says in stock
http://www.amazon.com/gp/product/B00...A34VCPZVL7E6XQ
Jay1 is offline
post #6 of 194 Old 09-07-2011, 07:01 PM - Thread Starter
Like I said, I can't run it full blast because it would melt the driver I have hooked up to it. So I cannot measure its output.
The noise floor is very impressive, I put my ear up to the woofer, and cannot hear any noise. No hissing at all. No power on or off thump, dead silent. Bear in mind this is with the loud amplifier fan running, but I feel confident that from any sitting position you should not hear any noise whatsoever.
Mine is the straight iNuke, I already have a Behringer DCX2496.
post #7 of 194 Old 09-07-2011, 07:22 PM
Bill Fitzmaurice's Avatar
Liked: 5687
One of my forum members measured its output at 28v at the point where the input started to clip. Realistically it's a 200w/ch/4 ohm amp. The Behringer ratings are vaguely quoted as 'peak'. They don't publish a continuous RMS figure.
Bill Fitzmaurice is offline
post #8 of 194 Old 09-07-2011, 07:38 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Wow, that would be pretty bad. The EP series basically measured at half of the spec Behringer gave. I would hope that's true for all their amps...
Jay1 is offline
post #9 of 194 Old 09-07-2011, 07:42 PM
Liked: 5687
I can't think of any good reason for their hiding the continuous RMS, but there's a few bad ones.
post #10 of 194 Old 09-07-2011, 09:22 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1144
Really? Specs in the manual line up fairly well with the tests posted here.
EP2500 8R
EP2500 4R
EP2500 bridged
Crop from manual attached.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #11 of 194 Old 09-07-2011, 09:31 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
EP2500 8R
EP2500 4R
EP2500 bridged
What about the EP2000/4000, aren't those the same amps? The specs sure are higher...
Jay1 is offline
post #12 of 194 Old 09-07-2011, 09:37 PM
A9X-308's Avatar
Liked: 1144
To the best of my knowledge, the 2000/4000 are the 1500/2500 rebadged and nothing else.
A9X-308 is offline
post #13 of 194 Old 09-07-2011, 09:42 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Right, and they're now claiming far more RMS power in the manual, like 950W @ 4ohm for the EP4000.
Jay1 is offline
post #14 of 194 Old 09-07-2011, 10:02 PM
A9X-308's Avatar
Liked: 1144
The numbers aren't all that different between the 2500 and 4000 excpet for the 4R which is higher. Whether that's a lie or a typo I dunno. Please also note that the 4000 specs are at 1% THD not 0.1% (for most of them anyway) that they were in the 2500 version.
So when someone measures one correctly we'll actually know.
A9X-308 is offline
post #15 of 194 Old 09-07-2011, 10:22 PM
noah katz's Avatar
Quoted: 1111 Post(s)
Liked: 387
That's an inconclusive result as far as power output is concerned, which requires driving the output to clipping.
Sounds like a gain structure issue, like the input level is too high and the level controls too low.
Noah
noah katz is offline
post #16 of 194 Old 09-08-2011, 07:02 AM
penngray's Avatar
Liked: 47
Not in the measurements in this forum. Behringers specs/measurements here are within percentage points. As good as any other pro audio manufacturer. Atleast they had been for the EP2500/EP1500.
So good that Behringer became the best DIY amp option.
penngray is offline
post #17 of 194 Old 09-08-2011, 07:03 AM
penngray's Avatar
Liked: 47
I have a EP4000 in a box, Chuck isn't doing measurements any more (it seems). A while back I PMed him on HTguide.com but no reply.
I have a new MiniDSP amp in a box too that I wanted measuring I will PM him again......
penngray is offline
post #18 of 194 Old 09-08-2011, 07:27 AM - Thread Starter
I have an oscilloscope and somewhere I have two 100 watt 8 ohm resistors. If I can find them I'll try and measure it's output tonight or this weekend. I will be very upset if the amp only puts out 200 watts per channel into 4 ohms.
I thought some Danish guys tested the amp and it did over 1000 watts rms per channel?
post #19 of 194 Old 09-08-2011, 07:51 AM
penngray's Avatar
Liked: 47
It will do more then 200Watts.
It should definitely have peaks > 1000Watts/ch.
penngray is offline
post #20 of 194 Old 09-08-2011, 08:33 AM
desertdome's Avatar
Quoted: 1337 Post(s)
Liked: 1526
There is a review of the iNuke NU3000 DSP in this German magazine. You can save the file and then upload it in Google Translate. It is still hard to read. It looks like using sine waves they measured 1176 watts per channel at 2 ohms, 600 watts at 4 ohms and 312 watts at 8 ohms. Peaks watts (20ms/1000 Hz) are 1700 watts per channel at 2 ohms, 870 watts at 4 ohms, and 465 watts at 8 ohms.
Here are the "Pros" listed at the end of the article:
+ Low initial price
+ Very low weight
+ Good editing software
+ Effective protection circuits
+ Very high efficiency
+ Stable power output
+ With / without DSP Controller
+ Different models to choose from
High Impact AV
desertdome is offline
post #21 of 194 Old 09-08-2011, 11:09 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
+ Low initial price
+ Very low weight
That sounds a lot better! I was expecting around 400-500 watts
Jay1 is offline
post #22 of 194 Old 09-08-2011, 11:47 AM
Raul GS's Avatar
Quoted: 21 Post(s)
+ Low initial price
+ Very low weight
Any idea what the contras are?
Dunning–Kruger effect - a cognitive bias where individuals exhibiting poor ability suffer from an illusion of superiority, due to their mistaken assessment of their cognitive ability. That is, a high level of incompetence prevents such individuals from cognitively recognizing their own ineptitude. Yeah, I know...the irony.
Raul GS is offline
post #23 of 194 Old 09-08-2011, 12:55 PM
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2717
Mine is coming in this week as well supposedly from guitar center. I got the Inuke 3000 DSP version for $340 (15% off labor day coupon) + $20 tax - so $360 shipped.
Here is a Danish review showing some impressive numbers -
I can't find much info or reviews in english yet, but the amp did just release this last weekend in the US as far as I can tell.
http://www.avsforum.com/avs-vb/showt...4#post20704344
4ohm bridge gave a 5,600 watt peak in their testing -- if that's true?!?!?!
The fan should have 12 volt or 24 volt listed on it. You can replace the fan from this shop for cheap. I bought my more silent fans for the EP4000 and a 2200VA Smart APC UPS from this shop and both worked perfectly.
http://search.digikey.com/scripts/Dk...=1179730&k=fan
Archaea is offline
post #24 of 194 Old 09-08-2011, 01:36 PM
exojam's Avatar
Liked: 33
Penn,
I do not think Chuck will be doing any tests soon. I communicated with him recently and he is pretty tied up with life stuff in general.
James
exojam is offline
post #25 of 194 Old 09-08-2011, 02:22 PM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
According to the German Review here are the cons:
- Nonexistent looping possibilities
- Speed of the input signals
- No terminals
- Plastic front panel
- Relatively loud fan
So far not bad at all except for the loud fan; anyway this fan produced less noise than EP4000/2500. I ordered the 6000 DSP Model; Supposed to be shipped tomorrow!!!!
javygonx is offline
post #26 of 194 Old 09-08-2011, 02:22 PM
Archaea's Avatar
Liked: 2717
cons as relayed by google translate
  • nonexistent looping possibilities speed of the input signals
  • no terminals
  • plastic front panel
  • relatively loud fan
Archaea is offline
post #27 of 194 Old 09-08-2011, 02:28 PM
desertdome's Avatar
Liked: 1526
I left the cons out on purpose so others could practice using Google Translate. It looks like it worked.
High Impact AV
post #28 of 194 Old 09-08-2011, 02:46 PM
Archaea's Avatar
Liked: 2717
ohhh you beat me to the cons...
The power specs aren't terrible. If I read the translation correctly the article is saying the inuke 3000 unit puts out over 900 watts per channel RMS in 2ohm stereo and about 1700 watts peak for up to 3 seconds before it will fault. It doesn't appear too dissimilar from the forum favorite EP2500/EP4000 unit. I'll be able to compare the two directly when the Inuke 3000 arrives, because I currently have a EP4000 unit. I can't do much aside from SPL meter levels to compare them, but that should tell us within some reason what the Inuke is capable of because I can run both of them at full attenuation up to tapping the clip light levels on my Captivator Pro pair at two ohms without fear of damaging the drivers --- assuming I can wear ear plugs and kick the family out of the house for a night.
Here is the full article from the google translate page. It certainty doesn't read smooth, but you can make out something here or there...
TEST I I I
32
Somehow I was assigned to the
presented do anything mission.
My confusion was based on the
wrapped in black foil
Package whose weight at more of a
few designers in the Lipper-Schuhkar
ton had been thought of as a-
adult stage. Who would have
Ten years have thought that power amp-
weight class in the fen shoes
Would make it competitive?
But before we deal with measurement results
Nissen deal, it is
advance the state of play
. Logging The back is
quickly explained, except for two
XLR / TRS combo jacks, two
Speakon jacks, and a cold-
there is no terminal access to
. announce Instead Neutrik valve position
Ren jacks come from Asian
shear production to the course, which
Quality certainly
would be interesting, in-depth un-
to be investigated. But this is a
separate issue for the com-
tools 4 music coming editions.
Back to "Candidate": The
Cooling is a powerfully into the unit
Santander blow 88-mm fans with me-
tallschutzgitter. The output
socket for Channel A is sensible-
, 4-pin connected, to what
the crab 2 + and 2 - the signal
of channel B is present. The basic
we find either in the An-
control active 2-way systems
over a 4-pole Speakon cable
or the requirement of a high
Output in Brückenbe-
driven into 4 ohms, with the loud-
Was several months ago on the Internet, announced the eagerly-Beh
ringer "inuk" amplifier series discussed. First attempts a kind of optical
took place at this year's Prolight & Sound in Frankfurt, even if the local
Idea rather rare sighting of reptiles in captivity was like. Because apart
was probably a glass box with lifeless exhibits the pre-series it
little to examine. So it was surprising that we are to this edition
promptly provided a sample for testing were available from Behringer.
Clear the ring for another flyweight in the DSP amplifier league.
By Stefan Kosmalla
Behringer "inuk"
NU-3000 DSP
then speaker to pins 1 + and
2 + clamped. The housing
The final stage consists of aluminum
umblech with a stylish geform-
th front of plastic including
Installation of two handles. Thus the
Front panel of the rack
protected against forces arising
is the lateral housing
walls bent at 90 degrees.
Centrally located in the viewing area,
The graphic display of the inte-
integrated digital controller, two
Rocker switch in union with an En-
coder to take the input
commands for programming
the final stage. Besides the two Pe-
I catch sight of even the gelstellern
Power switch and a USB port on
circuit for the communication be-
between amplifier and PC. Directly
status after switching to
the fan by briefly
Accelerate. The display and
the subtly glowing orange
Wreaths at the level adjuster signaled
Sieren proper function of the
Behringer "inuk" NU-3000 DSP
- So it's ready.
Concept
The Behringer "inuk" series is
in six different variants
with a total of 1,000 performances,
3,000 and 6,000 watts available. In
gives every performance category, it also
a DSP implementation, the one
"Digital sound processor" directly
has implemented. This DSP
Controller offers this pro-
programming options via simple
Low-and hi-cut functions to
toward crossovers Program
ming plus limiter, phase
circuit, delay and comfortable
Equalizer settings. To pro-
program development is the An-
Users expect a really easy-to-
to-use software available
tion, by the way, full-
are easily installed
and could be via frontseiti-
according to USB 2.0 slot the com-
tion takes up with a PC. At
get an impression from the graphical
Appearance of the nearly even
to make explanatory software
one glance at Figure 1
Figure 1: The editor software
"Inuk" amp is great
Ad
TEST I I I
34
The controller provides an active fre-
quenzweiche three-Filtercharakte
istics: Butterworth, Bessel and
Linkwitz-Riley, with its steep-
unit in 12-dB, 24 dB and 48 dB
Steps can be selected.
Image 2gibt an overview of the
Differences in the types of filters
direct comparison to each other.
Are in the EQ section be-
already in the parametric part of total
to award a total of eight filters, whose
Properties, in general terms without
can be designed. Who
yet not enough has attacks
to the dynamic filters, the
Effects depending on education
output power is available. The sense-the
these two filters per channel is
For example, in the programming
tion of a loudness function, the
with increasing volume con-
continuously decreases, no
Damage to the connected
Boxes to provoke.
Speaking of speaker damage -
the controller to the one-
limiter built even in the co-
connection with the load impedance
the connected speaker
boxes on the W-is exactly
will be. The stated
Values ​​are consistent with our measure-
measurements agree. This type of pro-
programming is essentially an-
to understand than the times specified
the gain reduction in decibels.
That both attack and
Release time in very wide areas
Chen is also can be set
worth mentioning. A good example is
The freely adjustable delay time,
Boxes for time-delayed anzusteu
The setting is in ern.
Meters, milliseconds, and the U.S.
Unit "feet" will be displayed. Reached
are delays of up to 102
Meters. If the user has to be
Program created, there are 20 memory
played only available to the so-
probably the most convenient device and
be managed through the PC can
. NEN The controller can, of-
course directly to the
Amplifier operated completely be
the one where I personally A-
setting on the remote PC
Editor prefer.
Inventory
The circuit principle of end-
stage is based on a switching network
concept with some pulse-width-
profiled amp circuit. This
among experts "Class D" referred to
Switching mode promises the highest
Efficiency with minimum construction
parts and cooling area overhead. So
surprise in the image 3gezeigte
No internal structure, as UEP
pige components dimensioning
with modern concepts of this kind
not necessary. Of course there is one
Figure 2 shows the steepness of the various filters
Figure 3: A modern design of the Behringer "inuk" NU-3000 DSP
some skepticism about the
erin-more like computer hardware
nernden boards left, one is
but otherwise mostly large-volume
Caliber in this performance class
usual.
Confusing at first love
View the manufacturer's guarantee regarding
insured services before starting-
come, especially before the
Given that no right
Heat sink can be explored.
That such Endstufenkonstruk-
tions but work well
We have been in the test of
Peavey shown IPR-1600. The devices-
teaufbau consists of a central-
circuit board, the power supply, output
levels, and input circuit
along with controller electronics-Beher
Bergt. The processing of the end
stage is flawless,
although the aforementioned
Front panel made of plastic but
some getting used to it-
appears.
The first measurements with a 20
Milliseconds-long burst packet
and a test frequency of 1,000
Hz at 8 ohms can peak level
without considering the distortion-
factor of 61 volts rms voltage
tion to recognize what a
Output of 2 x 465 watts
equivalent. Even at 4-ohm load, it
extends the "inuk" NU-3000 DSP
stramme 59 volts, which is-
expected to result in 2 x 870 watts.
Only at the low 2-ohm loading
Figure 4: Test with 500 millisecond burst signals - the power at 2 ohms is limited to 3 seconds
Figure 5: The comparison measurement shows the limiting behavior of the power amplifier test during sinus (blue = 8
Ohms, purple and green = 4 ohms = 2 ohms with switch-off after 5 seconds)
Ad
TEST I I I
36
load is the "emergency brake" pulled-
gene, which is unequivocally
significant reduction in the level
from initially around 2 x 1700 watts
gentler on 2 x 900 watts to
3 seconds displays.
The consideration of image 4zeigt
the behavior in detail, where all-
However, the present burst packets
lengthened to 500 milliseconds
were to the Leistungsreduk-
tion within the 10 seconds
While this is to de-
. onstrate These first results
The results show that the output stage
certainly very high-Impulsleistun
gene within a limited
Time window can provide to
But then as part of their
Power supply capacity, the capacity to
reduce to safe levels. Be-
If we look at the Ausgangsleistun-
Klirrfaktorgrenzen gene with up to
1 percent, I measure 2 x 2 ohm
1176 Watts at 4 Ohms 2 x 600 watts
and at 8 Ohms 2 x 312 watts. The
Amplifier shows an equally
constant temporal power drop
task as the Peavey IPR 1600th
To limit the behavior of
Amplifier in a direct comparison to
three load impedances to be-
, judging by Figure 5 shows
normal sinus Test means that
8 ohms no limitations
visible, while already at 4
Ohm first control interventions take place
the, then even at 2 ohms for
complete shutdown after
three seconds lead.
When testing the operating voltage
limits increases in the output stage
a sunken to 160 VAC
Mains voltage. Our tests
in the laboratory, we have at 230 VAC
Mains conducted, but
it is permissible to point out that
a trial basis the increase
Mains voltage of 240 VAC and
a slightly higher output
performance possible. The input
Sensitivity is the way
exactly 852 mV (+0.82 dBu) in order to
8 ohms undistorted voltage
from 50.33 Vrms (+36.25 dBu) to he-
to keep the gain resulting in the
Amplifier in Figure 35.43 6mit he dB
can be expected. When considering
the red input signal in comparison
relationship to the blue-on output
signal in Figure 6 is also the
temporal offset between the two spa-
tive to each other. This effect
is the runtime behavior of the Con-
Trollers attributed to the Ver-
delay measurement in Figure 7, a
Duration of 0.6 milliseconds to-
day brings.
The frequency response test in Figure 8
shows the final stage, the typical re-
sonanzreaktion the output filter
a cost-optimized "Class D" -
Assembly versus the in-
connected load impedance
an increase up to 7 dB at 24
Figure 6: With an input voltage of 852 mV (red) is the Behringer 'inuk "NU-3000 DSP one
Output voltage of 50.33 V (blue), which corresponds to a gain of 35.43 dB
Figure 7: Latency measurement of the controller: input signal (blue) and output (red), the delay time
is just 0.6 milliseconds
kHz into 8-ohm loads. For load-
device with 2 and 4 ohms is the
Slightly less strong nonlinearity
weight.
The measurement of harmonic distortion at 1
Watts into 8 ohms 9ergibt in picture very
low values ​​of only 0.045 per
cent, but at the higher loading
utilization is still sufficient to
SPONDING 0.12 percent increase (Figure
10). The detailed analysis of the distortion-
spectrum shows predominantly un -
even-numbered distortions such
for PWM power amplifiers often observed
th are.
Perhaps a few words about
Power consumption of the amplifier, the
by the manufacturer with only 350 watts
specified. Some colleagues
at the pub are now em-
pört pound the table when they
Before passionately discuss
th standing question: how can there
3,000 watts come out, if only
350 watts are consumed? To
Answering the question measure
we are the actual power consumption
commissioning of the power amplifier under sine
full load and make it a short time
1,600 watts active power set, the in-
Within a few seconds
Values ​​reduced to 650 watts
be.
As with the measurements
Output power above, be-
limits the peak, the Netzteilbe-
load within the allowable
Specifications. In addition, the
Fact that music is a mixture
from pulses of different
Amplitudes and thus ad-
consolidated power only a fraction
the available in-
pulse represents services. Yet
come to me from Behringer
given values ​​a little too
just before, because the measurements at
constant loads German
results were markedly higher.
The experiments also showed one in
amazingly high degree of efficiency
by nearly 90 percent since the ratio-
ratio of recorded active
ceded power to output
zusammenlag performance very close.
Really exciting when the tests are
Abnormal behavior patterns
Conditions such as short circuit,
37
Figure 8: Frequency response with typical resonance frequencies of a high rise to 8-ohm load
Performance Measurement: The pulse power at 8 ohms 2 x 2 x 61 = 2 x 465 watts rms
The output voltage at 2 x 8 ohms at 1% THD, is 50.27 Vrms, which corresponds to 2 x 315 watts
TEST I I I
38
low impedance or sub-
voltage. When Behringer
Are "inuk" NU-3000 DSP is also
In this respect, no reason
for criticism. Short circuit withstand
the output stage without damage and
Exposure to low-impedance
impedances by the simple
Shutdown acknowledged. Overall
made the "inuk" a very
feeling within the sovereign
Tests in the laboratory, so that in
During the test, no doubt about the
Quality of components or a
Circuit design emerged.
Final
For whom is the NU-
BEHRINGER DSP 3000 from the home-
ger? The award really belongs in
the category of "I simply purchase
times, "because with only 389 € Ver-
purchase price is the final stage ex-
extremely inexpensive. The question remains
after the application, the
good conscience "is actual-
Lich be answered for all "
can. As an interested party to the
Choose between versions with or
without an integrated DSP and selects
the required training as required
output power in three classes. The
Amplifier has no weaknesses in
processing, the perfor-
ability of the controller in combination
nation with the clear
Editor software can hardly wishes
scheoffen and offered training
output power is expected, especially before
the backdrop of the terminating-
th 6000 series is also higher
Demands. Si
cherlich is a front end of
Plastic used to,
the lack of binding posts
or not the existing By-
grinding possibility of input
signals like the one or
other critics of the reserve
. lure
But the bottom line has BEHRINGER-
ger with the new "inuk" series
an amplifier in the Pro-Series
program, with the security for an-
Nigen commotion in the industry
will provide. Really missing only
nor a comparison test within
This new lightweight
Class amplifier with DSP control
ler - following in the com-
coming editions. I
Pro & Contra
+ Low initial price
+ Very low weight
+, With / without DSP Controller
- Non-existing loop possibilities
- No terminals
From the firm Behringer he-
This test gave us no
Comment by editorial
circuit.
INTERVIEW
Figure 9: THD @ 1 watt and 8 ohms = 0.045%
Figure 10: THD at 100 watts and 8 ohms = 0.12%
Archaea is offline
post #29 of 194 Old 09-08-2011, 02:47 PM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
LOL!!... I read this review about 2 weeks ago!; and translate the whole review!... Very time consuming but worthy. Its the only decent review out there!... Lets hope we can see more reviews; specially from avs gurus!
javygonx is offline
post #30 of 194 Old 09-08-2011, 05:38 PM
stgdz's Avatar
http://www.avsforum.com/avs-vb/showt...1#post20635471
I still stand by this statement, the ratings that behringer put out you can pretty much cut in half. With that being said I plan on getting on of the 6000's to power my two back mael-x's
stgdz is offline
