JBL 2242H Build Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 85 Old 09-29-2011, 08:15 PM - Thread Starter
nichol1997's Avatar
I have a pair of JBL 2242H drivers that I plan on building enclosures for. I am thinking of 12 cu ft net for each driver. Ported and tuned to 22 hertz.
JBL's cut sheet recommends anything from 5-12 cu ft for the driver. They also recommend a high pass filter set to 20 hertz for the larger cabinet sizes as the driver runs out of xmax rather quickly below tuning. I am not too concerned about the content below 20 hertz for the application that I plan on using it for.
I am looking forward to how they will sound in a larger cabinet as they get rave reviews all over the internet. The cabinets will be placed under my entertainment center and will be used for both music and movies.
nichol1997 is offline
post #2 of 85 Old 09-30-2011, 01:30 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5282 Post(s)
Liked: 4167
Awesome.
Look forward to your results.
Scott Simonian is online now
post #3 of 85 Old 09-30-2011, 06:44 AM
Wrager's Avatar
Quoted: 192 Post(s)
Liked: 114
I love what I've read about the 2242. Would the 2268 be a step up?
Wrager is offline
post #4 of 85 Old 09-30-2011, 07:09 AM
coctostan's Avatar
Liked: 135
The 2242H is a great driver. What is your application?
The 2268 is very similar but not quite as good as the 2242 but it is much lighter and I think a little cheaper.
coctostan is offline
post #5 of 85 Old 09-30-2011, 07:51 AM
atomicmist's Avatar
Why not build something like this:
http://www.jblsynthesis.com/Products/Details/110
JBL Synthesis S1S-EX Clone...
6.5 cu.ft tuned to 25Hz
Adding B6 Filter (6db Boost@20hz Q=2) will get you an F3 around 24hz as long as you apply a high pass filter 12db/octave or better at 20Hz. This design will also offer much better group delay than a 12cu.ft box.
Just my 2 cents.
If I ever die of a heart attack, I hope it will be from listening to a movie too loud!
atomicmist is offline
post #6 of 85 Old 09-30-2011, 08:41 AM
coctostan's Avatar
Liked: 135
Just my 2 cents.
Once you apply the B6 filter the smaller box actually has slightly worse group delay although group delay at 20hz is pretty meaningless.
By going with the 6.5 cu ft box, you give up about 5-6db of excursion limited headroom which IMO trumps anything group delay related.
That's not to say the 6.5 cu ft boosted box is bad, but if you have the room, the 12 cu ft is without question better. I've heard the S1S and it is very nice, but JBL only goes the smaller route because most people don't have room for 12 cu ft boxes.
And if you don't already own the 2242H, you would be better off with the TD18H which models basically the same as the 2242H but with 5mm more xmax, probably lower distortion if you run them high enough to care, and a lower price (about half the price with the AE group buy).
post #7 of 85 Old 09-30-2011, 09:27 AM
atomicmist's Avatar
True.. GD goes up with eq and even with the high pass. I should have worded it differently. I meant low GD with the smaller enclosure. Of course if he has the room for the larger box, he will gain max output for the lowest octave but lose some as well higher up where this driver really shines.
post #8 of 85 Old 09-30-2011, 03:26 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
that sounds like a fun build. if you have the space, the 12 cubic foot option is a good choice at 22hz. other than placement issues and the sub 20hz stuff, i'm not really sure what more one could ask for. they are efficient, clean, and durable. a 3rd order butterworth at 20hz will pretty much keep the excursion below tuning to the same as above tuning (i.e., the excursion will be symmetric around the tuning frequency with an equal signal). what are you thinking about for portage?
jbl uses them in their 4645c commercial theater sub. i think it has a 1x6" port but don't quote me on that. with your lower tuning a 1x8" might be a little better.
the price of this thing has gone through the roof. i wonder if it is because the price of neodymium has shot up and they didn't want all their customers leaving the 2268.
as for quality of the 2242 vs 2268 asked earlier, that is a tough one. the lower q of the 2242
http://www.jblpro.com/pub/components/2242.pdf
is certainly attractive for a ported cab. the 2268
http://www.audioheritage.org/vbullet...hp?11346-2268H
isn't a bad driver though. the non-linear parameters and the distortion plots don't look too bad. it sure would make for an interesting shootout, 2242 2268 td18. :-)
Listen. It's All Good.
LTD02 is online now
post #9 of 85 Old 09-30-2011, 04:14 PM
coctostan's Avatar
Liked: 135
as for quality of the 2242 vs 2268 asked earlier, that is a tough one. the lower q of the 2242 is certainly attractive for a ported cab. the 2268 isn't a bad driver though. measurements here: http://www.audioheritage.org/vbullet...hp?11346-2268H
I don't know how interesting it would be. The TD18 would slaughter the others...and you can get them for half the price right now. That's saying something because you could probably say that about the 2242H prior to the TD18 coming on the market. About the only thing I'd like to compare to the TD18 in this kind of setup would be the B&C 21SW152/115.
post #10 of 85 Old 09-30-2011, 07:45 PM - Thread Starter
nichol1997's Avatar
Here is someone who compared the two subjectively:
http://forum.speakerplans.com/jbl-22...969_page2.html
Granted, this person seems to be using it for club/PA purposes.
post #11 of 85 Old 09-30-2011, 08:01 PM - Thread Starter
nichol1997's Avatar
Just my 2 cents.
The attached simulations show the frequency response difference between a 8 and 12 cu ft enclosure. By going with the 12 cu ft enclosure I gain 6 dB down low. I have the space for the enclosures but I am dreading moving these things into position. They are going to be heavy!
I bought the mdf this evening so I should be able to start cutting wood this weekend.
post #12 of 85 Old 09-30-2011, 08:08 PM - Thread Starter
nichol1997's Avatar
I am constrained to 20" in length for the port due to box dimensions and where I want the port to exit. So, I am thinking I will do three 4" diameter ports that are 14.5" long. No flares, just simple round ports.
post #13 of 85 Old 09-30-2011, 08:19 PM - Thread Starter
nichol1997's Avatar
The TD18 looks like an excellent driver. Only problem is...availability. I have seen some folks waiting close to a year for their AE drivers to be built.
The 2242H drivers are readily available and I will have no concerns about parts availability if I ever have to recone it.
post #14 of 85 Old 09-30-2011, 08:38 PM
coctostan's Avatar
Liked: 135
...and the 2242H is a killer driver. I recently heard a setup with 4 S1S's and it was impressive to say the least. I run 4 2245Hs which are old school 2242Hs.
We are talking about "best" and "slightly better than best".
post #15 of 85 Old 09-30-2011, 08:50 PM
LTD02's Avatar
Liked: 2574
cool. 3 x 4" portorama should be okay.
LTD02 is online now
post #16 of 85 Old 10-01-2011, 12:37 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Just my 2 cents.
6th order for a 2242 is 90L with a Q=2 HPF at 32Hz.
For a 2241 it is 205L at 26Hz.
A9X-308 is offline
post #17 of 85 Old 10-01-2011, 06:08 AM
penngray's Avatar
Liked: 43
There is a difference between the supply of TD series woofers that are used in main speakers vs AV series subwoofers. There was a major supply issue with the AV series but the TD series has never had one year delays, atleast nothing I have read about.
FWIW, John has indicated that the group buy TD series will have shipping times about 1 month or so after the large shipment of materials arrive sometime in November.
If I was search for a driver in the TD18 class, I wouldn't bother with any other choice, its simply unmatched in terms of measured performance. Yep, Im a Fanboy
Saying all that,
I doubt you will find real audible differences in the performance of either choice in your room.
penngray is offline
post #18 of 85 Old 10-01-2011, 07:03 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
Doug do you have any links to TD18 measurements? I can't really remember seeing any.
To the OP where are you located? I have a couple of 4645c cabs you could have if you happen to be near me.
Ricci is offline
post #19 of 85 Old 10-01-2011, 11:57 AM
Tack's Avatar
Quoted: 2575 Post(s)
Liked: 3467
I don't know about slaughter, I have both and both have their pluses and minuses. The Jbl has a larger voice coil, the TD has more x-max.They sound more similar than different Imo.
I paid close to 500 dollars for my TD, at 313 or whatever the group buy nets, its the value leader here.
The TD is beautifully made and was worth the money at list price.
2242s fetch good money on the bay, its possible to sell them, buy TDs and come out ahead, but that's a lot of work.
I found 8 cubic feet or so to be the best compromise of size and extension for ME. I'm sure 12 feet will work fine but if you haven't cut that MDF yet, you may want to return it for some nice ply. Thing is going to be HEAVY.
I have to build out a couple 2242s by Halloween to DJ my sister in laws party. I'm going to blow their masks off
Good luck with the build.
Tack is online now
post #20 of 85 Old 10-01-2011, 12:02 PM
Tack's Avatar
Liked: 3467
Ricci- re TD measurements -
Fs: 29Hz
Qms: 5.9
Vas: 390L
Cms: .185
Mms: 165g
RmsL 5
Xmax: 14mm
Xmech: 18mm
Sd: 1220sqcm
Vd: 3.4L P-P
Qes: .23
Re: 5.6ohm
Le: .41
Z: 8ohm
Bl: 27Tm
Pe: 1000W
Qts: .22
1WSPL: 98.2dB
2.83V: 99.8dB
That was as of 3-09 so I don't know if anything has changed since.
Tack is online now
post #21 of 85 Old 10-01-2011, 03:39 PM
LTD02's Avatar
Liked: 2574
"Here is someone who compared the two subjectively"
nice review. i wonder why the difference doesn't seem to show up in the measurements. eyeballing the charts is a little tricky, but knowing that distortion scales roughly twice as fast as spl, the 2242 looks a little cleaner, but i would have expected to see more difference in the measurements given how different they seem to have performed subjectively. both use techniquest to linearize inductance, so that leaves the much lower qe as the only thing that i can see that would explain the difference.
just thinking out loud, is it possible that distortion (or something in the frequency ressponse) has a time property that is not captured in a simple frequency sweep? qe is a damping property and damping is across time. if this were true, than it would explain how two drivers with equal measured frequency response and distortion, could sound subjective "fast" or "slow", with fast simply being the one with the lower qe.
LTD02 is online now
post #22 of 85 Old 10-01-2011, 05:15 PM
coctostan's Avatar
Liked: 135
I should have just said they have a significant advantage in output headroom. Whether that translates into an audible difference, that probably depends on how much output you are using. As far as the JBL SVG vs AE Lambda motor, I'll take the Lambda. I haven't seen any measurements on the TD18 specifically, but assuming it performs in line with the TD15, IMO it is superior. Of course, once again it is questionably audible, especially when used as a subwoofer on an LFE channel.
They should sound pretty much the same...they model to almost the same FR.
Nobody is going to complain about either driver.
post #23 of 85 Old 10-01-2011, 06:29 PM
LTD02's Avatar
Liked: 2574
"They should sound pretty much the same...they model to almost the same FR."
are those two separate claims, or a claim and the evidence?
"I should have just said they have a significant advantage in output headroom."
which one? like you said, they model pretty much the same watt for watt. they use different methods to cool the coils. are you saying that the td will slaughter the jbl for power handling/output headroom or did you just speak too quickly on this one?
btw, from what i've seen, for a home system, i'd go with the td, so this isn't a fanboy question.
LTD02 is online now
post #24 of 85 Old 10-01-2011, 06:53 PM
LTD02's Avatar
Liked: 2574
nichol, just in case you are curious, here is 2242 in 12 c.f. and 8 c.f.
in a typical room, you are going to get some boost under about 30hz, so consider that.
a filter on the orange line of +3db, q=2, f=22hz matches them up. personally, i'd go with the smaller enclosure, but if you have the space, larger is more efficient, which is always good.
LTD02 is online now
post #25 of 85 Old 10-01-2011, 07:46 PM - Thread Starter
nichol1997's Avatar
I am located in Virginia so a little too far to come and get the cabinets. Thanks for the offer though.
post #26 of 85 Old 10-01-2011, 08:10 PM - Thread Starter
nichol1997's Avatar
I have the space so the free output down low looks very appealing to me. The cabinets will be part of my entertainment center.
It rained all day today and more rain is expected tomorrow so no cutting mdf for me this weekend.
post #27 of 85 Old 10-01-2011, 08:29 PM
Tack's Avatar
Liked: 3467
As long as they don't try to turn them into something they aren't, I agree.
BTW I wasn't picking on your wording so much as it was a reason to blab about a couple of my favorites.
Its actually nice to see a fairly warm reception for Nichols thread. I remember 3 or 4 years ago my first thread about 2242s was met somewhat chilly.
Ricci- if you want a TD to measure, I can send you mine for a while. I saved Erich Hs' indestructible shipping boxes. That dude knows how to pack stuff.
Tack is online now
post #28 of 85 Old 10-01-2011, 08:50 PM
coctostan's Avatar
Liked: 135
I meant they model to virtually the same anechoic response at 1w. The TD18 has more xmax therefore it has more output headroom (neither is thermally limited in these boxes). I'd put money that nobody could pick a winner in a true double blind...assuming both are within their limits. I'm also assuming these are being used as subs. How they perform up past 150hz could show some differences that would require some testing, but I think that is a different discussion.
post #29 of 85 Old 10-01-2011, 11:56 PM
Bass Enabler
Liked: 4167
post #30 of 85 Old 10-02-2011, 07:52 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
Thanks Scott. I think I will pick one or 2 up in the group buy.
Ricci is offline
