Aftermarket amp for Kef psw2150 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 2 Post By ninja6o4
  • 1 Post By ninja6o4
  • 1 Post By Fido_One
post #1 of 26 Old 10-03-2011, 10:46 AM - Thread Starter
mattbrid's Avatar
I have the psw2150 sub made by Kef. It's my THIRD one after the first two amps died. The sub has just died again (loud buzzing even when not connected to the receiver). This appears to be a common problem with these subs (amps). Anyway, I'm going to buy a different brand of sub as a replacement. However, it seems to be a shame not to use this sub for something (maybe in the den). Therefore, I want to put in an aftermarket amp. I see Dayton makes a 250wt plate amp.
Does anyone have experience with this (or similar) type of thing? Thanks.
mattbrid is offline
post #2 of 26 Old 12-23-2011, 01:53 PM
marvinbeaverdip's Avatar
I realize this is an old thread, but I JUST finished fixing my amp (had the buzzing sound), and it was very easy. It was also really cheap. The new cap required cost $1. I can lead you through how to fix it if you want.
marvinbeaverdip is offline
post #3 of 26 Old 12-27-2011, 08:59 AM
taysbenz's Avatar
I have the buzzing problem on my 2150. If you could walk me through the repair i would be most appreciative
taysbenz is offline
post #4 of 26 Old 01-06-2012, 02:39 PM
zenfort's Avatar
Hi,
I would like to know any info on replacing amp in KEF PSW2150 also.
Mine died for the second time, a year or so ago - it's been sitting since then as not wanting to spend the money the shop charges.
If I could replace with after market or repair inexpensively - that would be great.
The shop had said he had a time opening the unit up. Is that not the case?
Id rather repair it over having it sit ant longer or selling it for parts - since I've already invested in it twice.
Any help would be appreciated.
namaste
zenfort is offline
post #5 of 26 Old 01-10-2012, 08:08 PM
Hey- I don't regularly check this site, so sorry for not responding earlier. Anyway, the "buzzing" fix is fairly easy. The C52 capacitor (location on the pcb, not a model number or rating) is located just above the two large smoothing caps on the amp.
First you need to locate a 47uF 100v 105degree radial capacitor. The one that has failed is a 63v 47uf 85degree one, but you need to "upgrade". I didn't have any place nearby that sold them, so I bought two from ebay. They cost $2 shipped.
Second, you need to take out the plate amp from the box, remove all the wire connectors connecting the amplifier part to the pre-amp part (the amplifier itself is the pcb that has the two large caps attached, and the transistors that are connected to the large heat sink.), and then unscrew the amp from the back plate.
I found that I was able to unsolder the C52 cap from the amp pcb without disassembling any more than this. If you're not able to access the posts underneath, then you'll need to unscrew the pcb from the bracket as well as unscrew the transistors from the heat sink. My advice is try first before going through this extra work. Make sure you note the polarity of the cap before removing it, and install the new one in the same orientation. Once the new cap is in, you just need to reassemble everything and plug it in.
post #6 of 26 Old 01-11-2012, 09:01 AM
Cabrito24's Avatar
I had the same problem... Thanks marvin, your advice just worked for me!
Cabrito24 is offline
post #7 of 26 Old 02-06-2013, 07:17 PM
rachurch's Avatar
Old thread, but I want to try this and the ebay listing is gone. Would this work?
http://www.amazon.com/Nichicon-Thru-Hole-Aluminum-Electrolytic-Capacitor/dp/B0058V13QQ/ref=sr_1_1?s=industrial&ie=UTF8&qid=1360203386&sr=1-1
Nichicon 47uF 100V Thru-Hole Aluminum Electrolytic Capacitor RADIAL 20% (Bag of 5)
Rich
rachurch is offline
post #8 of 26 Old 02-09-2013, 01:35 PM
dbaack's Avatar
dbaack is offline
post #9 of 26 Old 05-28-2013, 12:40 PM
ninja6o4's Avatar
I had this problem on my PSW2150. Marvin's description was perfect and I was able to repair mine. How long it will last for, who knows.. As I understand it, his sub completely died shortly after his repair as noted on another forum.
Here are the pics uploaded to imgur: http://imgur.com/a/LYgnJ
A couple notes about my repair job:
  • Only the speaker leads hold the back panel to the sub box after you've removed the screws holding it on. They are in the center of the board and mine were quite tight. I had to use gentle but firm pressure to unplug them from the board.
  • I could not remove the wires connecting the amp to the pre-amp etc. I think the plugs were soldered or glued in. So, I improvised and rested the amp at an angle on top of the pre-amp so I could get to the solder points underneath, without having to disconnect any wires (except the one plug right beside the capacitor itself)
  • I used a standard Weller WES51 Analog Soldering Station - just like this one: http://amzn.com/B000BRC2XU
  • I did have to add a touch of fresh solder as I had wicked off most of the original when removing the old capacitor
  • The capacitors I bought had very long legs on them - I trimmed them to fit a little better.
HTH somebody in the future. Feel free to post or pm if you have any questions.
Fido_One and Plasma_Chris like this.
ninja6o4 is offline
post #10 of 26 Old 06-24-2013, 12:10 PM
Fido_One's Avatar
ninja6o4,
Your post and the pics are friggin' awesome. Thank you. I have my capacitor on order and my fingers crossed. Your PSW2150 still holding up after that work?
Fido_One is offline
post #11 of 26 Old 06-24-2013, 02:15 PM
ninja6o4's Avatar
Originally Posted by Fido_One View Post
ninja6o4,
Happy to report that the sub is still working great as of yesterday. Definitely worth trying at the very least, considering the alternative is a $200+ replacement. Good luck!
Fido_One likes this.
ninja6o4 is offline
post #12 of 26 Old 06-26-2013, 05:58 PM
Fido_One's Avatar
Huh! It worked! Had been so long since I had a soldering gun I was sure I had made a mess of it. I had a call into Kef, and they were saying a solid 180 + shipping to look at it, which I couldn't afford - this post of yours and your pictures gave me the confidence to give the DYI a go. Thanks again!
ninja6o4 likes this.
Fido_One is offline
post #13 of 26 Old 06-26-2013, 07:16 PM
ninja6o4's Avatar
Good stuff! I'm glad to hear the pics and OP helped. Enjoy hearing that bass once again smile.gif
ninja6o4 is offline
post #14 of 26 Old 09-17-2014, 09:17 PM
Liked: 0
After a year of being KEF-less, I decided to take a stab at replacing the C52 capacitor in my 2150 PSW after my Polk Audio replacement-sub started making noises, too. It was okay, but I missed the deeper richer bass and much better performance of my KEF. I'm happy to report that my attempt at fixing my sub was a resounding success! However, I did notice that the voltage on the speaker output terminals measured 139 to 140 mVolts, a bit more than the 100 mV that the instructions mentioned. Nonetheless, my 2150 is working like a champ again! Thanks for the detailed instructions!
bbigby64 is offline
post #15 of 26 Old 09-18-2014, 08:56 AM
ninja6o4's Avatar
Glad to hear this is still helpful for people out there.
Just to update: More than a year after my resolder job and my subwoofer is still pounding as hard as ever
If anyone else out there has this issue and is considering a fix, my advice: do it!
ninja6o4 is offline
post #16 of 26 Old 09-20-2014, 05:30 AM
Liked: 0
Yes, absolutely! Fix it!
bbigby64 is offline
post #17 of 26 Old 10-02-2014, 03:01 PM
Plasma_Chris's Avatar
Liked: 0
Yes indeed. I printed the pictures and instructions, ordered the capacitor online, and bought a nice soldering iron.
I hadn't soldered since high school (about 30 years ago), so the disassembled Subwoofer sat there for a few weeks,
while I worked up the nerve. I gave it my best shot and put it all back together.
Yes, the lead wires from the speaker to the amp are *short*!
I powered it up and didn't really expect it work. No buzz, that part's good... and then lo and behold: the BOOM!
I got my Bass back! Plus the knowledge that I can actually do a simple solder. And saving the cost of a new Sub-Woofer.
THANKS ALL AROUND!
Plasma_Chris is offline
post #18 of 26 Old 10-26-2014, 11:39 AM
Liked: 0
Talking Another Kef PSW2150 repaired
Hi,
My PSW2150 start to buzz yesterday. I found this thread and i'm so happy! I want to share my success with you.
Just to let you know i checked the pictures and text carefully. It take me 20 minutes and i'm not very good with the iron... You need four hands to screw the plate amp back. There is a radiator plate with some thermal paste on it and it slip so you have to hold it for screwing.
My local electronic shop sell the replacement part 100v 47uF 105degree radial capacitor Nichicon for 0,52$.
Saved me a lots. Thanks marvinbeaverdip and ninja6o4. I register just to thanks you.
Good repair everybody
Bob
bob2014 is offline
post #19 of 26 Old 03-15-2016, 07:59 AM
Liked: 0
My father gave me this subwoofer and simply said "its broken, fix it and its yours". Thank you for this post!!! I'm an EE, so I can say that this fix was simple, but it may be more difficult for others that aren't as skilled with a soldering iron. I ended up changing C52 to a 100uF 85C cap (its all we had on hand at work). I kept the leads long on the cap to try and get it away from the power resistors. So far its been working like a charm.
Two things I would do differently:
1) If I were to buy a cap, I'd get one with a higher thermal rating to try and avoid the obvious heat issues that are in this section of the board.
2) I am a bit concerned that the heat sink compound should be replaced. I may come back after getting some arctic silver to clean up this job.
Happy fixing!
CarmelKona is offline
post #20 of 26 Old 06-05-2016, 12:06 AM
Liked: 0
Carlos Herrera is offline
post #21 of 26 Old 06-05-2016, 12:31 AM
Liked: 0
number part change ??
post #22 of 26 Old 07-23-2016, 09:59 AM
KenM10759's Avatar
Quoted: 1199 Post(s)
Liked: 664
I'm going to help a friend fix TWO of these subs with the same problem. Thanks for sharing!
Best source for the replacement/upgrade capacitors? Would this one work?
http://www.newark.com/illinois-capac...tor/dp/69K7954
Or this one?
http://www.newark.com/multicomp/mcrh...tor/dp/70K9739
Well, nevermind. I hope they're right, but I went ahead and bought 4 (in case two other people near me with these subs need a repair part), but went with these from Digi-Key, total $5.53...shipped. If they're not right I'm only out by the cost of a scratch off lottery ticket and my chances of winning with this are far better.
http://www.digikey.com/product-detai...1973-ND/589714
KEF R500, R200C, R100, SVS SB2000 sub, NAD T758 receiver, Pro-Ject RPM1 TT w/ Sumiko Pearl, Bluesound Vault2, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer.
KenM10759 is online now
post #23 of 26 Old 07-29-2016, 11:14 PM
ninja6o4's Avatar
Or this one?
Glancing at those links, all of those caps look identical and should all work for this repair.
Just checking in - yes, 3 years later, the sub is still pounding away Although at certain frequencies I can hear a flapping noise - the speaker seal seems fine, so I think something has come loose inside the box. I'll need to venture inside once again if I want to be rid of it. However, it doesn't see as much duty as it used to, so I might just leave it.
Kudos to everyone that's opted for a quick repair rather than adding to our landfills! Carry on with those low frequencies!!
ninja6o4 is offline
post #24 of 26 Old 07-30-2016, 03:14 AM
KenM10759's Avatar
Liked: 664
My friend and I went to my favorite audio dealer the other day and he walked out with a new SVS SB2000. I'll be doing the repair on the two KEF subs today and if they test well, they're for sale.
He's tired of unreliability so the attraction of a 45 day trial, no questions asked return, 1 year full cost upgrade credit and 5 year warranty combined with a more potent and better sounding sub all added up to the decision.
It's very encouraging to know the fix could well be all that's needed to get these KEF subs reliable. The new owners will appreciate it.
post #25 of 26 Old 11-30-2016, 09:14 AM
ninja6o4's Avatar
Just checking in, after 3.5 years, my sub made that buzzing noise again. I took it all apart and I could smell that dreaded burnt electrical smell so I feared the worst
Looking at my solder work today vs the pics I took 3 years ago, it looks like the solder I had added had corroded to the point that the connection was lost. Since I was already in there, and I still have the bag of 10 I had purchased, I changed the cap again, just in case, and repaired the connection with some fresh solder.
Plugged it back in and turned it on - sweet, sweet bass
P.S. also found the source of the odd flapping noise - a movie ticket stub had somehow worked its way into the box and was bouncing around in there. LOL! An even easier fix than the solder job.
ninja6o4 is offline
post #26 of 26 Old 11-30-2016, 11:36 AM
KenM10759's Avatar
Liked: 664
Thanks for checking in. I worry about choosing the right solder for that very reason, so that's why I let my son give me his to use. Now I have someone besides myself to complain about if something goes wrong with the repair I did on those two 2150's.
