Time to make some sawdust. - AVS Forum | Home Theater Discussions And Reviews
Old 11-03-2011, 08:37 PM - Thread Starter
Kanaris's Avatar
I have been waiting forever for CSS to release their new SDX 15 II..now the date has been pulled back to the beginning of 2012.
I know their 15 incher is give or take the same diameter as my 15 inch Tempests.. if more I can modify the box to accommodate the SDX15 II...
So I wanted something that doesn't just have a square look and won't break the bank book..
PassingInterests Howitzer project got me thinking...and also gave me some ideas..
I wanted something thats about 8 cubes and houses 2 drivers.. to net me at least right under the 7 foot for 3.5 ft. per driver sealed..
These are some pics ... that I started this week..
more to come later....
Kanaris is offline
Old 11-03-2011, 09:00 PM
LTD02's Avatar
Quoted: 1770 Post(s)
Liked: 2015
holy moley...those are some overkill routed braces. :-)
nice choice of design and ply btw...will be lurking...
Listen. It's All Good.
LTD02 is offline
Old 11-03-2011, 10:55 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
What will happen to the THTs?
JSS
maxmercy is offline
Old 11-04-2011, 12:27 AM - Thread Starter
Kanaris's Avatar
JSS
Wife wants her closet space back... I put up an ad to give them away for free locally but no one wanted them... too bad they were good and even could have been better if I had more placement options than the one was stuck with.
Kanaris is offline
Old 11-04-2011, 05:45 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Some local DJs or clubs may want them.....try the BFM forum's for sale section....
But I like the look of the new cabs....
JSS
maxmercy is offline
Old 11-04-2011, 08:46 AM
PassingInterest's Avatar
Quoted: 166 Post(s)
Liked: 384
Looking good. I hope you find a buyer for the THTs.
PassingInterest is offline
Old 11-04-2011, 07:21 PM - Thread Starter
Kanaris's Avatar
I decided to clad the sides with 3/4" MDF, kerfed cut... so it can bend...
gonna fill up the kerfs with a couple of tubes of NoMoreNails later.. and cap the top and bottom as well as install another front.
Kanaris is offline
Old 11-05-2011, 01:04 AM
goku14139268520's Avatar
Tuned in...
*grabs popcorn*
goku14139268520 is offline
Old 11-05-2011, 11:49 AM - Thread Starter
Kanaris's Avatar
I managed to fill the screw heads and put on a coat of primer and cut the holes... BTW this project has cost me $20 so far the ply and mdf were packaging scraps from a huge machine we purchased at work.. hence the marks you see on the ply...
Kanaris is offline
Old 11-05-2011, 12:17 PM
shepP's Avatar
Quoted: 35 Post(s)
Nice way to save on costs and trees. I wish I wasn't so far away as I would be happy take the THTs and drop in my 2 original tempests that are still in sealed enclosures.
shepP is offline
Old 11-05-2011, 12:34 PM
Tankramer's Avatar
The cab's are looking good. How did you calculate the volume with the curved sides? I am working on something similar an the only way I could think to do it was build a model and fill it with styrofoam packing material. It worked obviously but I'm wondering if you knew simpler way?
Tankramer is offline
Old 11-05-2011, 12:50 PM
tuxedocivic's Avatar
Quoted: 1521 Post(s)
Liked: 1385
^ Do you have access to autocad? I draw it up then use the area command, then multiply by the height. Somewhat approximate, but good enough.
tuxedocivic is offline
Old 11-05-2011, 04:46 PM
Quoted: 166 Post(s)
Liked: 384
Just when I thought this build was the coolest, you went and made it even cooler with that statement. Very, very nicely done, sir.
Old 11-05-2011, 05:46 PM - Thread Starter
Kanaris's Avatar
Thanks,but it's no where near your masterpieces...
I need some help with something.. if the cab contains two woofers and each is wired for 4 ohms then if I put a jumper to the middle red and black connectors and put the wire from my amp to the exterior connectors will I get 2 ohms total?
Kanaris is offline
Old 11-05-2011, 05:57 PM
shepP's Avatar
Quoted: 35 Post(s)
I think that would be a series connection and would give you 8 ohms. If you want 2 ohms you want to run parallel which would be both reds to the one red connection on the amp and both black to the black connection on the amp.
shepP is offline
Old 11-05-2011, 06:00 PM
LTD02's Avatar
Liked: 2015
as you described, you will be putting the drivers in series. with series you add the impedance, so you will have 8 ohms net.
LTD02 is offline
Old 11-05-2011, 06:02 PM
LTD02's Avatar
Liked: 2015
definitely don't plug power into each of those connections then wire them together. that will fry your amp.
LTD02 is offline
Old 11-05-2011, 06:17 PM - Thread Starter
Kanaris's Avatar
My old brain is confused ,is this correct for total 2 ohms?
Kanaris is offline
Old 11-05-2011, 06:25 PM
Quoted: 166 Post(s)
Liked: 384
Yes, but remember that is "nominal." At any given frequency, the impedance can be higher or lower. I'll let the experts elaborate or correct me.
Old 11-05-2011, 06:28 PM - Thread Starter
Kanaris's Avatar
My ohm meter gives me 3 ohms..
Kanaris is offline
Old 11-06-2011, 04:26 AM
coolrda's Avatar
Quoted: 371 Post(s)
Liked: 309
Resistive and nominal?
coolrda is offline
Old 11-06-2011, 08:39 AM - Thread Starter
Kanaris's Avatar
I would think resistive as in resistance.
Kanaris is offline
Old 11-06-2011, 12:09 PM
Quoted: 166 Post(s)
Liked: 384
If that is for the two drivers in parallel, then you should get 6 ohms for each one seperately on your meter. It sounds like this was an unexpected reading, so I hope there's nothing wrong with your drivers or wiring. I'll let the experts take it from here.
Old 11-06-2011, 12:34 PM - Thread Starter
Kanaris's Avatar
They got dual 8 ohm vc's I have them each wired parallel for a total of 4 ohms and then agian parallel them to get 2 ohms... my ohm meter gives me 3 ohms which is probably correct.
Kanaris is offline
Old 11-06-2011, 05:12 PM - Thread Starter
Kanaris's Avatar
I sprayed it with a black rubberized texture
I will take some measurements and post them tomorrow.
I am also making a dual opposed sub for my other two tempests..
Again I am using used MDF that I salvaged.. I installed hardwood on all the edges to strengthened the mdf..
Kanaris is offline
Old 11-06-2011, 08:38 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Very Nice!!!
JSS
maxmercy is offline
Old 11-06-2011, 10:30 PM - Thread Starter
Kanaris's Avatar
Dimensions are 24x22x36 (8.5 cu.ft.) minus about 1 1/2 for the drivers and ribbing.. plus I will be stuffing it with 20 pounds of pillow stuffing...
All sanded up and ready for me to install some arborite..
Kanaris is offline
Old 11-07-2011, 01:10 PM - Thread Starter
Kanaris's Avatar
This one will go next to the couch and it will be corner loaded..
Coincidentally, anyone know how to set up 2 subs with Audeyssy?
Kanaris is offline
Old 11-07-2011, 01:56 PM
noah katz's Avatar
Quoted: 633 Post(s)
Liked: 239
Damn, you're fast!
Noah
noah katz is online now
Old 11-07-2011, 02:11 PM
Fatshaft's Avatar
Quoted: 486 Post(s)
Liked: 729
Damn, you're fast!
No kidding!!! That's the fastest I've seen anyone build here. WOW!
Kanaris,
I'm thinking about buying 2 Pi 18's and am wondering if you would/could build sealed cabs for me.
Since you're in Montreal and I'm on the south shore of Montreal.
How much would you charge?
Man are you good and FAST!!!!
Very impressive!
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
