where to find OC 703 for DIY corner traps? - Page 2 - AVS Forum
post #31 of 52 Old 11-30-2011, 01:40 PM - Thread Starter
beastaudio's Avatar
Quoted: 213 Post(s)
Liked: 555
more and more i look at it, more and more it makes sense to just do the whole front wall 4 inches thick and trap the corner THAT way...
(European models do not accept banana plugs.)
"If you done it, it ain't bragging." ~ Walt Whitman
AE TD12x SEOS12 Build
Beast's DIY Master Measurement Thread
DIY Emminence Coaxial Surround Thread
beastaudio is offline
post #32 of 52 Old 11-30-2011, 05:23 PM
mannoiaj's Avatar
that roxul they have is much cheaper than the OC703, is it's absorption coefficient the same? How about the atsacoustics brand?
I don't know about absorption coefficient. I know the stuff I bought was "supposedly" very comparable to the OC703... the same stuff that I linked you to. I will say that it did what I wanted it to building an 8 ft tall corner bass trap. I also bought some 4' x 2' wall panels. I will post pics if you're interested, and I believe ATS to be a brand that is honest and going about making a buck in the right way.
mannoiaj is offline
post #33 of 52 Old 11-30-2011, 06:31 PM
maxserg's Avatar
Contact owens corning for a local distributor. Usually they don't sell for public but for the guys who work in ventilation or air conditionning systems.
maxserg is offline
post #34 of 52 Old 11-30-2011, 06:52 PM
Brad Horstkotte's Avatar
Liked: 57
Roxul AFB 4":
125 250 500 1K 2K 4K
0.86 1.11 1.20 1.07 1.08 1.07
OC 703 4"
0.84 1.24 1.24 1.08 1.00 0.97
Brad Horstkotte is offline
post #35 of 52 Old 12-01-2011, 07:10 AM - Thread Starter
beastaudio's Avatar
Quoted: 213 Post(s)
Liked: 555
Roxul AFB 4":
OC 703 4"
yep I saw that in the chart, ive expanded my search to include this as well, but as I said above, now im just looking at doing the whole front wall with 4inch panels. that outa prevent any reflections right now I have some 2'x4' 2 inch thick panels behind the front stage, but they dont extend all the way to the corners.
post #36 of 52 Old 12-01-2011, 07:33 AM
NicksHitachi's Avatar
Quoted: 37 Post(s)
Liked: 101
SPI
Specialty products, I have one local quoted me 703 unfaced $55 a pack couple months ago...
http://www.spi-co.com/
search for local office to U.
Don't waste time reading signatures.....
NicksHitachi is offline
post #37 of 52 Old 12-05-2011, 06:13 AM - Thread Starter
beastaudio's Avatar
Quoted: 213 Post(s)
Liked: 555
ok so how about rear wall, its about 29 feet from front wall, doesnt have available corners as a hallway extends down one way, and a staircase up the other corner, so what do you think, do I need 2 inch or 4 inch panels on the walls there? How about down the hallway? Think that would have any benefit as there would be nothing more than possible a 3rd or 4th order reflection anyways?
post #38 of 52 Old 12-05-2011, 07:33 AM
kingpin111's Avatar
I did the same as another poster.
All 4 corners of the room.
From what I was told you can compress different sections to absorb different frequencies.
MKtheater -"I just saw 300 tonight, great movie. I literally wanted to spear people after the show."
My speaker build. "PROJECT OVERKILL" WWMTMSS
kingpin111 is online now
post #39 of 52 Old 12-06-2011, 09:24 AM
jsil's Avatar
Hi guys,
I'm in CA and was wondering if anyone now's where to find a dealer out here thanks.
jsil is online now
post #40 of 52 Old 12-06-2011, 09:28 AM
exojam's Avatar
Liked: 26
Check the link in post 36 to see if there is a local company for you.
James
exojam is offline
post #41 of 52 Old 12-06-2011, 11:22 AM
Liked: 57
Originally Posted by jsil View Post
Hi guys,
I used MacArthur Co, they were quite helpful - good prices, and I could order by the sheet vs. the bundle. Looks like they have an office in San Jose:
http://www.macarthurco.com/contact-us
post #42 of 52 Old 12-06-2011, 01:40 PM
jsil's Avatar
Brad Horstkotte,
Called them and they have it in stock thanks.
jsil is online now
post #43 of 52 Old 12-07-2011, 10:01 AM
jsil's Avatar
Where can I get a step by step on building bass traps and panels to hang on walls. What about the space between the wall and panels.
jsil is online now
post #44 of 52 Old 12-07-2011, 11:31 AM
Liked: 57
Here's a good resource for making the SuperChunk style of corner absorbers: http://forum.studiotips.com/viewtopic.php?t=535
Building panels is pretty easy really, you build a wooden frame, cover it with fabric (staple to the back of the frame), and rigid insulation fits in behind the fabric. Looking here might give you some ideas:
http://www.acoustimac.com/index.php/...ic-panels.html
post #45 of 52 Old 12-07-2011, 12:29 PM
localhost127's Avatar
Liked: 24
Originally Posted by Bill Fitzmaurice View Post
+1. They should be called midbass traps, as that's as low as they're effective to. They're called bass traps as they help control boom, which is associated with bass, although actually sourced in the midbass.
this is not accurate.
effectively designed and placed porous absorption can make an impact down to 40hz.
localhost127 is offline
post #46 of 52 Old 12-07-2011, 12:34 PM
Liked: 24
as FOH stated, materials with low gas-flow resistivity (eg, pink fluffy attic insulation) are most effective for LF bass traps compared to OC703, OC705, etc.
even 34" corner chunks made with pink fluffy will perform better. if you stack cuts of pink fluffy, you need to add horizontal support every few feet such that the weight of the upper layers do not compress the layers at the bottom.
it is more wise to 'hang' the pink fluffy from the ceiling down, such that there is no need for the horizontal supports or compression.
eg, if you have an 8ft ceiling, then you will hang the first piece from the ceiling (8ft tall) all the way into the corner. you will need to cut the width down to say, 4" or so for the first first layer that is deepest into the corner. the next layer you hang (as the corner opens up), will be slightly wider (8"), and then keep adding layers until you are at 34" wide (faced), or extend even further if you have the room.
while it may seem unconventional that lower GFR material is more effective at LF absorption, like many things in acoustics, what is assumed or intuitive is not always correct.
use the cheaper (and more effective) pink fluffy attic insulation for corner porous bass traps, and save the expensive OC703 for broadband specular reflection absorbers.
post #47 of 52 Old 12-07-2011, 12:42 PM
Liked: 24
Originally Posted by Fatawan View Post
http://www.bobgolds.com/AbsorptionCoefficients.htm
Note how the ultra touch cotton has very good absorption--see if your local Home Depot has it
anyone referencing those absorption coefficients needs to pay care to the 2nd paragraph on that page.
it is important to understand what those values mean - reverberant chamber coefficients can be used as a comparison to other products - but those values are not directly applicable to a small acoustical space such as your room.
post #48 of 52 Old 12-08-2011, 01:50 PM
jsil's Avatar
Where are you guys buying your fabric from.
jsil is online now
post #49 of 52 Old 12-08-2011, 02:33 PM
S_rangeBrew's Avatar
Liked: 32
Hi guys,
Just look in the Yellow Pages for "HVAC" or "Heating and Cooling" suppliers. THEY are the people who use most of this rigid fiberglass insulation for covering heating and cooling ducts. They are usually located in your local industrial park along with all the other suppliers of contractors.
I had a hell of a time finding this stuff until I followed the advice I just gave you. It's very cheap. A few bucks a sheet. Warning: the pros price it by cubic foot. So be prepared to say something like: "I need 16cubic feet of rigid fiberboard insulation" for them to understand you. They may give you an option of thickness, but my local HVAC warehouse only had 2" stuff in stock.
If you are ordering it online or driving 2 hours to get it... you are doing it wrong. HVAC suppliers are everywhere.
Go to your local fabric store and look for thin polyester (also know as Gabardine by some) in the color you want. You will often see people referring to "Guilford of Maine" acoustical cloth like it's something special. It's not. It's just polyester cloth. Depending on building codes, (and if you even care about them) you may need to make sure the cloth has the proper fire resistance.
Acoustic treatments are dirt cheap, if you know where to look for the stuff.
I just wrapped the cloth over the panels and secured it with sewing stick pins (you know, the ones you have to remove from new clothes) then impaled them on the wall on a row of finish nails I tacked partway in to the wall at an angle. Rock solid, lightweight, easy to move, simple and cheap.
S_rangeBrew is offline
post #50 of 52 Old 12-08-2011, 04:15 PM
Liked: 57
triple velvet (screen wall): syfabrics.com
speaker cloth (column faces - in front of speakers): rosebrand.com
Guilford of Maine (wall panels): fabricmate.com
Commando Cloth (soffit): magnafabrics.com
marine vinyl (column sides): allvinylfabrics.com
post #51 of 52 Old 12-20-2011, 09:43 AM
jsil's Avatar
Going to start building me some bass traps. Better to use 2" or 4" for corner bass traps.
jsil is online now
post #52 of 52 Old 07-03-2013, 01:56 PM
Mfusick's Avatar
Quoted: 70 Post(s)
Liked: 663
Mfusick is offline
User Tag List
