Stentorian build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 255 Old 12-18-2011, 03:11 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 166
Originally Posted by Dusty Shopfloor View Post
That would look good. Time is limited, so I'm not sure if I will go that route or not, but thanks for the great idea.
flyng_fool--The recipient will use them for gigs in small venues.
Then Duratex it is!
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #92 of 255 Old 12-18-2011, 03:14 PM - Thread Starter
Dusty Shopfloor's Avatar
I upsized one pair of coils, so I could get some that were in stock, since I was in a hurry. If yours look different, that's why.
I epoxied some small standoffs on the underside, to allow room for wires.
Dusty Shopfloor is offline
post #93 of 255 Old 12-18-2011, 03:36 PM
BeerParty's Avatar
BeerParty--I don't mind if plywood edges show, as long as they look good and I think these will. Laminate is not an option and neither is veneer.
For a gift like this, would it be appropriate for you to simply seal then up and include an offer to finish them after Christmas? Then you could ask the recipient how they would like them finished without ruining the surprise.
If that isn't an option, I would suggest you simply spray a couple coats of clear poly.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #94 of 255 Old 12-18-2011, 03:46 PM
tuxedocivic's Avatar
Quoted: 2202 Post(s)
Liked: 2078
Flat black.
Easy, effective, universally liked.
My youtube channel: Impulse Audio
tuxedocivic is online now
post #95 of 255 Old 12-18-2011, 05:03 PM - Thread Starter
All great ideas, guys. Thanks.
That's thinking outside the box! It wouldn't have occurred to me. Unfortunately, it won't work this time, because the recipient will be driving a couple hundred miles to get back home on Christmas day. Great idea, though.
They're all great ideas, guys. Thanks again.
post #96 of 255 Old 12-18-2011, 05:58 PM
mayhem13's Avatar
Quoted: 45 Post(s)
Liked: 29
As always, an excellent job em......Dusty! Coming from my days in the profound field, corrugated metal grills and Duratex should do the trick. They'll bring less attention to themselves on stage and should be durable enough to last a few years. And before you finish em don't forget pole mounts, recessed handles and corner guards!
mayhem13 is offline
post #97 of 255 Old 12-18-2011, 06:05 PM - Thread Starter
Thanks for the useful tips, Mahyem13.
If I can get the Duratex locally, I may go that route. I'm pressed for time though, so handles, stand mounts and corner guards might not make it. Hopefully, the recipient can take care of the final touches as needed.
post #98 of 255 Old 12-18-2011, 08:33 PM
mayhem13's Avatar
Quoted: 45 Post(s)
Liked: 29
No need to do it yourself as it requires a special gun and it's messy. Just take em to a Rhino Liner place and let them do it. Hardware I mentioned can always be added later.
mayhem13 is offline
post #99 of 255 Old 12-18-2011, 09:28 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
a dome tweet in a pro audio app with no protection seems like "bye bye" to me. why not series a fast blow fuse in line with the tweet or even a "light bulb" limiter?
question to the designer, not to mr. shopfloor.
Listen. It's All Good.
LTD02 is offline
post #100 of 255 Old 12-19-2011, 04:49 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 166
I didn't think about that. If he's using them for DJ'ing or pro sorts of applications I would think that a CD would be a must.
post #101 of 255 Old 12-19-2011, 06:17 AM - Thread Starter
Color change.
I initially sprayed them with clear to keep my options open, while I decided on the finish. I am persuaded that black is the way to go for this application.
post #102 of 255 Old 12-19-2011, 07:26 AM - Thread Starter
Has anyone noticed a recommended amplifier rating for these?
I mean for small venues pro-sound use.
Sorry if I just overlooked it.
post #103 of 255 Old 12-19-2011, 07:41 AM
Liked: 2078
Can you elaborate on what the use is. Pro DJ in small venue.
Dance club?
Light background jazz during lunch?
Easily portable necessary? Or stays put at a club?
Even Curt says on his page it's not a dedicated pro device. It's approaching pro use. It's HT/Pro use. I would think more than 100 watts would eat that $12 tweeter quickly.
post #104 of 255 Old 12-19-2011, 08:22 AM
Liked: 2078
Any chance you have 8, 10watt, 8.8ohm resistors kicking around. Using 4 resistors instead of 2 4.4ohm resistors might help power handling of the xo. Mind you, using 2 resistors is a bit of built in protection. As they heat up they'll resist more. And possibly burn up with enough power flowing through. Just be prepared to replace those for him if it happens.
The xo point is about 2200hz and the Vifa spec sheet says 50watts long term power handling. I would think pro use is long term power handling. But how much of a 100watt amp reaches the tweeter? Probably less than 50watts in typical use.
I'm not trying to scare you. Just offering advice. I would think you are in general ok here. Depending on his use. I'd just hate to see him take home his new toy and pump 200watts continuous rap through them at 120db and then something go pooofff.
Will he have a sub for these? The enclosure Q is a little on the high side. Bass extention won't be good. From Curt: "I still recommend using these
with a subwoofer, but they shouldn't disappoint if you don't". That was listening in his home. Depends how small is small, and what for of music.
Pro audio is a different beast
EDIT - Consider this http://www.parts-express.com/pe/show...umber=248-6700
Might be more than he needs. But has options and enough power to make these smoke.
post #105 of 255 Old 12-19-2011, 08:41 AM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Might be worth having a few spare tweets in reserve.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #106 of 255 Old 12-19-2011, 08:55 AM - Thread Starter
Thanks for the advice and recommendations, guys.
All I know about the musician is he plays guitar and sings in small venues.
The Behringer NU1000 iNUKE (2 x 300 watts into 4 ohms) gets me in the ballpark for what I need to know.
I'll advise him accordingly. Thanks, Pete.
I actually doubled the wattage rating on one pair of resistors, but only because the ones spec'ed were out of stock, not because of any foresight on my part.
I'll advise him to check for excessive heat on the smaller pair of resistors and super-size them if needed. Thanks for the tip, Tuxedocivic.
post #107 of 255 Old 12-19-2011, 10:18 AM
Liked: 2078
Ok, those upgraded resistors should help.
Hmm, I thought he'd be spinning or something. Guitar and (male) vocals don't have much content above 5khz. They do have a lot of content around 2khz though, which is where the tweeter would feel the strain.
I think they'll be fine. For $200 they're sure good. And will look a lot nicer than any pro stuff. He'll also be able to throw them in his HT when not playing gigs
Just to put it in perspective what real pro gear does, and why some here have questioned the pro use of this a little... A typical 12" guitar speaker (only 1) is about 100db sensitive. If the sentorians are 94db, that means it would take 300 watts for the sentorians to do what the typical guitar speaker can do with 100watts. And if you had 2 of those typical 12" guitar speakers, you'd only need 50watts to equal the 300watts. A lot of guitar players use a stack of 4 12"s only needing 25watts to equal the sentorians.
post #108 of 255 Old 12-19-2011, 04:05 PM - Thread Starter
tuxedocivic--Thanks for putting things into perspective for me.
I'm sure these Stentorians will be fine for him for now and in time I may get to do some Bill Fitzmaurice builds for him, as his needs grow.
Oh man, I really want an excuse to build some of Bill's Pro Audio stuff.
His Tuba Home Theater folded horn was such a cool build experience.
And his pro audio designs look fantastic.
post #109 of 255 Old 12-19-2011, 07:02 PM - Thread Starter
post #110 of 255 Old 12-20-2011, 05:56 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 166
MKTheater has the BFM DR200's and he says they're fantastic!
post #111 of 255 Old 12-20-2011, 06:16 AM - Thread Starter
Oh man, I'd better start saving up for that build.
post #112 of 255 Old 12-20-2011, 06:19 AM - Thread Starter
Center-punch the screw holes.
post #113 of 255 Old 12-20-2011, 06:46 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
wish i had your skills and tools.
amazing work. can't wait to see how you going to finish them.
smokarz is offline
post #114 of 255 Old 12-20-2011, 06:54 AM
filtor1's Avatar
Quoted: 213 Post(s)
Liked: 167
Do you happen to need any new friends to do projects for? If not, can you please donate some of your unspent skill to me? I bet you have a cache of extra for rainy days. lol I always look forward to your builds. No matter what you call yourself at the time.
Chris
filtor1 is online now
post #115 of 255 Old 12-20-2011, 07:13 AM
Brad Horstkotte's Avatar
Liked: 73
and they're a very different type of build, which could be fun to build
Brad Horstkotte is offline
post #116 of 255 Old 12-20-2011, 07:20 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 192
Nice looking build man!
I would think these perfect for light acoustic coffee house type venus with a subwoofer....
They might struggle over a set of drums though..... If so hand him a set of cat tails and stuff his kick.
NicksHitachi is offline
post #117 of 255 Old 12-20-2011, 07:21 AM - Thread Starter
Thanks, guys. I take a lot of pictures to show you guys how you can do it yourself.
Brad--It looks like a fun build.
post #118 of 255 Old 12-20-2011, 07:23 AM - Thread Starter
I would think these perfect for light acoustic coffee house type venus.
Thanks! And that sounds like good advice. I'll pass it on.
post #119 of 255 Old 12-20-2011, 07:26 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Dusty (PI),
I really like your shop table, did you build that? Have any plans/details?
smokarz is offline
post #120 of 255 Old 12-20-2011, 08:28 AM - Thread Starter
Dusty (PI),
Thanks! The two workbenches were among the very first things I built, when I was pretty inexperienced.
I don't have plans for them, but give me time and I'll step it through for you on how you can build it yourself. It's really easy.
