More Flat Pack Kits Coming. - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #361 of 1139 Old 06-06-2013, 04:15 AM
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
What do you guys think... Fusion-8 Alchemy or Alpha-8 Minion for side surrounds?
Do you think that these will integrate OK with my B&W fronts? I will eventually replace the B&W's with Sentinel's.
sslv2pwned is offline
post #362 of 1139 Old 06-06-2013, 02:41 PM
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
The first of two 18" 4cu ft flat packs is built. WOW... I love this thing. Awesome work, Erich. Thank you so much!
I also love my air compressor and brad nailer. I built this box in about 30 minutes. Glue and brad nails. No clamps needed.
Am I stupid for wanting to setup the driver and use the sub before sanding and DuraTex?
post #363 of 1139 Old 06-06-2013, 07:24 PM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Do people use any wood fillers or anything for the corners or outside seems? Is any needed or does it fit pretty much perfect?
04rex is offline
post #364 of 1139 Old 06-06-2013, 07:29 PM
Sibuna's Avatar
Quoted: 375 Post(s)
Liked: 429
they fit pretty close to perfect, you can use filler to fix any assembly issues. just sand before you use filler if the seams are not 100% even
Sibuna is offline
post #365 of 1139 Old 06-06-2013, 08:48 PM
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
I sanded all the edges and primed. I will use drywall plaster to fill a couple brad nail holes and one edge. I'll then sand and re-prime.
post #366 of 1139 Old 06-07-2013, 06:31 AM
Sibuna's Avatar
Quoted: 375 Post(s)
Liked: 429
Originally Posted by Erich H View Post
I need to order at least 75 of the Anarchy tapped horn boxes to get them cut. I would consider it if there was still enough interest.
Guys, are there any other subwoofer boxes we should look into? Or any other woofers for the 4 cuft boxes?
do we have a dual opposed 15 yet?
make it more square vs rectangle like the current dual opp designs on the site
Sibuna is offline
post #367 of 1139 Old 06-07-2013, 10:03 AM - Thread Starter
Erich H's Avatar
Quoted: 1417 Post(s)
Liked: 1793
It wouldn't work very well having a square box that big. Figure a sheet of mdf is 49" wide, then subtract of a 1/2" bit that goes around each piece. That leaves a 47" width to get 2 pieces from. You can't get two 24" wide pieces cut next to each other. So a 23.5 cube is only 6 cuft gross.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #368 of 1139 Old 06-07-2013, 10:29 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1320
Erich do you only build sub woofer enclosures, or do you also do speaker enclosures?
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #369 of 1139 Old 06-07-2013, 01:10 PM
antisuck's Avatar
Quoted: 100 Post(s)
Liked: 143
http://www.diysoundgroup.com/
antisuck is online now
post #370 of 1139 Old 06-07-2013, 03:29 PM
Urlryn's Avatar
I need to get off my butt this weekend and start building my flat packs for the 18 SI that i've had on preorder...
Anybody heard anything about when they would ship or even if they gotten them yet?
Speaking of building these flatpacks....any recommendations now that a bunch of people have built them now?
How are you doing your cable plugs/feets and such?
I have the Titebond glue and 6x 42" clamps
Wasn't sure what type of screws/nails to use yet so haven't bought any yet.
Also was reading something about Polyurethane construction Adhesive (Glue and seal your box in one step) ... anybody with experience with this stuff?
anything i forgot?
Urlryn
Urlryn
Pioneer SC-1222-K
Emotiva XPA-3
Behringer EP4000
Klipsch RF 7ii
Klipsch RC 64ii
Subs: Pair of SI D4 18's 4 cuft sealed
Urlryn is offline
post #371 of 1139 Old 06-07-2013, 03:50 PM - Thread Starter
Erich H's Avatar
Liked: 1793
I would just use Titebond wood glue. I have some photos showing the steps to follow for assembling those larger 4cuft boxes on the product page. I think they go together easier that way, but some might do it differently.
I should have directions for all the boxes done in the next week.
Erich H is offline
post #372 of 1139 Old 06-07-2013, 04:06 PM
Sibuna's Avatar
Quoted: 375 Post(s)
Liked: 429
anything i forgot?
Urlryn
titebond is so much easier to work with vs PL Premium (the construction adhesive)
there are a bajillion pics in my build thread in my sig. im not sure you even need to seal the seams with the rabbit joints. i did with PL because i like overkill.
Just take your time and try not to glue too much at once
i did it like this and it was pretty simple
Rib Braces into back
Top and Bot
1 side
inner baffle
other side
outer baffle
Sibuna is offline
post #373 of 1139 Old 06-07-2013, 04:39 PM
Dank1209's Avatar
I was thinking the same as. SSLV. Just glue with titebond and use my brad nailer.No clamps. Will that work ok. ?.
Also Erich is the ports that come with the tempest already cut to the right length for tuning.. thanks Dan
Dank1209 is offline
post #374 of 1139 Old 06-07-2013, 05:45 PM
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
I used Elmer's Wood Glue. I sure hope that was OK. I just realized that I forgot to buy feet.
How air tight are the sealed boxes supposed to be? Should I run a bead of glue in all the inside seams?
post #375 of 1139 Old 06-07-2013, 06:48 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
As long as all the joints have glue it should be air tight. You can fill the inside seams with glue but overkill really...
Mrkazador is offline
post #376 of 1139 Old 06-07-2013, 07:17 PM
nubz69's Avatar
Have you ever considered a 3 way? OSWG or cd horn, 8" midrange and a 15" or 18" woofer in one package? You could get 20-20k, low distortion, great sound and work on a watt or two.
nubz69 is offline
post #377 of 1139 Old 06-07-2013, 07:46 PM
Face2's Avatar
Quoted: 337 Post(s)
Liked: 203
Elmers is fine. If you believe you may not have a good seal, use silicone or calk. But, if you use silicone, let it cure for a couple of days before installing your driver(s).
Face2 is offline
post #378 of 1139 Old 06-07-2013, 07:58 PM
mtg90's Avatar
Quoted: 425 Post(s)
Liked: 806
Hot glue to fix leaks, dries quick no fumes.
mtg90 is offline
post #379 of 1139 Old 06-07-2013, 09:09 PM
Face2's Avatar
Quoted: 337 Post(s)
Liked: 203
Even better. Just try not to get a huge blob of it on your hand. biggrin.gif
Face2 is offline
post #380 of 1139 Old 06-08-2013, 12:49 AM
Eyleron's Avatar
Quoted: 260 Post(s)
Liked: 157
Dual opposed 18". I would've happily spent more for such instead of the 4' single 18" box in retrospect (not that the box isn't awesome).
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #381 of 1139 Old 06-08-2013, 02:17 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Man, that will be one huge box. Shipping might be prohibitive.
BDP24 is offline
post #382 of 1139 Old 06-08-2013, 03:19 PM
steve nn's Avatar
Liked: 433
I don’t like building multiple subs. A single is fun but anything over two becomes work instead of play. That’s just me.. just sayin.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #383 of 1139 Old 06-08-2013, 03:49 PM
Sibuna's Avatar
Quoted: 375 Post(s)
Liked: 429
does not have to be perfectly square just not coffin like
something like 18"W x 23"H x 25"D would be a good shape and about 6 cuft which should work for many 15" drivers
however im not sure it would work based on MDF sheet dimensions
Sibuna is offline
post #384 of 1139 Old 06-08-2013, 08:59 PM
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
Besides applying Duratex, my two 18" subs are complete. I tested them today with Thor and Transformers. The only calibration I did was with Audessey. I'm blown away. My old sub was a 100w MTX 12". It was very boomy and just made a lot of noise.
I'm not sure how loud it actually was, but my Denon 4311 volume was set to 0db. While watching a scene in Thor, a piece of plaster from the ceiling fell onto my shoulder. LOL
When my wife came home, I was watching Transformers. She came in and said she could feel the bass while sitting in the car in the driveway. No way, I said. I still don't believe her.
I need to figure out how to properly calibrate these subs. Audessey wants to turn the subs way down. What has me worried is I was seeing the red clipping lights come on on the NU6000 DSP.
post #385 of 1139 Old 06-11-2013, 01:22 PM
financethis's Avatar
did erich get hooked up with parts express?
I see lots of knock down boxes and different kits with these boxes.
epson 3010 projector
marantz 1402 avr
infinity beta mains, center and surrounds
110" dalite screen
tc sounds pro 5100 subwoofers
financethis is offline
post #386 of 1139 Old 06-11-2013, 04:03 PM - Thread Starter
Erich H's Avatar
Liked: 1793
I hooked up Parts Express with some of the boxes just like I did with the Overnight Sensation boxes.
Erich H is offline
post #387 of 1139 Old 06-11-2013, 04:21 PM
NWCgrad's Avatar
Quoted: 1249 Post(s)
Liked: 1265
^^^Parts Express shows they are sold out of the 4 cu ft flatpack for the Dayton, looks like a lot of people are going the flatpack/dayton route! Great to have such easy way for people with the time or tools to still do DIY (ie AIY as I have seen it described here). This is a great thing....(not the sold out part, rather the creation of the flashbacks).
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #388 of 1139 Old 06-11-2013, 07:10 PM - Thread Starter
Erich H's Avatar
Liked: 1793
They're sold out because the woofer was sold out even before I took them the boxes. I didn't take them very many to start things off.
Erich H is offline
post #389 of 1139 Old 06-12-2013, 01:07 AM
aspd's Avatar
Stereo Integrity should start shipment of the HT 18 D2 and D4's today if everything goes as planned (read on another forum), really looking forward to receiving two of them myself! smile.gif
aspd is offline
post #390 of 1139 Old 06-13-2013, 08:39 AM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
Very cool to see the flat packs on Parts Express.
I measured the clearance I have last night to try to build myself a MTM alchemy center.... just under 10". Sucks.
bhazard is offline
