New Peavey IPR Amp lineup - 5000 and 7500 model - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #271 of 278 Old 10-13-2015, 10:30 PM
zeus33's Avatar
Quoted: 1528 Post(s)
Liked: 1380
Hey Luke,
What was the difference between your recent test and the previous one mentioned below that you mention that the "7.5 lives up to it's specifications". Obviously, this time around the 7.5 was only half of it's rated power, so it didn't meet the specs.
Thanks for the info.
Originally Posted by lukeamdman View Post
FYI - I did some basic output testing of the Crest Pro-Lite 7.5. A 2ohm load with one channel driven and also in stereo.
http://data-bass.ipbhost.com/index.p...plifier-tests/
All my testing between the Crest 7.5, cc4000/cc5500, and the sp2-12k indicates the 7.5 lives up to its specifications.
In 4ohm stereo, the difference between the 7.5 ($800) and the sp2-12k ($3,400) was almost exactly 3db in favor of the sp2. Not bad at all considering the price and also that the 7.5 was running 120v compared to 240v of the SP2.
zeus33 is offline
post #272 of 278 Old 10-14-2015, 07:00 AM
lukeamdman's Avatar
Quoted: 1208 Post(s)
Liked: 1471
Originally Posted by zeus33 View Post
Hey Luke,
The difference was 2ohm stereo vs 4ohm stereo.
I knew going in that the 7.5 wasn't going to reach rated power in 2ohm stereo based on other owners experiences with the amp.
However, I'm going to run the test again at 4ohm stereo and I have no doubt it'll meet specs.
lukeamdman is offline
post #273 of 278 Old 10-14-2015, 09:31 AM
zeus33's Avatar
Liked: 1380
Thanks Luke. It looks like you need to stick with a CC if you want to run 2 ohm loads.
zeus33 is offline
post #274 of 278 Old 02-23-2016, 04:44 PM
tsloms's Avatar
Quoted: 55 Post(s)
Liked: 60
I've pushed my 7500 very hard with a quad of SI18's and have never been able to shut it down. I ensure that I'm not too far into clipping though. Maybe I'm not pushing hard enough? Is this only running sine waves at single digit frequencies or something?
tsloms is offline
post #275 of 278 Old 02-24-2016, 08:18 AM
Point Source
beastaudio's Avatar
Quoted: 4003 Post(s)
Liked: 3308
2 ohm stereo load is what does it. You have no warning like you do at 4ohm when you start to see the lights flicker and can back off a shade. With 2 ohm stereo, it is fine one second, then the channels shut down the next. It's pretty instantaneous.
FS: BossoBass A-14K amplifier
beastaudio is online now
post #276 of 278 Old 02-24-2016, 08:49 AM
brian6751's Avatar
Quoted: 1083 Post(s)
Liked: 1077
Im hoping quad UM18's will be a good match since they dont really get down to 4 ohms a piece till 5hz. Well into system signal roll off territory. That should keep it just over 2 ohms per channel most of the time. We shall see
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #277 of 278 Old 02-24-2016, 09:33 AM
Point Source
beastaudio's Avatar
Liked: 3308
I think you'll be just fine there. One of these is a pretty solid match for 4 um18's. I do have one for sale in the classys ya know
post #278 of 278 Old 02-24-2016, 09:43 AM
brian6751's Avatar
Liked: 1077
if I didnt have one already i would grab it. I know its been field tested!
Rivers Edge Theater
Peavey Ipr2 7500 Power Amplifier 7500 Watts
