New Peavey IPR Amp lineup - 5000 and 7500 model - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
Old 06-24-2014, 01:13 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Originally Posted by pdxrealtor View Post
^^ DW - you're reducing 4db of signal at the outputs of the Minidsp. Same thing, for this conversation, as reducing four db at the sub trim or MV.
I can reduce 3 db on my sub trim and problem solved, or reduce my shelf filter, or turn down my MV or...
Well, kinda sorta.......
XT32 in Marantz can not reduce sub output to appropriate levels........-12.5 db's is all she can do. Once calibrated....so I thought...... subs were still too hot by 4-5 db's. My only alternative was to lower level in Mini which worked magnificently! Re-ran XT32 which set front subs to -12 and rear subs to -8.5 db's..........distance in wiring back is more than double compared to front which makes sense on XT32 calibration. Re-ran REW sweeps at 0 level on Marantz and was ruler flat at 115db's. Plugged in a few scenes I'm familiar with and sound was incredible........for like 5 minutes until I lowered volume down to my listening levels.
I'll take flat down to 8 Hz at 115 db's which was my end goal. No reason for me to go beyond those limits..........suffice to say, my 7500 powers my four UXL's just fine in 2 ohm load. How long is does so is my only real question.
doublewing11 is offline
Old 06-24-2014, 01:41 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Pretty sure that reducing the output of the mini reduces the boost before it exits the DAC. To get full boost applied in the output stage you'd need to reduce gain at the input and that reduction will take place just after the ADC, but before the boost is applied.
Not saying you still wouldn't not shut down, but you'd certainly be getting all of your boost that way.
*Edit* Also not bugging you to do it - if you're happy that's the point!
I know your amp, and any other Peavey IPR2 will shut down with a 2 ohm nominal load if enough power is demanded from the power supply.
pdxrealtor is offline
Old 06-26-2014, 05:30 PM
Archaea's Avatar
Quoted: 2845 Post(s)
Liked: 2427
This is offtopic - but not really in the discussion of really eeeking every last drop of performance out of these powerful amps. I spoke with Tech Support for Cerwin Vega and asked if they thought it would be okay to run the Cerwin Vega CV-5000 amp with four subs per channel with a combined load of 1 ohm per channel for home theater use (four subs off each of two channels - eight subs total). We talked over my gear, my plan and while he acted surprised that I was doing a setup like this for home theater use - he said absolutely I could run the Cerwin Vega CV-5000 at 1 ohm per channel for home theater use. He said the Cerwin Vega amp is virtually indestructable and it would get hot and shut down before I damaged it - stating the amp is designed for huge venues and designed to be run much harder and longer than the typical home theater would ever see. I also confirmed the amp could be run off household 240 volt power by toggling the switch on the back as well. I have a oven range 8 gauge power wire with a 40 amp circuit unused and run to my theater room already. I'll probably give this option of running all eight subs off one amp on 240 volt power a shot. Hey why not? If it doesn't work, or doesn't get loud enough before shutting down, I can go back to my other plan of running four Ultimax drivers of the Cerwin Vega at bridged four ohm, and four Ultimax drivers off the Crown XLS-5000 at bridged four ohm. I'm still waiting on testing feedback on the iNuke DSP 12,000 and the Peavy IPR 7500 from Brian at speakerpower as well that buckamdman has setup. If those turn out better - then I'll just sell my Crown and Cerwin Vega 5000 watt amps and go with those instead.
saginawjuggalo likes this.
Archaea is offline
Old 06-26-2014, 06:04 PM
chrapladm's Avatar
Quoted: 825 Post(s)
Liked: 286
CV techs have kinda been hit or miss on things they have to said in the past. BUT that being said if your willing to test this idea that would be great for the rest of us to know. Also for those that use these in pro audio I wonder how hard they are pushing them?
There are quite a few people on here that push amps harder that some pro audio applications.
chrapladm is offline
Old 06-26-2014, 07:14 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Since you already have the amp - hell yes give it a shot. I would say for ANY amp that will run low ohms until thermal shut down it's worth a shot.
It will depend on amp and load demand. As much as I like the Peavey amps and all that comes with them, in a way, they fall short of their two ohm rating due to the power supply limitation.
Ill bet anyone an amplifier that the ipr2 7500 will outperform the inuke 12k by a gaziliion in a 'big picture' shoot out. Maybe even just in output power.
Old 06-28-2014, 10:25 PM
Quoted: 93 Post(s)
Liked: 30
What does an ipr 3000 put out in bridged mode? Really 3,000 and can it sustain it?
cellarnoise is online now
Old 07-05-2014, 03:40 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
I would bet it could considering the specs on the larger models still stick pretty close to the true ratings.
beastaudio is offline
Old 08-02-2014, 04:48 PM
Archaea's Avatar
Liked: 2427
heeheh - re-reading this thread and chuckling. I've been in my theater room all day and listening to Pandora shuffle. I went back in my equipment room and felt the back of the Crown XLS-5000 in one particularly bass heavy song. Warm air? First time I've felt warm air blowing out the Crown XLS-5000. Clip lights were tickling with each heavy bass hit. My lights were dimming in the basement even with two dedicated 20 amp circuits run to my equipment rack. (The Crown XLS-5000 is on it's own dedicated 20amp line, and my Sherbourn 7-350 and AVR/other equipment is on the other one). I love my pair of JTR ported captivators - they are effortless -- even after hours of pounding! To your point - I doubt many pro audio applications run their pro amps at 2ohm stereo for hours on end to that level --- but it's nice to have quality gear (Crown XLS-5000, Sherbourn 7-350, JTR speakers and subs) that doesn't even strain when you are enjoying it. A couple years ago I had a fan modded EP4000 and was playing it to the point of clipping at 2 ohm stereo the caps and it bellied up - the Crown is a far superior product and I've no question on its reliability. I'm pretty darn pleased with my whole setup at this point in time. My eight ultimax 18" drivers should arrive mid this week. I'll get to play with the JTR powerhouse ported vs the eight budget sealed going forward and just wearing a smile thinking about it!
Going to compare the three amps I have - iNuke DSP 6000, to Crown XLS-5000, to Cerwin Vega CV-5000 amps on the sealed subs in the next few weeks.
Archaea is offline
Old 08-02-2014, 07:47 PM
Point Source
beastaudio's Avatar
Liked: 2826
I would just about ship you my crest 7.5 or peavey 7500 to join the ranks of testing if you really wanted to Lemme know I am just now in the process of seeing how they each do with just a single channel running as I kept shutting down both running each channel at a 2 ohm load. Power supply stuffs. I will have more possibly on this later this evening, but if not, definitely tomorrow.
Old 08-02-2014, 08:04 PM
Archaea's Avatar
Liked: 2427
That could be cool! Are you not using either of them right now? What are you using instead?
Archaea is offline
Old 08-02-2014, 08:08 PM
Point Source
beastaudio's Avatar
Liked: 2826
I am actually using both now. I was just running the crest but I am trying to see how much better it does just running one channel of each at 2ohm, instead of all 8 on the single amp, 4 per side at 2 ohm...
Old 08-02-2014, 08:19 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
^^ when I went from two channels to one chennel per amp not only did I avoid the shut downs the subs sound noticably better at and just prior to clipping. WOTW type scenes at refernce.
Old 08-02-2014, 08:41 PM
Point Source
beastaudio's Avatar
Liked: 2826
I can already tell I get substantially better sound out of doing it this way. One note, I have the crest gain at 12:00 and to level match with the subs on the peavey, I am actually a little closer to 1:30. Could be differences in the gain knobs, moreso than differences in the amps methinks, but something to keep in mind for those that would do the same type setup....
Old 08-02-2014, 08:53 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Isn't it amazing how much better it sounds? And articulate. Play some heavy material and you can actually see the cones having more control vs. two channels driven.
If you are level matching wouldn't you expect one gain to be different from the other?
Or are you talking about gain matching?
Old 08-02-2014, 09:12 PM
Point Source
beastaudio's Avatar
Liked: 2826
The boxes are identically placed in each corner left and right. I plan to measure the response between each and the combo maybe tomorrow am, but so far, I am finally seeing the clear benefit of the crest over the peavey. I have been able to still kill the channel of the peavey and the crest keeps rocking. No issues at all. Even dropping the gain down 3dB on the peavey, it still gives up the goat around the same time of the track I was running it on. I don't know if switching to channel B would change anything but I might try that just for fun.
Old 08-02-2014, 09:22 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Intersting. JD told me flat out the crest would not solve the shut down problem.
Even more interesting is you are shutting down on only one channel driven.
They both use the same power supply i think, amongst most other parts.
There's more aesthetic differences than hardware....
Ya know, when I got the one amp back from peavey they had made a couple corrections that resulted in the amp now shutting off before the other four I have. Before I sent it off it shut off at the same time as the rest so whatever they did was wrong. Sent it back a second time and it got a new main board. Haven't had time to test it yet but will soon because i sold one and nees to make sure its up to par.
Maybe your peavey has something going on with it. ??
Old 08-02-2014, 09:24 PM
chrapladm's Avatar
Quoted: 825 Post(s)
Liked: 286
SO Beast your doing exactly the same test on 1 channel of the Peavey and 1 channel of the Crest?
Doesnt the Crest have more Caps or something I dont remember?
Old 08-02-2014, 09:32 PM
Point Source
beastaudio's Avatar
Liked: 2826
The bank of 4 caps on the crest they upped to 1100uF from 600uF in the peavey. Both seem virtually identical inside from what I can tell other than that. The funny part is the crest has it's componentry on the bottom of the box where the peavey has it all mounted above (basically upside down) and the front plates are backwards from each other. Not sure what drove them to do it this way, but the difference it would make I guess is null...
Old 08-02-2014, 09:40 PM
chrapladm's Avatar
Quoted: 825 Post(s)
Liked: 286
Maybe Peavey had a OEM client that wanted to add a few things to the design and used specifically the Peavey amps. I havent a clue and just guessing. I dont think Danley would care how the boards were positioned so long as it worked properly.
Old 08-02-2014, 09:44 PM
Point Source
beastaudio's Avatar
Liked: 2826
Danley? I don't think Danley had anything to do with it from the getgo! Haha. Just messing with you man
Old 08-03-2014, 10:18 AM
Point Source
beastaudio's Avatar
Liked: 2826
Well, ran through all kinds of material last night. Ears a little raw this afternoon actually Anyways, I managed to still thermal both amps, but the weird thing was I never did it at the same time. Some scenes would shut down the crest, others would shut down the peavey. WoTW didn't actually shut down either as a matter of fact. I guess next thing to do is go to 4 ohm stereo on each amp. I never had issues previously running this way, and it appears the wattage is still about the same so that is good... Definitely strange findings though...
Old 08-03-2014, 11:37 AM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Man you must have been jamming.....
Maybe your SI are dipping below two ohms.
Old 08-03-2014, 11:44 AM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
B- We POUNDED on my peaveys for several hours yesterday, including some crazy electronic stuff that Mark and Austin wanted to jam to. As you know I'm running them in 4 ohms and even with the DDTs glowing solid at times, I had no issues at all. No tripped breakers, no shutdowns, etc during sustained low hits in the +10 volume range running quite a bit hot. On the 30A line I'm even sharing the line with the inuke 6000, although that amp wasn't drven as hard since it was driving nearfield subs.
Gorilla83 is offline
Old 08-03-2014, 12:55 PM
Point Source
beastaudio's Avatar
Liked: 2826
Could be, still it surprises me generally that the issue almost alternated between scenes. When I jam, though, I can tend to scare most people.
Yep, I am sure they got a little warm to the touch after yesterday haha. I owe you a callback and will do so soon.
Old 08-03-2014, 02:31 PM
95bat's Avatar
Quoted: 24 Post(s)
Just wanted to say thank you to you guys updating this thread. I've been reading it from day one and following along with the progress of these amps I've got my eye on the Peavey/Crest 7.5 for sub duty and this information has been very valuable!
95bat is offline
Old 10-20-2014, 07:35 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Anyone who has owned the IPR2 7500 DSP for a while how has it held up for you? I was thinking about picking on up in place of a couple inuke6k's
lemonslush is offline
Old 10-20-2014, 08:25 AM
Point Source
beastaudio's Avatar
Liked: 2826
If you are needing the DSP, the inuke's is much better, if you are just putting a single filter or whatever on it. You already own the inukes?
Old 10-20-2014, 09:07 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Yea I own a few 2 3ks and 1 6k at the moment all DSP. I sadly dont have a minidsp yet and would probably pick one up if I added another amp. The inukes push the ht18's great and I could give them less wattage and still be happy. I found a peavey 7500 for $680 used. Figured it was cheaper than picking up two inuke6ks even at a discount. I could also sell off a amp or two in place of the peavey and just run it at a lower ohm rating for a cleaner signal. But, in my head I know I would want to get enough subs to power both channels @2ohms. With those B stock SI's its hard to pass up.
I am in no rush, cant buy anything else this month, would have to wait until Nov.
Old 10-20-2014, 09:15 AM
Point Source
beastaudio's Avatar
Liked: 2826
You should be able to find a new one for around that price. There is a guy on ebay that sells them around that price and offers one day shipping for free. I am running mine at 2 ohm stereo (four SI's per channel) and it has some troubles with the absolute most demanding scenes. There were no issues at 4 ohm stereo. I don't know what the 6k has actually measured in output, but if the specs are close, they peavey won't offer you enough additional wattage to validate a trade-out...They really should be pretty similar in output.
Old 10-20-2014, 09:19 AM
Archaea's Avatar
Liked: 2427
iNuke DSP 6000 puts out between 1800 and 2100 in solid wattage per channel according to the tests I've seen at 4ohm. It won't do 2 ohm per channel. It seems to do 3ohm okay.
Archaea is offline
Peavey Ipr2 7500 Power Amplifier 7500 Watts
