New Peavey IPR Amp lineup - 5000 and 7500 model - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #1 of 278 Old 12-14-2011, 06:43 PM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Any thoughts up the 2012 upcoming IPR amps?
http://peavey.com/products/proaudio/poweramps/ipr/
If the 5000/7500 series are even close to legit, it would set forth a remarkable value for those of us with passive subs.
I imagine the 6lb unpacked weight for the 7500 is a typo considering the 1600 is 9lbs.
Gorilla83 is offline
post #2 of 278 Old 12-14-2011, 07:05 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
The IPR 7500 DSP Power Amp boasts 3,750 watts RMS per channel at 4 ohms. Featuring 2 channel independent fourth order Linkwitz-Riley crossovers, a variable-speed fan housed in a lightweight aluminum chassis, DDT speaker protection, and the revolutionary new IPR class D topology.
.... all in one FUGLY case!
Wasn't there an IPR6000 at some point??
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #3 of 278 Old 12-14-2011, 07:10 PM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Another typo found - they claim 3750/channel at 4 ohm on the DSP model's main ad, when the non-dsp says the same @ 2 ohms. Hopefully their efforts are focused on getting the amp out the door and not updating the site.
I'm not a huge fan of the looks either, but this thing can be hot pink and I'll still rock it proudly if it puts out those numbers at that price, heh.
I don't think the IPR6000 ever came to fruition. Hopefully this one actually does. A few sites claim they will be in stock the week of January 11th. If that's true, I'll probably be ordering one to play with.
post #4 of 278 Old 12-14-2011, 07:53 PM
kouack's Avatar
Vaporware
Warning to prevent risk of injuries, you should always be smarter than the equipment you are about to use.
kouack is offline
post #5 of 278 Old 12-15-2011, 03:58 AM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Originally Posted by kouack View Post
Vaporware
I'm *hoping* that's not the case this time around. . The expected ship date at pro audio states January 11th which isn't too far off so I guess we will see soon enough.
post #6 of 278 Old 12-15-2011, 07:49 PM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Couldn't really find a ton of info on the ipr 3000 - anyone using one?
post #7 of 278 Old 12-15-2011, 10:16 PM
kouack's Avatar
Just go on peavey forum many people are happy with their ipr 3000
kouack is offline
post #8 of 278 Old 12-16-2011, 05:13 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Thought it rolled off at 16hz or something along those lines and required a tweak? Was it Noah that bought one and figured that out? Can't recall...
pbc is offline
post #9 of 278 Old 12-16-2011, 10:56 AM
noah katz's Avatar
Quoted: 1100 Post(s)
Liked: 381
There was a component change between when the 3000's rolloff was first discussed and early (or maybe any) production models that made it down only a dB or two at 10 Hz, and I measured rated full power at that freq.
noah katz is offline
post #10 of 278 Old 12-16-2011, 11:05 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Thanks Noah.... thought I recalled something about a roll off.
pbc is offline
post #11 of 278 Old 12-20-2011, 07:22 AM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Good to know - I had read a 'rumor' of this, but good to see it's been confirmed.
Really hoping the 7500 will release sometime soon. Hopefully there is a way to disable those blue led's, heh.
post #12 of 278 Old 12-20-2011, 07:38 AM
coctostan's Avatar
Liked: 142
Is this also true for the DSP units? Did you post your measurements?
coctostan is offline
post #13 of 278 Old 12-20-2011, 10:51 AM
noah katz's Avatar
Liked: 381
Dunno, but I assume the amp sections are the same.
Yes, such as they were, in the big IPR thread.
post #14 of 278 Old 12-20-2011, 01:57 PM
coctostan's Avatar
Liked: 142
Cool, I'll check them out thanks.
post #15 of 278 Old 01-20-2012, 09:07 AM
chmedly's Avatar
And 17" deep? (according to the spec sheet on Peavey.com)
chmedly is offline
post #16 of 278 Old 01-29-2012, 04:18 PM
john lutz's Avatar
Look at the Peavey power amp forum. When asked about all the delays in delivering the higher power IPRs to market, all you will hear is the same answer -quantity and quality parts availability. ?????????
Must be some real special hard to make parts to force a big player like Peavey to wait for 2+ years
john lutz is offline
post #17 of 278 Old 01-29-2012, 04:34 PM
kouack's Avatar
or wait for berhinger to do some R&D heehee ?
kouack is offline
post #18 of 278 Old 01-29-2012, 04:41 PM
LTD02's Avatar
Quoted: 2530 Post(s)
Liked: 2872
"...and I measured rated full power at that freq."
what method did you use noah?
Listen. It's All Good.
LTD02 is offline
post #19 of 278 Old 01-29-2012, 05:06 PM
noah katz's Avatar
Liked: 381
I'll answer you here if you answer me in the OM thread
post #20 of 278 Old 01-29-2012, 05:23 PM
Archaea's Avatar
Quoted: 3082 Post(s)
Liked: 2706
I believe the new timeline sets summer as street release date for the new IPR series. Gorilla83 got that from one of the resellers.
That delay made made my mind up to jump on the uniquesquared deal for the Crown XLS5000 for $550.
Archaea is offline
post #21 of 278 Old 01-30-2012, 01:58 PM
beastaudio's Avatar
Quoted: 4122 Post(s)
Liked: 3462
that is one heck of a deal! what do you do to get it to $550?
beastaudio is offline
post #22 of 278 Old 01-30-2012, 02:36 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Looks like it's regular $599...
http://www.uniquesquared.com/crown-x...at-8-ohms.html
pbc is offline
post #23 of 278 Old 01-30-2012, 02:45 PM
Archaea's Avatar
Liked: 2706
They had a deal for $530ish
http://slickdeals.net/f/3743320-Crow...ped-Half-Price
The 10% off coupon for new members is now dead.
A couple weeks back they had a "make an offer" button.
I offered ~$530 they countered with $575. After playing back and forth a couple times they took $550.
If you e-mailed them and offered them $550 they might take it again, since they took my offer.
The ones at UniqueSquared are manufactured in 2008, so new old stock. (at least both Gorilla's and mine were 2008 manufacture date.)
Archaea is offline
post #24 of 278 Old 02-01-2012, 11:00 AM
beastaudio's Avatar
Liked: 3462
they havent produced the 5000 since 2008, it is not on their main website anymore, its a backlogged product, still a good deal, might just have to scoop one.
post #25 of 278 Old 02-01-2012, 01:11 PM
Quoted: 995 Post(s)
Liked: 523
We'll see if/when they get here, but one thing people should consider is that they're they're going to have much higher input sensitivity than the IPR1600 and 3000. Peavey's lead amp designer wrote the following on the Peavey forum:
Originally Posted by JD View Post
***The non-DSP 1600 and 3000 are both calibrated for 0dBu, which is approximately 0.77459667 volts in for the rated four ohm power. This makes the gain different per model, x75 for the 3000 & 60 for the 1600.
The higher powered models go back to the x40 gain standard. ***
We are still unresolved as to what the gain should be for the DSP models. Headroom versus S/N is the consideration.
Source
Not really a worry, just something to think about. I bet there will be a few "my IPR 3000 sounds louder than my IPR 7500" threads if the bigger ones ever get released.
The IPR-based product that's more interesting to me (and also equally vaporware at this point) is the Crest ProLite line. Mostly because it takes the same technology but puts it in a more visually appealing package.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #26 of 278 Old 02-01-2012, 06:58 PM
noah katz's Avatar
Liked: 381
I think you mean lower - gain of 40 is lower than 75
post #27 of 278 Old 02-02-2012, 03:55 AM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
When I talked to crown tech, they said they technically still consider it a current/supported model, but have stopped producing it. He also mentioned the closest model would now be something in the xti-6000 series.
post #28 of 278 Old 02-02-2012, 03:57 AM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
I wouldn't wait too long. Their eBay stock is down to one unit and they since noted stock is getting lower on their site. FYI.
post #29 of 278 Old 02-02-2012, 07:10 AM
beastaudio's Avatar
Liked: 3462
Good thing mine will be there today
post #30 of 278 Old 02-02-2012, 08:31 AM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Excellent. Using for subs I assume?
Peavey Ipr2 7500 Power Amplifier 7500 Watts
