LMS 5400 - Curved Cabinet Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 51 Old 05-28-2012, 12:13 PM - Thread Starter
NateTTU's Avatar
I finally got to work on this project over the past few days and made some great progress. I suspect my dad and I won't finish until maybe next weekend, but so far things are going well. I'll post pics in a day or so.
I did have one general question to ask whether I should stuff the box with poly fill or not. The volume is about 3.5 cubic feet. If I do stuff the box should I do something to prevent the poly fill from hitting the cone or suspension or block the vent pole during operation or is it not that big of deal?
NateTTU is offline
post #32 of 51 Old 05-29-2012, 08:07 PM
Warpdrv's Avatar
Couple of pillows stuffed in mine...
Gives ya the ability to shape and contain the fibers from pole - my box is 3.0 Cu Ft
Warpdrv is offline
post #33 of 51 Old 05-30-2012, 10:28 AM - Thread Starter
NateTTU's Avatar
Thanks Warp.
Here is a picture, sorry for the bad quality. I can upload some more progress pics later.
Thanks to Nathan from Funky Waves for the CNCed parts. That birch plywood he has is some great stuff. Much better than what I can find locally around here. I still need to add the solid walnut inlay for the corner roundovers and apply the veneer, but hopefully that won't take more than another weekend. This was our first attempt at a curved cabinet and it really wasn't too bad. Definitely worth the extra effort I think.
NateTTU is offline
post #34 of 51 Old 05-30-2012, 11:22 AM
Tankramer's Avatar
Nate,
Can you post some pictures when you get to the roundovers. It would be really helpful to me. I can't figure out the process to get the solid wood to bend with the radius? Kerf cuts? I don't know but I am curious to see your method. I like the build btw, nice choice
Tankramer is offline
post #35 of 51 Old 05-30-2012, 08:00 PM - Thread Starter
NateTTU's Avatar
I'll try to take some pictures. You don't actually bend the hardwood to fit the curve or corners. The front and back pieces are just straight pieces with a miter cut at each end. The curves are cut from a larger chunk to fit the box and also mitered at the ends to mate up with the front and back pieces. Just glue them on and trim them flush.
BTW, in this particular build make sure to cut the perimeter out before making any corner radii to the box and then apply the veneer before the hardwood pieces.
NateTTU is offline
post #36 of 51 Old 05-31-2012, 09:44 AM
Tankramer's Avatar
Thanks nate.
Sometimes the answer is so simple. I thought if a few possible workarounds but the proper one flew right past me. Thanks again and looking toward to seeing your progress.
post #37 of 51 Old 07-18-2012, 07:01 PM - Thread Starter
NateTTU's Avatar
I'm considering picking up a balanced minidsp to use with the dual LMS setup. Can I get by with just the Audyssey mic that came with the receiver, copy of REW, and a laptop with mic input? What extra plug-ins would I need to get to EQ and setup a height pass filter?
NateTTU is offline
post #38 of 51 Old 07-20-2012, 06:58 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
I know I could never get my Audyssey Mic to work on my laptop. Plus, you never really know how accurate the mic is or isn't. For $75, I'd pick up one of these ..
http://www.cross-spectrum.com/measurement/calibrated_dayton.html
and have it calibrated to 5hz. Throw in a soundcard with phantom power (Mobile Pre USB can probably be found for $80 or so on ebay) and a few cheap connectors and you're golden. Plus you know the mic is accurate.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #39 of 51 Old 07-20-2012, 06:58 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
BTW, where are the pics of the finished subs?!
pbc is offline
post #40 of 51 Old 07-21-2012, 04:40 PM - Thread Starter
NateTTU's Avatar
Thanks PBC, I may also look into the Omnimic since I have heard lots of good things about that.
I will get some more pics of them shortly. Unfortunately still not quite finished though.
NateTTU is offline
post #41 of 51 Old 07-21-2012, 07:10 PM
popalock's Avatar
Quoted: 1291 Post(s)
Liked: 1805
If I were you I would go that route... I tried to set up everything to run REW, but got ridiculoisly irritated when it came to the soundcard on my laptop. I've heard a lot of good things about Omnimic as well. Haven't made the dive yet though.
popalock is offline
post #42 of 51 Old 08-06-2012, 10:42 AM - Thread Starter
NateTTU's Avatar
Here are some new pics of what we accomplished over the weekend. Still need to trim the top flush and then the roundovers will be next. After that all I need to do is stain and finish the box. We probably won't get a chance to work on it again for another couple of weeks though. Sub 2(1).JPG 242k .JPG file Sub 4.JPG 237k .JPG file
ID:	62852   Click image for larger version
NateTTU is offline
post #43 of 51 Old 08-06-2012, 01:37 PM
popalock's Avatar
Liked: 1805
Couple of weeks? Man, when are you going to be able to enjoy the fruits of your labor?
My Ultras have been sitting in my HT for 3 days now and I'm about to have a fit if I don't throw something together for them soon!
popalock is offline
post #44 of 51 Old 08-06-2012, 03:07 PM - Thread Starter
NateTTU's Avatar
I'm certainly ready to get them back in the HT. I've been subless for at least three months. It's just difficult for me to schedule time to work on the cabinets.
NateTTU is offline
post #45 of 51 Old 09-04-2012, 09:58 AM - Thread Starter
NateTTU's Avatar
I'm finally getting these back in the HT and just had a quick question. Does everyone use gasket tape/weather stripping prior to installing the driver or is the rubber sleeve around the driver suppose to be sufficient to seal the enclosure?
NateTTU is offline
post #46 of 51 Old 09-04-2012, 10:30 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
I picked up this tip from Bossobass a long time ago.
Take off the rubber sleeve and use gasket tape to ensure a better seal. I personally use this as it has good adhesion and forms a nice tight seal: http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-542
I just recently used the rubber sleeve as it was only a test and didn't want to to through the trouble of using up gasket tape for a test enclosure. I listened for a bit and could tell I was getting some air leakage, removed the rubber gasket, applied the gasket tape and re-installed. The difference in performance was easily noticed and no more slight sound of an air leak that I had with the rubber gasket.
Bosso told me that all those rubber gaskets leak, after testing that out my-self he is right.
mjaudio is offline
post #47 of 51 Old 09-04-2012, 11:13 AM
popalock's Avatar
Liked: 1805
+1.
It's a nice pointless accessory that the Ultra could do without... Maybe lower the sale price by $20... smile.gif
I mounted my sub with the sleve on and I felt like the worst box builder ever as soon as my box started farting at me...
popalock is offline
post #48 of 51 Old 09-04-2012, 11:38 AM
beastaudio's Avatar
Quoted: 4103 Post(s)
Liked: 3424
+1.
I had a nice whistle that developed in one of mine, like A perfectly fine high E, no farts but ill agree, any of that stock gasket/foam stuff that comes with a speaker is useless if you want a good seal. Especially the interlocking kind like the RE has. It is worthless.
beastaudio is offline
post #49 of 51 Old 09-04-2012, 01:54 PM - Thread Starter
NateTTU's Avatar
I'll pick up some gasket material at one of the local hardware stores on my way home then. BTW, I actually do like the look of the provided rubber sleeve so could I still use it and install the gasket underneath?
Also, could I use some standard bathroom tile silicone to help seal up the locations where my binding posts are installed? Would that hold up well against the electrical current and not get hot?
NateTTU is offline
post #50 of 51 Old 05-08-2014, 07:30 PM
cape_man's Avatar
If you ever need any advice on laminated plywood builds, let me know.... That's all I do. Yes, tons of work , and waste, but when I do a sub the insides become a main... Beautiful subs by the way.
Grady_white
cape_man is offline
post #51 of 51 Old 05-10-2014, 08:48 AM - Thread Starter
NateTTU's Avatar
Wow this is an old thread. Thanks for the kind words though and I appreciate the offer.
Since this is up here I might as well ask, I've had a recent problem come up with my subs. It seems that I'm getting some really bad interference with my amps. With the amps on and no signal I hear a slight scratching noise coming for the subs. It's loud enough I heard it the other day when sitting on the couch about 8 feet away. I'm not exactly sure when it started, but definetly wasn't there before. Any ideas?
NateTTU is offline
