Kappa Perfect Subwoofer Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 02-16-2012, 05:51 AM
sgallagan's Avatar
Looks great man! Nice work!
sgallagan is offline
post #32 of 44 Old 02-16-2012, 06:52 AM
Archaea's Avatar
Quoted: 2829 Post(s)
Liked: 2416
Good work
Archaea is online now
post #33 of 44 Old 02-16-2012, 02:48 PM - Thread Starter
DankNuggz's Avatar
Thanks dude! It's coming along slowly but surely.
DankNuggz is offline
post #34 of 44 Old 02-16-2012, 02:51 PM - Thread Starter
DankNuggz's Avatar
Good work
I'm waiting for a chance to get it back in the spray room.
Maybe another couple of coats this weekend.
I should be listening to it in a couple weeks.
post #35 of 44 Old 02-16-2012, 04:00 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2572
i don't see any reason why you can't rub that finish out to mirror...if you wish...look'n really good so far.
Listen. It's All Good.
LTD02 is offline
post #36 of 44 Old 02-16-2012, 08:09 PM - Thread Starter
DankNuggz's Avatar
Thanks Man!
I may try that on the amp box or shelves first.
Can you recommend a polish for lacquer based paint?
post #37 of 44 Old 02-22-2012, 07:20 PM - Thread Starter
DankNuggz's Avatar
Got the amp box finished!!!
post #38 of 44 Old 02-27-2012, 04:48 PM - Thread Starter
DankNuggz's Avatar
GOT THE BOX DONE!!!!!!!!!!!!!!!!!!!!!
Overall, I'm impressed with finish, the design, and the sound.
Eventually, I may try some polishing compound to try to mirror the finish a little more.
I've had the sub in a pre-fab Bassworx box 1.65cf tuned to 42hz since I bought the plate amp, and it sounded better than my 10" Cerwin Vega.
Put the sub in the new box, and WOW!! what a difference.
I'm feeling notes that I never knew were there. The SA240 really pushes the sub to its limit.
It doesn't shake the walls down, but its more than enough for my condo.
When I pulled the sub out of the old box, a piece of the trim ring came off. D'oh!
I have a blown Kappa, Does anyone know if I could use the trim ring off of that one for this one? Could this be done easily?
Heres some pics.
post #39 of 44 Old 02-27-2012, 05:01 PM - Thread Starter
DankNuggz's Avatar
Bought a flat screen wall mount from Amazon for $55.
Looks like the ones Best Buy sells for $200-300.
http://www.cheetahmounts.com/product-p/apdam2b.htm
I think my next project is to buy a HTPC case so the computer can go in the entertainment cabinet.--------Built that too a few years ago.
Then I'll build a twin brother for the Kappa.
Can anyone recommend a different subwoofer that would go good with this design?
post #40 of 44 Old 02-27-2012, 07:10 PM
qx56's Avatar
Looks great. What kind of output are you getting down around 20 HZ. That's a big ass box but I guess that's The price you pay to go low.
qx56 is offline
post #41 of 44 Old 03-01-2012, 05:06 AM - Thread Starter
DankNuggz's Avatar
NOOB Question:
I have a Pioneer VSX-920 AVR.
It has a sub pre-out.
Can I hook up say a Behringer ep2500 to power my sub?
Do Pro Audio amps only work with a pre-amp?
post #42 of 44 Old 04-24-2012, 11:16 AM
ILOVEMYHDTV's Avatar
Quoted: 47 Post(s)
Liked: 48
Yes. I just turned on sub 2 on my ACT. An inuke 3000dsp, make sound like a ....
PS3+4= CHiNGOBLiNG = RUBEN...YOU NEED TO OPEN YOUR EYES TO SEE THE PICTURE!!... "SHOE MAKER HOME THEATER".7/22/16....just a KLIPSCH NUT..>7/22/16...2new videos show..https://www.youtube.com/watch?v=jWO0YtCWQxI.....https://www.youtube.com/watch?v=yIen05Wcg9w. u can even look from when I started about to present day.... i stutter sometimes....
ILOVEMYHDTV is offline
post #43 of 44 Old 04-26-2012, 05:10 AM - Thread Starter
DankNuggz's Avatar
Thanks man!
I wish I had a cool graph to show , like all you other guys.
My ears say its pretty flat from around 17hz-70hz.
After listening for a couple months now, I'm wishing that I got a Behringer, and
built something for a 15" or 18".
I hooked up an old Memphis 15" (entry level) sub in a like 1.5cf sealed box,and
it was a whole lot louder---didn't sound as good as the Kappa, but in a different
box I think it would.
I run a Rockford Fosgate T215D2 in my car right now, that I want to use for my home theater.
I've seen people run W7's, XXX's and Sundowns for home theater, but haven't seen a T2 yet.
Does anyone think it would make a good HT sub?
here are the t/s parameters
http://www.rockfordfosgate.com/rftec...ookieSupport=1
post #44 of 44 Old 06-04-2012, 12:03 PM
Archaea's Avatar
Liked: 2416
your ears can't know if you are flat to 17hz. Get some measuring hardware/software
cool project though!
