measuring 2.83 volts at amplifier? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-03-2012, 09:30 AM - Thread Starter
johnbomb's Avatar
Hello everyone,
When determining the SPL of a speaker at 1 meter at this voltage, do I measure the voltage at the amp while inputting a test signal before I hook up the speaker to it, or do I measure the voltage once the speaker is connected and the amp is under load?
John
johnbomb is offline
post #2 of 6 Old 01-03-2012, 09:35 AM
Ricci's Avatar
Quoted: 188 Post(s)
Liked: 489
Measure at the speaker terminals. You can have some voltage drop depending on your wire gauge and how long the cable is. Use a 50 or 60Hz sine wave as that is where volt meters are most accurate.
Ricci is online now
post #3 of 6 Old 01-03-2012, 01:00 PM
DonH50's Avatar
Quoted: 1816 Post(s)
Liked: 1352
^^^ Assuming the speaker looks "nice" at that frequency... Ideally*, you'd use an RMS voltmeter with enough bandwidth to measure a number of points across the audio band. In practice, a spot check at 60 Hz is not unreasonable, although sensitivity is typically measured at 1 kHz. If your speaker's bandwidth does not extend to 60 Hz you may get a misleading result. Of course, you'll also get a misleading result if your DMM does not have 1 kHz AC bandwidth...
Either way, do it under load, as Ricci said. - Don
* Actually, "ideally" you'd use a wideband vector meter system to determine V, I, and power, but those are not cheap.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #4 of 6 Old 01-03-2012, 05:03 PM - Thread Starter
johnbomb's Avatar
johnbomb is offline
post #5 of 6 Old 01-04-2012, 07:58 AM
Ricci's Avatar
Quoted: 188 Post(s)
Liked: 489
Hey Don...I didn't mean that he should measure the SPL at 60hz. I guess it could've been read that way. I meant that should verify that he actually has the 2.8 volts delivered to the speaker that way. Then proceed to measure the speaker after he knows he has the right drive level.
Ricci is online now
post #6 of 6 Old 01-04-2012, 12:18 PM
DonH50's Avatar
Liked: 1352
Ah, I misunderstood, sorry! Makes sense. - Don
