Sampson S-Convert replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 01-13-2012, 05:15 AM - Thread Starter
t6902wf's Avatar
I need to bump the output from a receiver through a Minidsp to a Crown Amp.
I have used a Sampson S-Convert in the past but it has been discontinued.
Is there a cost effective replacement?
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
post #2 of 33 Old 01-13-2012, 05:36 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Good question. It is a nice little box. Look forward to what others say.
JSS
maxmercy is offline
post #3 of 33 Old 01-13-2012, 06:12 AM
cmryan821's Avatar
Quoted: 194 Post(s)
Liked: 59
Rane Balance Buddy B22 could work. Not as cheap as the samson though.
cmryan821 is online now
post #4 of 33 Old 01-13-2012, 06:19 AM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
What receiver are you using? have you tried to increase the receiver's channels' output trim? perhaps you can consider Art cleanbox pro
WereWolf84 is offline
post #5 of 33 Old 01-13-2012, 06:43 AM - Thread Starter
t6902wf's Avatar
That looks like it will do it thanks. Yes I have played with levels and I can not get enough output to fully drive the amp.
T6
t6902wf is offline
post #6 of 33 Old 01-13-2012, 04:43 PM
A9X-308's Avatar
Quoted: 1296 Post(s)
Liked: 959
Search on the cleanbox. I recall reading that it has a rather high LF rolloff.
A9X-308 is offline
post #7 of 33 Old 01-13-2012, 05:17 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1041
I have a modded cleanbox, flat to 5hz using the same parts as the huge thread on Home Theater Shack. I don't use it anymore, $50 shipped if you're interested. It was used with an older sony ES receiver I had to a ep2500.
PM me if you're interested.
N8DOGG is offline
post #8 of 33 Old 01-14-2012, 07:33 AM - Thread Starter
t6902wf's Avatar
What is rather high? I have a high pass at 15hz on this?
T6
t6902wf is offline
post #9 of 33 Old 01-14-2012, 07:39 AM
Quoted: 911 Post(s)
Liked: 490
Why not just get another S-Convert?
I'm sure some of us know where to find a spare one.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #10 of 33 Old 01-14-2012, 08:05 AM
omegaslast's Avatar
Helpful post of the year!!!
omegaslast is offline
post #11 of 33 Old 01-14-2012, 11:18 AM
A9X-308's Avatar
Liked: 959
I don't recall OTTOMH, so you'll need to search. I was simply pointing it out in case it proves to be an issue.
A9X-308 is offline
post #12 of 33 Old 01-14-2012, 11:38 AM - Thread Starter
t6902wf's Avatar
Thanks hopefully I can lay my hands on a used Sampson.
T6
t6902wf is offline
post #13 of 33 Old 01-14-2012, 12:35 PM
Ghani99's Avatar
If you know someone in Canada you can buy and ship a Sampson to them and they could ship it to you since Axe doesn't ship to the U.S.
http://www.axemusic.com/product.asp?...istory=related
Ghani99 is offline
post #14 of 33 Old 01-14-2012, 01:11 PM
Looneybomber's Avatar
Liked: 25
The wink makes me think DS-21 has one, or knows where one can be found, which would make it a helpful post once the two PM each other...Or I could have just been reading in to things.
YID DIY
Looneybomber is offline
post #15 of 33 Old 01-14-2012, 01:25 PM
Quoted: 911 Post(s)
Liked: 490
Originally Posted by Looneybomber View Post
***Or I could have just been reading in to things.
Serious Audio Blog
DS-21 is offline
post #16 of 33 Old 01-14-2012, 01:45 PM
Liked: 25
Well then.
postCount++;
return null;
YID DIY
post #17 of 33 Old 01-14-2012, 01:48 PM
Quoted: 911 Post(s)
Liked: 490
Let's just say I no longer use pro amps (all of my subs are either powered by onboard plate amps, or consumer rack amps with suitably low input sensitivity) but for a while I did.
Serious Audio Blog
DS-21 is offline
post #18 of 33 Old 01-15-2012, 07:47 PM
Muzikal-JRNE's Avatar
Muzikal-JRNE is offline
post #19 of 33 Old 01-15-2012, 08:10 PM
Viperoni's Avatar
Are there any DIY kits for this kinda device? Seems like it shouldnt' be too expensive to build a simple step up box for 1 or 2 channels...
Viperoni is offline
post #20 of 33 Old 01-15-2012, 08:28 PM
spanish68's Avatar
I have a Samson S-Convert if someone is interested. I'm not using it right now. PM me for details.
spanish68 is offline
post #21 of 33 Old 01-15-2012, 11:01 PM
A9X-308's Avatar
Liked: 959
Yes, Rod Elliott has some amongst others. Pick the slope you want to HPF at and download the free calculator (for LR2 and 4) in Project 81. Adjust the gain via the input or output buffer, and only add the LPF section if you need it. Complete LM317/337 based PSU modules are on ebay for about $20 last I looked (built) so add a small transformer and put it in a box. You can even add an LT or parametric EQ if you want.
Most power amps and many line level devices have their 3dB LF point defined by a single series DC blocking cap to give a 6dB/oct roll off.
You could also look at modifying a commercial item like a CX2310 if you can get a schematic. Some of the older Ranes like the AC23 are also good.
A9X-308 is offline
post #22 of 33 Old 01-16-2012, 12:20 AM
DL86's Avatar
I have one of these in my system
http://www.henryeng.com/matchbox.html
Works great and has excellent specs. Although a bit pricey.
To improve the black level performance of your projector: Shine bright light into your eyes every 5 minutes.
DL86 is offline
post #23 of 33 Old 01-16-2012, 02:49 AM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
mic2200
Mrkazador is online now
post #24 of 33 Old 01-16-2012, 11:51 PM
jasonpctech's Avatar
WANTED to buy: RCA input Samson S-convert Bump Box. With Paypal funds to 04015. Must work and have stock power supply.
If you see this rascal approach with caution!
Cuff that goat roper with some bubblewrap then box him up for a one way trip on the pony express for your reward! & send him to.
Sheriff JasonPCtech
I might even deputize you partner
!:whistling:
Don't let the smoke out.
My Theater setup: http://www.avsforum.com/avs-vb/showp...&postcount=373
jasonpctech is offline
post #25 of 33 Old 01-17-2012, 12:16 PM
Point Source
beastaudio's Avatar
Quoted: 3509 Post(s)
Liked: 2831
OK OK OK OK. Ive been trying to work through some other stuff in the theater while all along I have my several signal boosters in the back waiting to all be tested head to head. right now I have the ATI mm100, cleanbox PRO, samson, and matchbox HD, all of which do the same thing, convert from rca to pro level. All of these sans the samson are still pretty easy to find. I WILL TRY MY BEST to run them all through a loopback on REW tonight and post the results if anyone cares to wait a few. Obviously the winning box I shall keep, all others will go up for the first or highest bidder.
beastaudio is online now
post #26 of 33 Old 01-17-2012, 01:03 PM
We got that Cowpuncher, he was hiding in Salt lake City in Poll Sound in his best NIB duds!
Thanks, to all that read my post!
Now gather round the camp fire, here's the story.
I just called,
Andrew Glasmacher
Poll Sound
4026 South Main Street
Salt Lake City, UT 84107
(801) 261-2500 office
(801) 660-8835 mobile
(801) 262-7379 fax
He was a great help sold me the NIB S-Convert box at cost saying because it was the last one for $36+ shipping for a total of $50.
I also told him that Bobdog from this Klipsch forums had seen the box on the shelf in Salt Lake UT.
Te overall experience was great and Andrew made it sound like they were ramping up web sales by changing the site and putting more resources into future internet sales. Give Andrew a call and tell him Bobdog sent you!
So in light of that I will post this info on the sites I did my WTB posts. AVS, HTS & Klipsch.
Thanks to Bobdog & Andrew for the help!
Now we'll have Samson SC hop in the corral with that big bad 1200w 338ltr Sonosub and see if he can make it sing. God help the lil fe
post #27 of 33 Old 01-17-2012, 11:33 PM
Thunderheader's Avatar
I do not want to high-jack this thread but I just purchased one of these today, I am new to Pro Amps, does this handle only one amp at a time? I just purchased 2 Crown XLS-1500's; too; one for the centre channel (bridge-mono) and the other is in (Stereo-Bypass) for the Front L/R, I want to run the front sound-stage with ample headroom based on my taste in fidelity and overkill.
I played around with the Samson S-Convert all night and could not seem to get it right, leading me to believe that it will only run 1 signal at a time from unbalanced to balanced or unbalanced to unbalanced. Again I apologize if this is construed as high-jacking.
I have to edit this, I again went back to the Samson to try and figure it out; alas I am returning it tomorrow. I cannot get it going with even one input/output, I may be doing something completely wrong but I do not think so. Without the Samson in the mix running XLR-RCA from amp to AVR I get sound from the front L/R and centre respectively from the Crown 1500's granted I have to raise the trim a little more. I cannot let this sit, it needs to be addressed...any ideas as to what I am doing wrong???
Thunderheader is offline
post #28 of 33 Old 01-18-2012, 06:19 AM
I look forward to hearing about your findings Beast. Some solid measurement data should take care of the the conjecture we have about these products.
Cheers, Joe
post #29 of 33 Old 01-18-2012, 01:27 PM
Point Source
beastaudio's Avatar
Liked: 2831
not sure what you are doing wrong, but it doesnt matter, you dont need that samson for your mains or center on the xls-1500 since it has RCA inputs on it in the first place! I fiddled an fiddled with my cleanbox inline for my mains until I realized that it was completely unecessary.
With that said, the monoprice xlr-->RCA cables only seem to work about half the time. all three that ive purchased have not worked, and I know of TOO MANY other instances where folks have had the same problem as I. not sure if you are using these anywhere but that it usually problem "A". Problem "B" is using the input RCA and output RCA at the same time, just as in the above paragraph, this really does nothing to help you out. assuming you are going rca cable from AVR to rca input of the samson and then xlr output of samson to xlr input of the crown:
Did you forget to plug the samson in? Dumb question but have to ask
adjust the gain pots on the samson?
What is your subwoofer trim level set on the receiver? try setting it higher
post #30 of 33 Old 01-18-2012, 01:29 PM
Point Source
beastaudio's Avatar
Liked: 2831
Cheers, Joe
Alas, I will get these findings out soon, unfortunately I still have not sat down and run them all yet, and tonight doesnt look too good either but we shall see. I first have to move my subs out and remove the drivers as they will be finding a new home tomorrow Time to start building again!
