axiom tweeter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-15-2012, 01:47 PM - Thread Starter
s002wjh's Avatar
Quoted: 30 Post(s)
ok it seem one of my tweeter die in an axiom m60. after some search i found Dayton Audio DC25T-8 tweeter at part express very similar to axiom tweeter. but i never diy speaker before. is there a guide or something on how to replace/install tweeter? or its simple as wire/solder and replace it?
s002wjh is offline
post #2 of 7 Old 01-15-2012, 01:58 PM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1726
Likely won't work out the same as before. I'd at least change both tweeters, or there will be a tonal imbalance.
Can you get a replacement from axiom.
Ryan
tuxedocivic is online now
post #3 of 7 Old 01-15-2012, 03:43 PM - Thread Starter
s002wjh's Avatar
Quoted: 30 Post(s)
i belief the tweeter is same as axiom. they LOOK exactly the same. of course not 100% sure, i have to contact axiom see how much they charge it.
but for replacement procedure basically just swap and solder??? nothing else
found a thread about dayton audio tweeter and axiom tweeter.
The dayton Ti tweeter is obviously from the same molds and factory. Frankly, I'd be surprised if there was anything different besides the face plate logo. Or course it's possible they spec'd them differently, but I wouldn't bet on it
http://www.diyaudio.com/forums/multi...s-etc-etc.html
s002wjh is offline
post #4 of 7 Old 01-15-2012, 04:57 PM
Steve_Vai_rules's Avatar
You won't know without measurements if they are the same.
It is possible though.
Matt
"The main reason Santa is so jolly is because he knows where all the bad girls live." - George Carlin
Steve_Vai_rules is offline
post #5 of 7 Old 01-15-2012, 05:44 PM - Thread Starter
s002wjh's Avatar
Quoted: 30 Post(s)
Matt
anyway, for replacing it. just swap and solder it? or i need to do something else. is there a guide on how to install/replace speaker?
s002wjh is offline
post #6 of 7 Old 01-15-2012, 06:57 PM
saabracer23's Avatar
Liked: 29
Yes, just swap and solder. Or there may be clips so no solder.
Dan
saabracer23 is offline
post #7 of 7 Old 01-16-2012, 04:31 PM
fredfish's Avatar
Quoted: 25 Post(s)
Axiom manufactures all their drivers in their own facility and have done so for many years. Unless they also manufacture for other companies (highly unlikely) they are not the same.
fredfish is offline
