minidsp box/case thread - AVS Forum
post #1 of 6 Old 01-18-2012, 02:00 PM - Thread Starter
omegaslast's Avatar
For those with a bare minidsp board and want to put it in a case, post your findings here
http://www.parts-express.com/wizards...AT&srchCat=208
http://www.parts-express.com/pe/show...number=320-482
plastic is probably the easiest one to drill through
http://www.par-metal.com/product-rmc-10series.php
10-19082x in black paint with gray handles would look pretty slick
Want to measure your subwoofers? check out my dummies guide for a step by step process to Room EQ wizard
http://polaraudio.blogspot.com/2012/01/calibration.html
omegaslast is offline
post #2 of 6 Old 01-18-2012, 02:22 PM
JackNC's Avatar
right, steel is too hard to drill. have you seen any aluminum case options?
JackNC is offline
post #3 of 6 Old 01-18-2012, 02:48 PM - Thread Starter
omegaslast's Avatar
http://www.parts-express.com/pe/show...number=262-070
http://www.parts-express.com/pe/show...Number=262-078
might be too narrow
post #4 of 6 Old 01-18-2012, 04:22 PM
notnyt's Avatar
Quoted: 73 Post(s)
Liked: 333
notnyt is offline
post #5 of 6 Old 01-18-2012, 04:23 PM
lilmike's Avatar
Liked: 73
I'm still just laying mine on my desk...is that bad?
For a case, I just grabbed a small 1U case from the as-is pile at the local electronics recycler. Used to be an Internet firewall in a past life, but no longer works. It only cost me $3, and has a nice power supply in it already. It is steel, so it's not exactly easy to work with, but I have a pretty well-equipped shop.
I'll post up pics if I ever get it done.
lilmike is offline
post #6 of 6 Old 07-17-2014, 09:49 AM
NicksHitachi's Avatar
Quoted: 37 Post(s)
Liked: 100
I know this is an old thread but I've started my own version FWIW.
DIY Rack Mount Minidsp Balanced 2x4 Enclosure
Don't waste time reading signatures.....
NicksHitachi is online now
User Tag List
