DIY Amp Repair - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-19-2012, 03:01 PM - Thread Starter
mdk2007's Avatar
Hey guys, I recently had some channels go out on my B&K 4430 amp and I wanted to see if there was anyone hear that specialized in amp repair or had some ideas on how to fix them.
I have read through a lot of the forums on amps and I didnt know the best way to go about asking for help so here it is
What is the best way to fix blown channels on different amps? How have you guys fixed them in the past and is there anyone that could possible help (paid of course) to figure out the issues. Thanks for looking!
mdk2007 is offline
post #2 of 8 Old 01-19-2012, 05:48 PM
annjones13's Avatar
This could help me too....
I have a channel out on my Parasound HCA 2003
Ann
annjones13 is offline
post #3 of 8 Old 01-19-2012, 07:25 PM
Nardokor's Avatar
Open case, look for burnt components. Capacitors are a hours place to start as they dry out with age.
Nardokor is offline
post #4 of 8 Old 01-20-2012, 05:41 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
Typically, it is very helpful to start with the service manual for the particular amplifier. Many manufacturers consider their service manual proprietary. To find one, try a large number of Google searches. If a site has the manual, it may cost $15-25.
You need a volt/ohm meter, soldering tool, and solder removing tool. In a very small number of situations, you get lucky and can identify a swollen or burnt capacitor. Capacitors (generally) deteriorate with age and heat.
Repair shops can cost $200-300+ and guarantee their repairs for 30-90 days. The difficulty is that other non-failed parts may be close to failing and fail within a few months of the initial repair. A few individuals have been able to identify an obviously failed capacitor which a repair shop replaced for them cheaply ($10-30).
Contact B&K because they may be able to offer a better deal.
wwinkler is online now
post #5 of 8 Old 01-20-2012, 08:00 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
ATI took over B&K, ATI has a great reputation....
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
post #6 of 8 Old 01-20-2012, 10:15 AM - Thread Starter
mdk2007's Avatar
Well I emailed ATI or B&K and there repair prices were right in line with a local shop so I wanted to put something out here before I spend $300 on an amp that is wort probably 400-500 max. Ill try some of the advice given and go from there!
mdk2007 is offline
post #7 of 8 Old 01-20-2012, 10:54 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
sorry, but i think you're better off in the long run by selling off the amp for whatever you can get and purchase a new unit.
unless there are significant sentimental values for keeping the amp.
smokarz is offline
post #8 of 8 Old 01-20-2012, 12:43 PM
PassingInterest's Avatar
Quoted: 177 Post(s)
Liked: 486
If you haven't done so already, check your Line fuse (12 Amp/250 Volt Slow Blow) and your Rail fuses (6 Amp/250 Volt Slow Blow). It's a good place to start.
PassingInterest is online now
