diy 12 or 15 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-26-2012, 06:27 PM - Thread Starter
qx56's Avatar
I am looking for a diy option that will play well or out do my ED A2 300. The goal is to keep it as cheap as posible must reach 20hz or lower. I have the skills to build the box if i know the volume it would be.
thanks
qx56 is offline
post #2 of 10 Old 01-26-2012, 06:41 PM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
I'm building two Kappa Perfect slot ported subs for a friend of mine.
Using the Kappa 120.9w for $130 shipped. 500 Watt BASH plate amp for $189.
About $50 in lumber. So figure about $370-380 with misc items.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #3 of 10 Old 01-26-2012, 06:54 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
a2 300 list price $1025...lol.
if you have the skills and the space, build one of lilmikes f20 horn loaded subs.
http://larchive.avsforum.com/www.avs....php?t=1329971
Listen. It's All Good.
LTD02 is offline
post #4 of 10 Old 01-26-2012, 07:35 PM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 286
+1
Not sure what you mean by cheap as possible?
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is online now
post #5 of 10 Old 01-26-2012, 09:51 PM - Thread Starter
qx56's Avatar
Just looking for ideas. Hope to stay around ,250 for sub and amp
qx56 is offline
post #6 of 10 Old 01-26-2012, 10:25 PM
LTD02's Avatar
Liked: 2578
is an f20 within your build capacity?
LTD02 is offline
post #7 of 10 Old 01-26-2012, 10:35 PM - Thread Starter
qx56's Avatar
Yes. I built my whole theater from ground up. But that thing is a little big check out my theater thread and you will see under the screen I have 2 and a half feet wide by 21 tall by 22 deep so I have to stay within those outside dementions. Thanks for the ideas.
qx56 is offline
post #8 of 10 Old 01-29-2012, 11:36 PM - Thread Starter
qx56's Avatar
Any other ideas ?
qx56 is offline
post #9 of 10 Old 01-30-2012, 06:47 AM
mayhem13's Avatar
Quoted: 44 Post(s)
Liked: 29
You won't out do the eD and extend below 20hz within your budget. Sorry. I would suggest supplementing the eD sub with a sealed sub whose primary function is 40hz and below. Combined with the roll off of the eD you should wind up with usefull response into the teens. But driving low frequency sealed subs requires power and the amplifier alone will gobble up your budget. If you can extend your budget a bit, I can help.
mayhem13 is offline
post #10 of 10 Old 01-30-2012, 09:48 AM - Thread Starter
qx56's Avatar
Im all ears. Thanks for the help.
qx56 is offline
