So...I have a couple of good 55A DC supplies and a couple car audio amps - AVS Forum | Home Theater Discussions And Reviews
Old 01-28-2012, 08:35 PM - Thread Starter
mcsoul's Avatar
Quoted: 16 Post(s)
Has anyone tried to use car audio amps and a DC supply for a home subwoofer setup? I have 2 55A supplies that can be bridged for 110A.
I'm leaning towards trying to use one supply on a 100wpc car amp (older sound stream) that will bridge to 400w at 4ohms.
I don't know, it sounds like fun and I want a new cheap project. Now I need to find a well priced new or used 15" or 18" sub. I have all the wood and saws I would need. Maybe the Dayton 18" classic 4ohm svc. I could always design the project so that the car audio can be easily replaced with a plate amp.
mcsoul is offline
Old 01-28-2012, 08:54 PM
Looneybomber's Avatar
Liked: 25
It'll work. No kidding, I used a car battery and a charger to power my mtx2300x and18" JL in my dorm room for an entire semester. I say try it since you have it. You can always buy an AC amp later.
YID DIY
Looneybomber is offline
Old 01-29-2012, 12:51 AM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
You can also power car audio with pc power supplies.
Mrkazador is offline
Old 01-29-2012, 11:39 AM
MoFinWiley's Avatar
I am using a server class PC power supply to power a car amp for my 21" mal. It does the job while I save for a lg clone.
MoFinWiley is offline
Old 01-29-2012, 12:03 PM
DiscoDuck's Avatar
Quoted: 14 Post(s)
Sounds like a great idea. I bet many of the parts in a plate are similar to the amp boards found in car stereos. I have a car amp I may try with with a pc power supply. It is labeled to output 18a at 12v and the amp has a 20a fuse in it.
Sr7009 + external amp for 9.3.4
jbl - northridge x11; sp6cii ceiling
Dayton HF15 sealed x2 on xls1500
av123 mfw15 w/ bash 300
DiscoDuck is offline
