how would this perform - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-31-2012, 02:20 PM - Thread Starter
qx56's Avatar
Power handling: 250 watts RMS/500 watts max • VCdia: 2-1/2" • Le: 1.94 mH • Impedance: 4 ohms • Re: 3.23 ohms • Frequency range: 23-200 Hz • Fs: 23 Hz • SPL: 89 dB 2.83V/1m •Vas: 4.12 cu. ft. • Qms: 5.59 • Qes: 0.44 • Qts: 0.41 • Xmax: 9.3 mm • Dimensions: Overall diameter: 12", Cutout diameter: 11", Depth: 6".
if this was in a 2.45 ported box and a 4x 12-14inch port. 300 watt bash amp
i have no software to figure this out your help would be great
thanks
qx56 is offline
post #2 of 7 Old 01-31-2012, 03:10 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5835 Post(s)
Liked: 4836
Working with very little information here... no listed Sd ... just guess that it's an average 12". Also "4x 12-14inch port"... what the hell does that mean? Do you want four 12" ports cuz.... no. I'm guessing you meant a single 4 inch port around 12-14 inches long. You're looking at a tune in the mid to upper 20's. Okay by any stretch but it aint gonna hang with the big boys. That's for sure.
What driver is this?
Scott Simonian is online now
post #3 of 7 Old 01-31-2012, 03:21 PM - Thread Starter
qx56's Avatar
http://www.parts-express.com/pe/show...number=295-204 yes one 4inch round 12-14inch long port. its the dayton sub at parts express. i swear its the same woofer in my ed a2 200 but i could be wrong. Would this setup hang with the a2 300? sorry for the lack of info
qx56 is offline
post #4 of 7 Old 01-31-2012, 04:55 PM
LTD02's Avatar
Quoted: 2462 Post(s)
Liked: 2781
ed specs are shaky at best.
e.g., what is "room tuning"
Listen. It's All Good.
LTD02 is online now
post #5 of 7 Old 01-31-2012, 05:02 PM - Thread Starter
qx56's Avatar
hmm no idea on the room tuning. its 23x14x7.5. riser takes up half the floor and is one foot tall. the ed woofer looks just like the dayton, like i said i could be wrong. mybe the internals are different, they said the ed has a 1inch excursion so maybe its not the same.
qx56 is offline
post #6 of 7 Old 01-31-2012, 05:09 PM
LTD02's Avatar
Liked: 2781
oh, qx56, was not pointed at you. "room tuning" for a subwoofer is a bogus spec that means nothing.
LTD02 is online now
post #7 of 7 Old 01-31-2012, 05:13 PM - Thread Starter
qx56's Avatar
gotcha.
qx56 is offline
