Edogg's QUAD LMS AIY (Assemble It Yourself) Build - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 608 Old 05-03-2012, 01:10 AM
samhain1's Avatar
Wow who said there was a recession. Drool
samhain1 is offline
post #302 of 608 Old 05-03-2012, 01:14 AM
pokekevin's Avatar
Liked: 102
I had to wait a week before my amp came in to power my sub....Horrible feeling
pokekevin is offline
post #303 of 608 Old 05-03-2012, 04:56 AM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Originally Posted by edoggrc51 View Post
FedEx arrived a day early with sub #4. Just need that 2nd amp and I'll be all set!
Awwww, yeeeaah...
Man, the light at the end of the tunnel is getting closer! When are you putting the next Clone on order? As always, I'll be checking back frequently for status updates.
I'm still having to slow play this with the wifey. We had a house warming party last weekend and I had a few of my friends tell her that our setup sure could use some more LFE and a 120" projector.
You know it's a tough sell when you gotta call for backup...lol. We're wearing her down slowly.
popalock is offline
post #304 of 608 Old 05-03-2012, 09:29 AM - Thread Starter
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Tell me about it. At least I have the one amp to break-in the 2 newer subs.
Originally Posted by popalock View Post
Awwww, yeeeaah...
Its getting there bro, little by little. I had some unexpected bills come up these last few days so the 2nd clone amp is gonna have to wait a little while longer.
edoggrc51 is offline
post #305 of 608 Old 05-03-2012, 04:16 PM - Thread Starter
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Since the 2nd map seems to be little while out, what do you guys think about me running the 4 subs off the single 14k?? I have each sub wired in series so theres a 4ohm load at each sub terminal. Im thinking of wiring each stack in series to produce an 8ohm load per channel for the FP14k and If i remember right the specs called for 2350 watts per channel.
What ya guys think? Am i waisting my time by doing this??
post #306 of 608 Old 05-03-2012, 04:52 PM
popalock's Avatar
Liked: 1712
Who am I to weigh in but, technically wouldn't you just be negating your additional displacement by cutting your power in half?
Hey, I'd do it regardless. Do it... Do it...
popalock is offline
post #307 of 608 Old 05-03-2012, 05:01 PM - Thread Starter
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Thats kinda along the lines of what i was thinking too.
post #308 of 608 Old 05-03-2012, 05:04 PM
omegaslast's Avatar
Not really, he should add 3db by simply doubling cone area.
you gain 6db by doubling power and doubling cone area. Hes keeping power the same and doubling cone area
omegaslast is offline
post #309 of 608 Old 05-03-2012, 05:10 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
+1
The system becomes more efficient, more efficiency means less watts are needed for a given spl.
mjaudio is offline
post #310 of 608 Old 05-03-2012, 05:11 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
In other words, do it do it do it
mjaudio is offline
post #311 of 608 Old 05-03-2012, 05:35 PM - Thread Starter
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Originally Posted by mjaudio View Post
+1
Learn me here guys.
Am I really keeping the same power?? I thought going the 8ohm route id go down to 2350watts per channel, then that's getting split to 2 LMS's. How does power vs. efficiency work out here??
post #312 of 608 Old 05-03-2012, 05:51 PM
popalock's Avatar
Liked: 1712
I thought long and hard before I posted my response. He is not going to see a 4 ohm load to each channel. It's going to be an 8 ohm load.
So double the cone area and half the power.
vs.
+3db with the same power
+6db with double the power
Learn me here guys.
Shaboom.. That's the logic I'm talking about.
+1
Seems like the same output would obviously more effortless (for the subs anyway) with that much more displacement. Reducing the ohm load should technically be less stress on the amp, correct?
popalock is offline
post #313 of 608 Old 05-03-2012, 05:58 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5278 Post(s)
Liked: 4163
One sub @ 4,400w power = 0 dB gain
Two sub @ 4,400 each power = 6dB gain (extra power AND cone area/displacement)
Two sub @ 2,200 each power = 3dB gain (extra cone area/displacement)
Two sub @ 1,100 each power = 0dB gain (extra cone area/displacement negates power loss)
If that makes sense
*shrugs*
Scott Simonian is offline
post #314 of 608 Old 05-03-2012, 06:03 PM
popalock's Avatar
Liked: 1712
If that makes sense
*shrugs*
Got it. Eric will be going with the last option you presented because it's an 8 ohm load. I think we're on the same page.
When he get's his second amp and each channel sees a 4 ohm load, he'll get his 6db gain he's looking forward too...
Call me master of the obvious, lol.
popalock is offline
post #315 of 608 Old 05-03-2012, 06:27 PM
omegaslast's Avatar
Maybe the LG clone would be even more stable at 8ohms on each channel.. idk.
Less power going through 4 drivers should still be better overall simply due to 4 drivers barely moving to get same effect as 2 drivers moving a lot. At least youre breaking in the drivers too
post #316 of 608 Old 05-03-2012, 06:30 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
There is no reason NOT to run all 4 subs while waiting for the second amp. Sure it's not the headroom he is after but it will play to the same levels with less cone excursion and less strain on the amp. He can also loosen up the new subs and make sure they function perfectly.
mjaudio is offline
post #317 of 608 Old 05-03-2012, 06:31 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
You beat me to it.....
mjaudio is offline
post #318 of 608 Old 05-03-2012, 06:33 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Exactly.
mjaudio is offline
post #319 of 608 Old 05-03-2012, 06:43 PM - Thread Starter
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
So............... what you guys are saying is to......... DO IT, DO IT, DO IT!!!!
I'll work on that this weekend. Thanks fellas!
post #320 of 608 Old 05-03-2012, 07:46 PM
Bass Enabler
Liked: 4163
post #321 of 608 Old 05-04-2012, 02:16 AM
chrapladm's Avatar
Quoted: 822 Post(s)
Liked: 286
^^^^^^ gifs not working......BBoooo
chrapladm is online now
post #322 of 608 Old 05-04-2012, 09:43 AM
popalock's Avatar
Liked: 1712
Safe to say that's the general consensus. lol
I'm looking forward to hearing your impressions almost as much as I'm looking forward to seeing the Avengers this weekend!
popalock is offline
post #323 of 608 Old 05-04-2012, 05:44 PM - Thread Starter
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Will do!
Btw, my brother just sent me a text. He said the movie was EXCELLENT!
post #324 of 608 Old 05-04-2012, 09:55 PM
chrapladm's Avatar
Quoted: 822 Post(s)
Liked: 286
Love the movie. Its a movie I wouldn't mind seeing again. Really curious how one of the scenes will sound at home on a true 3-120hz subwoofer.
post #325 of 608 Old 05-05-2012, 02:17 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
Has anyone here ever heard the Danley DTS 10 SUBWOOFER KIT? I have 3 of them and wonder how they would stack up against 4 of these LMS ULTRA 18 IN sealed enclosures just as this thread is now.
In a 4 LMS ULTRA sealed System does it really dig down to 3 htz? What htz would you put in a hpf?
Last I would love to demo a 4 sub system like this. What state are you located in and would you welcome a demo?
kutlow is offline
post #326 of 608 Old 05-05-2012, 07:22 PM
chrapladm's Avatar
Quoted: 822 Post(s)
Liked: 286
You dont need a Hpass on the Ultra unless your maxing them out. Not has a Hpass filter but he probably doesn't really need it.
MK had 2 DTS10 kits and now has a bunch of 18's also.
post #327 of 608 Old 05-05-2012, 08:39 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Ricci said even 2 ultras would have a hard time outgunning a single DTS 10 so I'd say you're gonna need some more displacement to make a lateral move in terms of output.
gpmbc is offline
post #328 of 608 Old 05-05-2012, 08:41 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
what I want to know is will 2 of these sealed 18 LMS ULTRA outperform 2 of the DTS 10'S? MK can you respond? How do you think 4 of these will sound verses 3 dts 10's?
kutlow is offline
post #329 of 608 Old 05-05-2012, 08:44 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
In a room measuring 16 feet wide and 21 feet deep and 9 foot ceilings what db should I be able to achieve in movies from my seating position which would be 14 feet from my listening position?
kutlow is offline
post #330 of 608 Old 05-06-2012, 07:09 AM
popalock's Avatar
Liked: 1712
Will do!
Avengers. Double thumbs up. 9.2 of 10.
Edoggs impressions of his quad setup? All of this fans eagerly await his input...
popalock is offline
