Box calculator - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-02-2012, 05:17 PM - Thread Starter
qx56's Avatar
Whats the best free software?
What is everyone using?
qx56 is offline
post #2 of 8 Old 02-02-2012, 05:41 PM
cwier60's Avatar
Here's a great "getting started" site - http://techtalk.parts-express.com/sh...d.php?t=219617
Check the items under Essential Speaker Building Software. WinISD is pretty straightforward and easy to learn, although it might not handle everything.
cwier60 is offline
post #3 of 8 Old 02-02-2012, 10:45 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
I like UniBox and believe it's more accurate than WinISD.
WinISD allows you to compare systems with different drivers; UniBox only lets you compare the same driver in different kinds of boxes.
Noah
noah katz is offline
post #4 of 8 Old 02-02-2012, 11:32 PM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2582
"I like UniBox and believe it's more accurate than WinISD."
except for inductance, don't both programs employ more or less the same equations for small signal response?
Listen. It's All Good.
LTD02 is offline
post #5 of 8 Old 02-03-2012, 11:08 AM
Ricci's Avatar
Quoted: 185 Post(s)
Liked: 473
Unibox...WinISD is unable to accurately model some drivers due to the inability to account for inductance. Simple as that.
On the other hand if you don't know what those parameters are then it won't really matter since you can't enter them into Unibox either.
Ricci is online now
post #6 of 8 Old 02-03-2012, 01:34 PM
A9X-308's Avatar
Quoted: 1307 Post(s)
Liked: 971
Another, and long and oft repeated vote for Unibox. As well as working perfectly for a decade, it allows you to it allows to import and implement .frd files from the many other programs available at the FRD Consortium, which are also free.
A9X-308 is offline
post #7 of 8 Old 02-03-2012, 02:49 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
I don't know, but a professional designer I talked to says UniBox gives results much closer to predictions and measured results from Speak (IIRC).
Another odd thing is that in WinISD adding series resistance gives big increases in in low freq output, UniBox much less so.
Noah
post #8 of 8 Old 02-03-2012, 06:44 PM
coctostan's Avatar
Liked: 135
I like both for different reasons. WinISD shows down to unity, it is very easy to add filters and eq, you can quickly compare designs and you can use more than 4 drivers.
Unibox allows for the better inductance model if you have that data available. You can also apply filters but it is a more convoluted process. I prefer its handling of passive radiators too.
coctostan is offline
