RCA to XLR or T/S? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 02-06-2012, 02:46 AM - Thread Starter
djdcm0722's Avatar
Last question before I purchase all my parts for my subwoofer build. As the title suggests RCA to XLR or T/S? Any benefits or downsides to either cables? I have an Onkyo RC260 with two sub preouts. I plan on connecting them to an iNuke NU1000DSP.
These are what I am looking at:
RCA to T/S
or
RCA to XLR X2
I'll be ordering everything here in a few weeks. I'll be posting pics of the build progress. Just wanted to say thanks to everyone for helping me and informing me on my first DIY sub.
djdcm0722 is offline
post #2 of 16 Old 02-06-2012, 03:05 AM
DL86's Avatar
Either works fine. I have used both configs with an EP4000.
To improve the black level performance of your projector: Shine bright light into your eyes every 5 minutes.
DL86 is offline
post #3 of 16 Old 02-06-2012, 04:12 AM - Thread Starter
djdcm0722's Avatar
Sounds good. Just what I needed to hear. Thank you.
post #4 of 16 Old 02-06-2012, 05:42 AM
dbldare's Avatar
Do you guys think he's gonna need a pre-amp with this set-up?
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #5 of 16 Old 02-06-2012, 06:55 AM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
dbl
No way! Onkyos tend to have high output voltage on their preouts already.
tsloms is offline
post #6 of 16 Old 02-06-2012, 07:18 AM
dbldare's Avatar
Alrighty then - Good luck with the build.
dbl
dbldare is offline
post #7 of 16 Old 02-06-2012, 07:33 AM - Thread Starter
djdcm0722's Avatar
dbl
Thanks, will keep you guys posted.
post #8 of 16 Old 02-06-2012, 08:10 AM
coctostan's Avatar
Liked: 135
Does anybody have the input sensitivity spec for the amp? It shouldn't be too tough to figure out if your receiver has enough voltage to drive it to full power. All you need is that spec and a multimeter.
coctostan is offline
post #9 of 16 Old 02-06-2012, 08:42 AM
Quoted: 911 Post(s)
Liked: 490
Haven't there been a few batches of Monoprice RCA->XLR cables that were mis-wired?
Dunno if they've fixed them, but for that reason alone I'd look at something else. Or even just get a phone-plug adapter for an RCA wire you already have.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #10 of 16 Old 02-06-2012, 10:52 AM
zhillsguy's Avatar
Some batches of MP's 6 ft. RCA>XLR cables were wired incorrectly last summer. However, it may still be the best option if you know how to use a VOM and soldering iron.....especially if XLR pin 1 needs to be isolated from the signal chain. It's difficult to buy the materials for what they sell them assembled.
zhillsguy is offline
post #11 of 16 Old 02-06-2012, 11:24 AM - Thread Starter
djdcm0722's Avatar
I remember reading something about this. Apparently there is a setting in the amp to adjust the sensitivity. I could be wrong on this.
I also have been hearing the XLR cables have been bad from mono. I was planing on going with the RCA to T/S cable. I just wanted to make sure I wouldn't be sacrificing anything by going with one over the other.
post #12 of 16 Old 02-06-2012, 11:30 AM
DonH50's Avatar
Quoted: 1795 Post(s)
Liked: 1330
RCA is single-ended so you won't have balanced (XLR or TRS) anyway. T/S is probably cheaper and easier, and no worries about geographic pin-out differences on the XLRs.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #13 of 16 Old 02-06-2012, 11:34 AM
desertdome's Avatar
Quoted: 1121 Post(s)
Liked: 1224
I think it is easier and cheaper to buy RCA to XLR adapters and use your existing RCA cables.
High Impact AV
desertdome is online now
post #14 of 16 Old 02-16-2012, 05:33 AM
Angelo M's Avatar
I'm looking at this amp too, to power 2 boxed subs for ht. What do you use to connect to this amps speaker outs to the subs speaker connections. I'm using binding posts on the sub boxes....
Angelo
Angelo M is offline
post #15 of 16 Old 02-16-2012, 08:49 AM - Thread Starter
djdcm0722's Avatar
You'd use speakon cables. I haven't started the build but I will be using Speakon Neutrik connection on the sub box http://www.parts-express.com/pe/show...number=092-059. I don't know if it would be safe or not, maybe someone else can chime in, but I think it would be possible to run two wires from the back of the Neutrik connector to your binding posts.
post #16 of 16 Old 02-16-2012, 04:54 PM
Angelo M's Avatar
Thanks, I get it now!
Angelo
Angelo M is offline
