What wood for Laquer finish on Sub ??? - AVS Forum | Home Theater Discussions And Reviews
Old 02-06-2012, 11:37 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
When a Sub is finished in a beautifull laquer paint finish , what materiel is the Sub made of ,...MDF , Birch Ply ....???
randyc1 is offline
Old 02-06-2012, 03:54 PM
mwmkravchenko's Avatar
Liked: 26
Either can be used. It's the joinery that matters. A completely mitered box on the exposed sides is what matters. The bottom of the box does not have to be mitered.
Butt joints will telegraph through the finish. In other words you will end up seeing the joint movement.
Sealing on the interior and the exterior of the box is most important. Then your choice of lacquer and the number of coats. Under a dozen total coats ( sealer coats should be around three, and top coat a minimum of three or four coats ) is ok, lots of coats end up cracking. The real trick is knowing how to sand properly to get a dead flat surface.
Mark Kravchenko
Consultant and Designer
www.kravchenko-audio.com
mwmkravchenko is offline
Old 02-06-2012, 10:09 PM
Colm's Avatar
Liked: 94
Could be MDO as well.
The finish can only be as good as the substrate.
Sometimes laminate is used as an alternative to a lacquer finish. Wilsonart black laminate looks very much like a piano black lacquer finish.
Colm is offline
Old 02-06-2012, 11:36 PM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2581
as was already said, the key to a good paint job is to get the surface perfect before applying coat 1 of paint. less important is the wood used. one technique to help ease the process is the use off high build primer. this will help fill in all the hairlines, pinholes, grain effects, etc.
http://www.avsforum.com/avs-vb/showthread.php?t=1139736
Listen. It's All Good.
LTD02 is offline
Old 02-07-2012, 05:00 AM
t6902wf's Avatar
There are laminates that will give you the look you are after with a lot less skill and labor.
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
