clearance for internal port flare - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-12-2012, 07:34 AM - Thread Starter
christmclean's Avatar
How much space should there be between the back of the amplifier and the flared subwoofer port. Is a 1 inch clearance enough.
christmclean is offline
post #2 of 3 Old 02-12-2012, 10:39 AM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
around one port width is a good rule of thumb. 2" for a 2" diameter port, 6" for a 6" diameter port.
the less room that you give it, the less the air flows and you can actually end up with a lower tuning frequency, which can either be an advantage or a disadvantage.
Listen. It's All Good.
LTD02 is offline
post #3 of 3 Old 02-12-2012, 03:14 PM - Thread Starter
There must have been only about an inch of clearance from the original amp, however the back of the amp had more free space with the open part around the capacitors. Now with the enclosed design there will be less total space behind the port. But the air flowing into the port will be more uniform. I guess I will just try cutting the port tube down and leave about an inch or so with the port flare. I guess I won't have to worry about chuffing to much, and maybe a lower tune but less output.
