Bash 300,s or dayton sa240 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-14-2012, 08:51 PM - Thread Starter
qx56's Avatar
Simple what one would you buy?
qx56 is offline
post #2 of 12 Old 02-14-2012, 09:21 PM
bullitt_60's Avatar
I bought the Dayton 3 years ago and it has served me well. It has plenty of power for my smallish room. I use it to a power 12" driver in a sealed box.
bullitt_60 is offline
post #3 of 12 Old 02-14-2012, 09:32 PM
mcsoul's Avatar
Quoted: 16 Post(s)
mcsoul is offline
post #4 of 12 Old 02-15-2012, 04:17 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
Parts Express also has a 300w BASH amp along with the SA-240.
I would consider buying which one is on sale (i.e., least expensive).
I have the PE 500w BASH amp and also the PE SA-240. Both work fine in my applications.
wwinkler is offline
post #5 of 12 Old 02-15-2012, 07:08 AM
garciab's Avatar
Quoted: 144 Post(s)
Liked: 55
I'm a believer in the BASH amps. Best thing I like about them is how quiet they are with no signal. No hum whatsoever. The 240 I have has a slight hum. Also, I've had some 'old school' plate amps where the huge transformer itself was a source of noise. Not a problem with the BASH amps. I do have some smaller 'old school' types (the 100W type), and they are dead quiet too. But I'm fairly certain that if I were to buy another, it'd be a BASH type. I keep a 300W and 500W spare, just in case the bug hits me to build something.
bg
garciab is offline
post #6 of 12 Old 02-15-2012, 08:09 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Yup, the 240 hums... Can a cheater plug help
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #7 of 12 Old 02-15-2012, 10:06 AM
Favelle's Avatar
Creative Sound has the BASH 300 on for $125!
In terms of LFE, size does matter!
Favelle is offline
post #8 of 12 Old 02-15-2012, 10:54 AM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
I picked up my BASH 300 from Parts Express for $114 shipped. Not sure if that price is current.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #9 of 12 Old 02-15-2012, 10:55 AM
lowpolyjoe's Avatar
my 240 hums as well, althought the wife makes me keep it turned down so low i don't even hear the hum ......
i was having major cable tv signal problems when i last tried turning it up and heard the hum. since then the cable stuff has been 95% resolved so maybe the hum has lessened.
can't say a Bash wouldn't do the same thing in my setup, but if i buy another plate amp i will probably give Bash a shot
-1 on the cheater plug thing... after some reading about electrical safety issues i've decided to make a significant effort to remove them from my house completely. i've changed a few 2prong recepticles to 3prong to avoid them in the past.
lowpolyjoe is offline
post #10 of 12 Old 02-15-2012, 11:54 AM
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
BASH pricing is correct as of today on PE's site...
SA 240 (and 240b) both only a few dollars more for 119.00
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #11 of 12 Old 02-15-2012, 12:35 PM
bullitt_60's Avatar
Yes, it resolves the hum.
post #12 of 12 Old 02-15-2012, 12:42 PM
bullitt_60's Avatar
If you have pets or kids I would do the same. I don't and unplug all devices prior to working on them. The chances of anything going wrong are very small as well.
