Mini-Gun build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 56 Old 03-03-2012, 02:58 PM - Thread Starter
PassingInterest's Avatar
Quoted: 185 Post(s)
Liked: 504
Take a few passes and trim off a little at a time.
For the final pass, use some paper folded over to set the depth, leaving a little bit to sand the rest of the way.
One side sanded.
PassingInterest is offline
post #32 of 56 Old 03-03-2012, 05:22 PM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Hey PI
Did you intentionally get the warning label from the strap in this shot? Was it a strap or clamp that whacked you in the head?
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #33 of 56 Old 03-03-2012, 06:04 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
Pete--The warning label in the shot was purely accidental.
A 24" Black Pipe clamp was launched from the curved panels and got me. I'm glad it wasn't serious.
post #34 of 56 Old 03-05-2012, 02:05 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
Ready for the front baffles.
post #35 of 56 Old 03-05-2012, 04:18 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
It's not speaker-related, but here's a tip:
If you have a slow leak, but the tire won't hold air, because the bead has broken free from the rim--you can force the bead against the rim, by squeezing the tire with a ratcheting strap. Then you can add air.
This trick works on car tires, too.
post #36 of 56 Old 03-06-2012, 09:12 AM
BeerParty's Avatar
Nice! Almost a shame to cover the front of those with another baffle, they look pretty good as-is.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #37 of 56 Old 03-06-2012, 11:04 AM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
Thanks, Chris! I wanted to make sure the front baffles were strong.
I didn't like the look of the newly added baffles, since I didn't angle the edges to match the curve of the sides. Sorry I didn't get a photo of that.
I sanded the edges to match the curved sides.
Then I sanded the edges with a curved sanding form used for sanding sheet-rock corners. I placed a folded sheet of P220 over the curved sanding form and held it in place with my hand while I sanded a rounded edge.
post #38 of 56 Old 03-06-2012, 11:07 AM
filtor1's Avatar
Quoted: 213 Post(s)
Liked: 166
Wow, you never leave me unimpressed PI... Any info on the drivers going in this?
filtor1 is offline
post #39 of 56 Old 03-06-2012, 11:10 AM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
Thanks, man!
The drivers are 10" NHT 075s.
I used the 10" NHT 083s in my Howitzers.
Both drivers are sadly, no longer available.
post #40 of 56 Old 03-06-2012, 11:23 AM
filtor1's Avatar
Quoted: 213 Post(s)
Liked: 166
Originally Posted by PassingInterest View Post
Thanks, man!
Man I tell you what, the info I needed was in your first post. lol I get them mixed up sometimes. Sorry about that.
filtor1 is offline
post #41 of 56 Old 03-06-2012, 11:37 AM
lowpolyjoe's Avatar
Funny you should post this - a few months back i looked up how to get air into a tire who's bead has given up and found this approach. I was very skeptical, but it worked fine for me on my snowblower.
+1 for random garage knowledge
lowpolyjoe is offline
post #42 of 56 Old 03-06-2012, 12:21 PM
BeerParty's Avatar
Nice! I have seen drywall sanders for inside corners, but never for curved outside corners. Looks like you one-up'ed me in the cool tool department again.
Chris
post #43 of 56 Old 03-06-2012, 12:42 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
Thanks, guys.
Setting the recess depth.
I glued some discs together to make some feet.
After the glue dries, I will sand them smooth, then install them.
My work here is nearly done.
I hope my friend will show how they look after he finishes them, but that's up to him.
post #44 of 56 Old 03-06-2012, 12:59 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
Your the best friend in the world, my local friends suck compared to you
mjaudio is offline
post #45 of 56 Old 03-06-2012, 01:25 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
Haha! You're very funny. Thanks.
I did some initial sanding.
Then added clamps.
I'll do the final sanding tomorrow, then I'm done.
post #46 of 56 Old 03-06-2012, 04:25 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 169
Those feet look like AraucoPly....
JSS
maxmercy is offline
post #47 of 56 Old 03-06-2012, 05:09 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
JSS
You have a good eye. I'm impressed. They are indeed Arauco--a great value in plywood.
post #48 of 56 Old 03-07-2012, 06:27 AM
mcsoul's Avatar
Quoted: 16 Post(s)
Amazing projects you build, I mean wow! Where are you in Dallas? I wish I could come over and train at the feet of a master speaker builder
mcsoul is offline
post #49 of 56 Old 03-07-2012, 07:24 AM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
You're very kind. Thanks.
I lived in Rowlett for a few years, myself.
Now I am in Forney.
I'm no master or expert, just a DIYer. But we can get together on a build some time, if you'd like.
post #50 of 56 Old 03-07-2012, 11:17 AM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
Sand the glue squeeze-out.
My job here is done.
post #51 of 56 Old 03-07-2012, 12:04 PM
04FLHRCI's Avatar
Great Job PI; be sure to get us some pics once the drivers are mounted. This has me reconsidering at least one of my current cabinet approaches.
Larry
04FLHRCI is offline
post #52 of 56 Old 03-07-2012, 03:49 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 169
What will be the final finish?
JSS
maxmercy is offline
post #53 of 56 Old 03-07-2012, 05:37 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
04FLHRCI--Thanks, man. When I see him I'll ask him to post his finish shots here in this tread. It's up to him, but I hope he does.
JSS
He wants to go for a gloss black.
post #54 of 56 Old 03-07-2012, 06:00 PM
mcsoul's Avatar
Quoted: 16 Post(s)
Now I am in Forney.
PM on it's way! Thank you sir.
mcsoul is offline
post #55 of 56 Old 03-22-2012, 10:28 AM
BP1Fanatic's Avatar
LMAO!!! Beautiful work as always PI!
BP1Fanatic is offline
post #56 of 56 Old 03-22-2012, 03:02 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 504
It's very kind of you to say so. Thanks!
