The advent loudspeaker rebuild - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 02-23-2012, 08:54 AM - Thread Starter
beastaudio's Avatar
Quoted: 4158 Post(s)
Liked: 3515
I am getting a set of the original walnut advent loudspeaker cabinets for free from a business partner of mine and wanted to put a thread out asking about what some cool options might be for me to rebuild them into. Id love to incorporate the new SEOS waveguides into a build if its possible, but im willing to take any other opinions here. potentially even a 3 pi type setup The cabinet stock, has a 10" but the basket is the size of a 12, I would be willing to bore it out for whatever. the top of the cab has a "fried egg" type tweeter and would easily fit an SEOS12 with possible even room for a port. The port could also be located below the woofer if needed. Here is a pic of the enclosure off the internet (that woofer is not stock), I wont be able to get the cabinets until tomorrow...
http://www.google.com/imgres?q=adven...1t:429,r:0,s:0
beastaudio is offline
post #2 of 18 Old 02-23-2012, 09:23 AM
WiSounds's Avatar
Alot of baffle to work with there, modern upgrades to a classic like that sounds like such a fun project. Scribed
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #3 of 18 Old 02-23-2012, 10:19 AM
Spec4's Avatar
Liked: 24
Well like I stated in another thread I've had a similar project (Advent 5012) that has been on the "back burner" for some time while I watched the SEOS take shape, pun intended. I've got some E-wave build links that I've saved if you would like them?
The Advent Loudspeaker (Zilch's own OLA):
http://www.audiokarma.org/forums/sho...d.php?t=165025
EconoWaveguide Utility Large Advent Build Thread:
http://audiokarma.org/forums/showthread.php?t=196614
AK Design Collaborative - Econo-Waveguide Speaker Project:
http://www.audiokarma.org/forums/sho...t=large+advent
The Advent Loudspeaker is 12" x 23.25" x 9" = 1.4531 cuft. internal volume by my calcs....
http://audiokarma.org/forums/attachm...1&d=1232943245
Walnut Large Advent Restore in progress - Some Q's:
http://www.audiokarma.org/forums/sho...t=Large+Advent
Spec4 is offline
post #4 of 18 Old 02-23-2012, 11:16 AM - Thread Starter
beastaudio's Avatar
Liked: 3515
awesome links, ill check them out I also looked up the specs on the 3pi and the cabinet size on it yields 3.81 cuft while the advent is 1.4, think that would cause problems with the xover and/or doing a build around the 3pi? since it already uses a 12 and is a sealed design, I think it should still work pretty well, just maybe not get as low, which is OK as I cross at 80 or above anyways...
post #5 of 18 Old 02-23-2012, 12:48 PM - Thread Starter
beastaudio's Avatar
Liked: 3515
I tried to look up the specs on the TD12s and the link seems to be down. Does anyone know if it will work ok in 1.4cuft? I dont see why it wouldnt but perhaps it needs more room. Another thought I had was that I could actually extend the back of the cab out another inch or two to gain some additional airspace, and or space for the horn which might need some more depth than the currently available 14inches.
post #6 of 18 Old 02-23-2012, 02:32 PM
bobgpsr's Avatar
I cut your 39 liter (1.4 ft^3) to 36 liters for driver volume, etc. Tune box for 38 Hz (2.5" dia port now at 5" length from 3Pi's 2.5"). Not too bad and handles more power.
TD12S T/S parms
1.4 cubic foot tuning
bobgpsr is offline
post #7 of 18 Old 02-24-2012, 06:53 AM - Thread Starter
beastaudio's Avatar
Liked: 3515
well that certainly looks like it will work! I was under the impression that the 3pi was a sealed design though? 4pi is the ported. Not that I dont mind porting it, unless it messes with the XO values. I would order the XO from Wayne if I did it like this, assuming with the smaller box that the XO would still work ok using the same drivers.
post #8 of 18 Old 02-24-2012, 07:11 AM
bobgpsr's Avatar
No, the three Pi is ported with an Fb of approx 30 Hz (my sims show 28 Hz) for a F3 of 50 Hz but with a nice slow slope from 80 Hz down to 30 Hz that should work very well with normal room gain.
To use Wayne's crossover you should use the same waveguide (Eminence H290) and front baffle layout (woofer to waveguide locations).
I have two, three Pi kits, with upgraded drivers on order from Wayne (waiting for the AE TD12S's to be built).
bobgpsr is offline
post #9 of 18 Old 02-24-2012, 07:44 AM - Thread Starter
beastaudio's Avatar
Liked: 3515
Hm, so the advent baffle wont be the same size as the standard 3pi build, or do you mean the vertical distance from the horn to the woofer should be the same? that might still work if that's the case.
I would buy all the same components needed for the 3 pi, including the H290 if I did that particular design, but im still open to others as well
post #10 of 18 Old 02-24-2012, 08:13 AM
bobgpsr's Avatar
...or do you mean the vertical distance from the horn to the woofer should be the same? that might still work if that's the case.
Well Zilch talked about a school of thought that with waveguides baffle width did not matter so much. But there is still the Baffle Step Compensation on the woofer/midrange driver to deal with. I wonder what Wayne Parham would have to say?
But for sure the vertical distance between woofer and waveguide is very important and considered in the crossover design (aiming of the front lobe).
bobgpsr is offline
post #11 of 18 Old 02-24-2012, 08:23 AM
Quoted: 995 Post(s)
Liked: 525
A project in the true tradition of Zilch!
(Seriously, has anyone else taken more old-school speaker boxes, put modern parts in them, and designed a real crossover for the new parts in the old box?)
What I'd do is build a new baffle to fit flush with the step, and screw-mounted so you can get underneath it. I'd mount the SEOS12 flush to the new baffle. For the woofer, I'd rout the inside of the new baffle out to fit the woofer's mounting ring. Mount the woofer to the sub-baffle inside, and on the front side of the new baffle gently round over from the woofer suspension out. (The cutout for the woofer on the new baffle will look kind-of like a flattened urn: a step on the inside, with a round over on the other side. That way, you'll hide the basket frame and better align the driver motors.
Unless already you have a pair, you should think about using an actually available mid woofer.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #12 of 18 Old 02-24-2012, 08:32 AM - Thread Starter
beastaudio's Avatar
Liked: 3515
Good suggestions, and No, I dont have the ae's, just thought it would be a great option and is the right size. Ive wanted to hear a good ae speaker for a while.
post #13 of 18 Old 09-25-2012, 02:18 PM - Thread Starter
beastaudio's Avatar
Liked: 3515
Ok sold some speakers finally so I am bringing this one back. I have decided on the designer 12 with the SEOS 12 and DNA360 per bwaslo's design. I will probably put my order in by the end of the week. I plan on using these, depending how they sound in either a dedicated listening room or my upstairs den, and Im really looking forward to doing this whole project for sure!!!
One problem. I would really really need someone to assemble the XO for me. I have absolutely no skills with soddering, electronic boards or the like. Would anyone be willing to do this for me? I could order all the stuff necessary and ship it to you, pay for shipping to me obviously and maybe throw a little extra in for time taken?
post #14 of 18 Old 09-25-2012, 02:48 PM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
mtg90 is offline
post #15 of 18 Old 09-26-2012, 09:08 AM - Thread Starter
beastaudio's Avatar
Liked: 3515
Awesome!!! I will PM you when I get the final order down and can ensure that I have all I need to do the XO properly. Thanks man!!!!
post #16 of 18 Old 09-26-2012, 09:16 AM
Erich H's Avatar
Quoted: 1495 Post(s)
Liked: 1908
I'm close enough to PE and go there every week to pick up parts. If you want, I can pick up everything you need as a kit and maybe I could talk Bwaslo into showing me the proper way to solder up your boards.
Actually, this would make a good opportunity for me to price everything out and get a kit made up and maybe with the choice of baffles or box.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #17 of 18 Old 09-26-2012, 01:15 PM - Thread Starter
beastaudio's Avatar
Liked: 3515
what is the total SEOS width? I just want to double check that it will fit the baffle of the advent, otherwise, Ill be making new boxes...Regardless, if you want to use this a good shot at getting the full kit built up, I am 100% for it. MTG did offer to build the XO's as well, but if this helps the greater good by you getting a good grasp on XO building. Ill be happy to fund the venture.
post #18 of 18 Old 09-28-2012, 11:48 AM - Thread Starter
beastaudio's Avatar
Liked: 3515
Ok back to drawing board... I measured the interior of the front baffle of the advent cabinet. It is not wide enough to fit the SEOS 12. With it's overall width at 13.2", I only have 11 3/4 to work with comfortably. I might be able to squeeze another 1/2" somehow,but I would have to remove the plastic surround that is part of the recessed baffle. Might do this anyway, at which point the designer 12 will still be able to fit, but the SEOS12 is still a good bit too large. Any thoughts on making the 12 work alright? These are kind of just a fun little project I wanted to do, so I dont really want to jump for the SEOS 10 as that will take it way over budget. I plan on doing a 15" SEOS build for the theater more than likely, so I will eventually be doing one of the top-end builds. but for now, this was just supposed to be a little fun project with the advent cabs.
I am kinda disappointed, but I think I can still manage some way to make these work out. Any suggestions? Could I even shave off just a little bit of the WG to make it fit? Or Erich do you have any that are slightly undersized?
