JTR 12HT vs Yorkville U215 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #61 of 81 Old 05-05-2013, 04:03 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1139
Originally Posted by Martycool007 View Post
I am not that up to date when it comes to horns. Can anyone tell me if the Unity style horns are available to the general public DIY guys? Are there any good DIY designs using these types of horns?
You can buy the later Synergy horns from Danley, and there are some DIY efforts available, but how good they are I dunno. I do know they are very tricky to design so I bought a set of the old Lambda Unity's, the same design as used in WIlliam's speakers, here. I got to hear that system (Finale) and it was damn good, one of the two or three best systems I'd ever heard.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #62 of 81 Old 05-05-2013, 10:05 AM
COACH2369's Avatar
Quoted: 896 Post(s)
Liked: 732
First of all, thanks for the input and information.
I spent yesterday reading up on the Yorkville speakers. Unlike JTR, which has a “PRO” line and a “HT” line, the Yorkville speakers seem to be used for “PRO” applications. This has me wondering if their could be some drawbacks using them for HT use. My knowledge of what the main differences between the two types of speakers are is very poor, so I am not sure what to think.
Now the guy selling his speakers had been using them in a dedicated room for HT with some JTR slanted 8’s for rears and some DIY subs. He was only using an AVR to power them and told me he was pleased with the sound and performance.
Another thing I need to determine is if these speakers are okay being put on their side. I would have to have the center below the screen, so this would be must.
The price he is willing to take for them, make it almost hard not to get them and try them out. Then if I don’t like them, try to sell them on here. He just doesn’t have them setup at this time.
My church recently installed them with their latest expansion and they used a local company in East Tennessee that reps them, so it is good to know somebody handles them nearby.
COACH2369 is online now
post #63 of 81 Old 05-05-2013, 10:07 AM
COACH2369's Avatar
Quoted: 896 Post(s)
Liked: 732
Of course, selling my T12's and saving up for some 212HT's also is an option.... wink.gif
post #64 of 81 Old 05-05-2013, 04:15 PM
A9X-308's Avatar
Liked: 1139
They don't have a furniture grade finish. Otherwise, no.
A9X-308 is offline
post #65 of 81 Old 05-05-2013, 04:28 PM
COACH2369's Avatar
Quoted: 896 Post(s)
Liked: 732
That is no worry to me because my room is a dedicated HT and is dark. smile.gif
post #66 of 81 Old 05-06-2013, 04:16 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 180
I thought I remembered reading somewhere that the Yorkville Unitys can be modded to perform better in
a consumer home theater type setting. I am not sure what kind of mods would be necessary, though. Perhaps
some tweaking of the crossover, or maybe driver swaps as well?
Martycool007 is offline
post #67 of 81 Old 05-06-2013, 05:05 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 521
I'm not seeing any reason to make crossover changes at this point. The cabinet could be dampened a bit better and some slight eq on the top end brings them to just about perfection for me. tongue.gif midrange is so darn smooth on these guys!
Btw the woofs are a stout 18 sounds model and the CD is a bms 4550. I don't know why any component swaps would be needed - this would further complicate a crossover redesign as well. Ive got a feeling many suggesting such tweaks have never heard them in the first place.
Btw I also have the up215 processing box / external crossover for them. I will be trying this out when I return home next weekend .
Gorilla83 is offline
post #68 of 81 Old 05-06-2013, 10:26 AM
LTD02's Avatar
Quoted: 2462 Post(s)
Liked: 2781
"Btw I also have the up215 processing box / external crossover for them. I will be trying this out when I return home next weekend ."
iirc, that is what marty is recalling not the passive crossover. i don't recall the thread, but it seemed like the active crossover left something to be desired.
Listen. It's All Good.
LTD02 is online now
post #69 of 81 Old 05-08-2013, 05:05 AM
Quoted: 280 Post(s)
Liked: 180
Are the Synergy horns available as a separate horn from Tom Danley without having to buy the entire speaker? Are they very expensive?
post #70 of 81 Old 05-08-2013, 05:40 AM
Mike Garrett's Avatar
Quoted: 6602 Post(s)
Liked: 4288
The Unity Horn is the entire speaker. If you are talking about buying the horn without the drivers, then no it is not available that way. Besides, by the time you bought the drivers, you would have more money in it and if the drivers Tom uses has any customization, then the drivers you purchase would not fit right with the crossover.
mjgarrett100@gmail.com
Mike Garrett is online now
post #71 of 81 Old 05-08-2013, 07:12 AM
Quoted: 280 Post(s)
Liked: 180
So are there any companies that sell Unity horns? I have read about some other companies that have produced them in the past, but aparently they have gone out of business.
Who said that I would use the same drivers that Tom uses? I figure that if I wanted to use the same drivers as Tom, then I would have just purchased his completed speakers.
What I would like to do, is find a single Unity horn that I can experiment with different drivers and various crossover settings either actively or passively. Are there any Unity horns
available to us DIY'ers?
post #72 of 81 Old 05-08-2013, 07:20 AM
MKtheater's Avatar
Quoted: 1706 Post(s)
Liked: 1238
Unity horns are what Yorkville sells designed by Danley. Synergy horns are the newer designed product from Danley. The unity horn contains the CD and mid drivers where the Synergy horn is a complete speaker all housed in the horn. You can buy a Yorkville unity horn but it comes with drivers.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is online now
post #73 of 81 Old 05-08-2013, 02:36 PM
COACH2369's Avatar
Quoted: 896 Post(s)
Liked: 732
Hopefully I will get to demo these in the next few days. The used ones I am getting are in my customer's storage unit, but I saw them today. They are quite large, but I think I can "squeeze" them into my room wink.gif
post #74 of 81 Old 05-09-2013, 06:12 AM
Quoted: 280 Post(s)
Liked: 180
Are the Yorkville Unity horns available with just the horn and CD's without having to buy the entire speaker? How do you guys
think the newer Synergy horns compare, performance wise, to the Unity design? I am sure that there are a wide range of possibilities
with regards to that answer. LoL.
I have seen some Synergy designs using what appears to be very large "wings" with the CD's and the woofers stuffed inside. I wonder
how those would compare for home theater use?
post #75 of 81 Old 05-09-2013, 09:02 AM
Kimeran's Avatar
Quoted: 23 Post(s)
Liked: 128
From what I have understood,
The synergy horns do not get you much extra for your money in a home environment because it is acting more like a bandpass when you get down bellow the midrange. So it may not be worth the cost and effort....
there used to be some Lambda Unity Horns that you could possibly find used but for the most part I have seen DIY attempts and build them.
I also read on DIYaudio.com that a properly designed Unity will get your down to 220hz in the horn which is really all you need as below that your have the Schroeder frequency of your room.
Trying to enjoy the simple things in life.
Steam: madbrayniak
Kimeran is offline
post #76 of 81 Old 05-09-2013, 09:38 AM
Mark Seaton's Avatar
Quoted: 642 Post(s)
Liked: 1727
To be clear, Tom didn't design the Yorkville U15/215 speakers. They license and utilize his patent in their design. He gave some input, but the final speaker was designed by a rather talented designer at Yorkville. The Synergy patent is an improvement over the original Unity design, both of which are scalable from 2 way to any number of drivers. Neither are limited to just HF/mids nor all speakers in the horn. The TD-1 was a 3 way Unity design with the 12" woofers also loading into the horn through specifically placed holes.
How low the horn goes depends entirely on the size/shape of the horn, the location of the drivers and the driver parameters.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #77 of 81 Old 05-09-2013, 10:10 AM
MKtheater's Avatar
Liked: 1238
Thanks Mark, I knew he had a hand in it but to me this just tells me the synergy horns are worth it over the Yorkville. They advertise designed by Tom Danley after all.
Marantz 7702 Atmos
post #78 of 81 Old 05-09-2013, 11:33 AM
Reddig's Avatar
Quoted: 201 Post(s)
Liked: 366
Hey Coach mind sharing how much your picking up the used Yorks for?biggrin.gif
If not I understand. No biggie.
JBL Pro Cinema
MANCHESTER UNITED!!
Reddig is offline
post #79 of 81 Old 01-12-2016, 09:33 AM
Skylinestar's Avatar
Quoted: 1175 Post(s)
Liked: 213
Most would say the Yorks have a better bottom-end with a larger soundstage overall, and the 212's would have a more "Crisp" upper end and extension.
What? The Yorkville U215 sounds larger than the JTR 212?
Skylinestar is offline
post #80 of 81 Old 01-12-2016, 06:00 PM
N8DOGG's Avatar
Quoted: 1094 Post(s)
Liked: 1195
I would say so for sure. The dual 15s can put out some serious bass.
N8DOGG is offline
post #81 of 81 Old 01-12-2016, 07:14 PM
Jeff Permanian's Avatar
Quoted: 803 Post(s)
Liked: 1702
Wow, old thread.
I wouldn't say "for sure". There is a lot that goes into a speaker. When comparing speakers you need to look at port area, the port shape, driver's xmax, sensitivity, max output, and so on. Also, how all the specs came to be? Data-Bass measured the N212 at +130db longterm (above 60hz) and +136db peak (within CEA2010 distortion limits).
Jeff Permanian is online now
