RSS390HF 22" cube build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-11-2012, 03:07 AM - Thread Starter
djdcm0722's Avatar
First off I wanted to thank everyone here for their input's and teaching me a little something about speaker building. This is my first project. 22" cube, double baffle, 4.3 ft^3 cube with a Dayton 15" HF. The final box didn't turn out as good as I would have liked. Only having a borrowed jigsaw, some cargo straps and some sand paper and files, I think it turned out pretty decent.
Crown XLS 1000 and the driver
3/4" MDF
Gluing of the box
Front baffle glued on and painted
Black ash vinyl applied. Magnetic grill guides are behind the vinyl
Dry fit of the sub woofer
The driver hole is a little uneven due to having to use a file to round it out further. I will also be drilling the holes for the driver later this week. There are also a few defects in the vinyl having not sanded perfectly (the vinyl shows every little defect on your wood) but all in all turned out pretty well. I haven't had a chance to listen to it. My amp was DOA and the cable I got from monoprice won't mate with the NL2MP connector I had bought so I had to order the 4 pole and ordered another amp while this one is being sent back to Amazon. Both should be here in a week.
Still working on the best way to stretch the fabric on the grill using partsexpress grill guides.
I figure once I get stationed back in the states I'll invest some money in power tools and redo the box.
Once again thanks everyone for all your help. Once I get the grill finished I will post up some pictures. Of the final product.
djdcm0722 is offline
post #2 of 6 Old 03-11-2012, 04:02 AM
speckled hen's Avatar
great job buddy!!!
speckled hen is offline
post #3 of 6 Old 03-11-2012, 07:33 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
How do you like the finished result of the vinyl? Is that the PSA type like from PE?
Does it look nice?
NicksHitachi is offline
post #4 of 6 Old 03-11-2012, 08:45 AM - Thread Starter
djdcm0722's Avatar
Does it look nice?
Yes it is the stuff from PE. I think it looks great. Very similar to the finish on my Paradigm Monitors. Only thing is it is very thin so any little defect will show through. Very easy to apply as well.
post #5 of 6 Old 03-11-2012, 11:32 AM
DiscoDuck's Avatar
Quoted: 14 Post(s)
Looks great for a first build
Sr7009 + external amp for 9.3.4
jbl - northridge x11; sp6cii ceiling
Dayton HF15 sealed x2 on xls1500
av123 mfw15 w/ bash 300
DiscoDuck is offline
post #6 of 6 Old 03-11-2012, 11:40 AM
ovrrdrive's Avatar
I love the idea of the magnetic grill guides being behind the vinyl for the stealth look. Looks nice.
ovrrdrive is offline
Dayton Audio Rss390hf 4 15 Reference Hf Subwoofer 4 Ohm
