Filling countersink holes in MDF - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-15-2012, 09:33 AM - Thread Starter
Subjga's Avatar
So I have a lot of countersink holes with screws on the outside of my MDF sub. How can these be filled-in and still eventually achieve a shiny look at the end of staining and polyurethane?
Subjga is offline
post #2 of 12 Old 03-15-2012, 09:52 AM
lowpolyjoe's Avatar
I think Bondo auto-filler is the best bet. I've used it several times and it's often recommended on the forum. It's available at Home Depot near the Caulking section. Drawback is that it STINKS and i think the fumes are dangerous My wife goes crazy when i use it because the garage is uninhabitable for a day or two.
Wood putty might be ok too, but i'm not sure how well it bonds to the primarily metal (screwhead) surface inside the divot. I've used it before but i can't remember how happy i was with it.
Last year i tried using drywall spackle after reading about it somewhere.... my goal was the same as yours, to get a nice smooth painted finish. DONT DO IT. It's far too fragile and after painting over it, i bumped a speaker when carrying it through a doorway and it dented the spackle under the paint and made a big ugly mess.
Good luck,
Joe
lowpolyjoe is offline
post #3 of 12 Old 03-15-2012, 10:59 AM
cecaa850's Avatar
Bondo is an awesome filler for MDF, after it's sanded, you can't feel the patch. I don't know about it's ability to take stain, I normally use paint or bedliner material.
120@20@14'
cecaa850 is offline
post #4 of 12 Old 03-15-2012, 11:36 AM
lowpolyjoe's Avatar
Oops. My bad. I thought you were painting. For staining I don't know what you can use. Maybe wood glue and Mdf dust mixture? Don't know how that would stain either tho
post #5 of 12 Old 03-15-2012, 12:18 PM
DonH50's Avatar
Quoted: 1790 Post(s)
Liked: 1324
The usual solution is to use a plug tool/bit to make plugs from scrap MDF that you glue in the holes. You have to use just a drop because glue on the outside won't stain well. You can also buy plugs from various woodworker suppliers.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #6 of 12 Old 03-15-2012, 01:30 PM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Dont use drywall compound hahaha my cabinets look like the have bad acne
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
post #7 of 12 Old 03-15-2012, 03:17 PM
ovrrdrive's Avatar
Yeah if you're staining plugs are the only sure bet...
My only question is how are you staining mdf? People stain that stuff?
I used wood putty on mine and it said it was ok to stain, but even if it was you would still see a difference. I painted so it worked out great.
ovrrdrive is offline
post #8 of 12 Old 03-15-2012, 04:12 PM - Thread Starter
Subjga's Avatar
Thanks guys.
Been reading a lot about staining. I was thinking of oil-based stain, then spray painting the edges black. Someone sent a link for one that looks awesome.
I'm not opposed to just painting it. How do you do that?
What type of paint? Sealer first, last, or not at all? Primer? Or just spray paint?
Subjga is offline
post #9 of 12 Old 03-15-2012, 05:15 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
I have used steel filled 5 minute epoxy before
Originally Posted by Subjga View Post
Thanks guys.
qguy is offline
post #10 of 12 Old 03-15-2012, 07:53 PM
ovrrdrive's Avatar
Thanks guys.
I just got a quart of krylon satin black acrylic latex enamel from walmart and a foam roller and went to town on mine and it actually turned out pretty well. I filled everything I could and sanded for about 4 hours on the box first and rolled it right on. I think I put about 4 coats on it.
It's nothing special but it fits right in with my speakers.
post #11 of 12 Old 03-15-2012, 11:05 PM - Thread Starter
Subjga's Avatar
Man, that's a sweet looking sub!
I read somewhere it's better not to sand the smooth part of the MDF. Did you sand the whole thing, or did you mean sand between layers?
Subjga is offline
post #12 of 12 Old 03-16-2012, 03:18 AM
ovrrdrive's Avatar
Oh mine was plywood. I sanded all of it. I was just showing you the paint.
In theory it would look the same no matter what was under it.
