80 degrees out in NY? Its project day! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 41 Old 03-18-2012, 08:52 AM - Thread Starter
WiSounds's Avatar
I'm finally home from some travels, so it is project day!
I have to load my open back mid cabs and HF horns. I am debating on painting them as well because it is such a nice day out.
The mid cabs will be loaded with 4 Sundown NeoPro 8".
I also have to head up to Niagara falls this week to see how much it would be to get this 15" basket chromed:
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #2 of 41 Old 03-18-2012, 10:06 AM - Thread Starter
WiSounds's Avatar
I'll be loading one cabinet with a pair of the NeoPro8s, and the other with the pair of B&C8s from my previous top design. I'll have a little listen-off and see which way it goes. The B&C have completely unsuitable specs for open back like this however.
WiSounds is offline
post #3 of 41 Old 03-18-2012, 10:13 AM
Steve_Vai_rules's Avatar
Me likey!!
"The main reason Santa is so jolly is because he knows where all the bad girls live." - George Carlin
Steve_Vai_rules is offline
post #4 of 41 Old 03-18-2012, 11:25 AM - Thread Starter
WiSounds's Avatar
Hmm, hooked up one of my LMS-R 12" enclosures for bass while I work on the other cabs and found a horrendous rattle. Seems the entire suspension has become detached from the frame.
Normal:
Mine:
Emails are going out :/
WiSounds is offline
post #5 of 41 Old 03-18-2012, 11:33 AM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 161
Wow....that sux.
80??? No fair.... 36 with snow in the forecast here... You take some of that AZ weather back home with you???
lilmike is offline
post #6 of 41 Old 03-18-2012, 01:06 PM - Thread Starter
WiSounds's Avatar
Apparently
First completed project was making some 1x1 standoffs for the adapter plates. I figured why not use them as grilles too. They don't look as pro as I would like, but they are very functional.
WiSounds is offline
post #7 of 41 Old 03-18-2012, 01:44 PM
kgveteran's Avatar
Quoted: 373 Post(s)
Liked: 131
yup, mid to high 70's northwest of the city . Sushi lunch is coming soon !
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #8 of 41 Old 03-18-2012, 05:10 PM - Thread Starter
WiSounds's Avatar
Got the HF horns done:
On to the mids. I'll next be mounting a pair of B&Cs and a pair of Sundowns, and comparing them for SQ and output.
WiSounds is offline
post #9 of 41 Old 03-18-2012, 07:48 PM
Viperoni's Avatar
I got LCR cabinets cut up and screwed together for the Stentorians, with any luck I'll be able to route the holes later this week.
Absolutely gorgeous weather, we broke daytime highs up here near Toronto.
Viperoni is offline
post #10 of 41 Old 03-18-2012, 08:52 PM
noobzorta's Avatar
Did you free-air your LMS-R? I managed to beat the crap out of mine tonite with some rew sweeps, and also managed to break the glue on the VMP-12. Not sure if i bottomed the lms out though. Did your vc former looked like someone bent over the end of it? I compared pictures of new vs now, and it looks the same.
Interesting grill idea, not super pretty but works good lol.
noobzorta is offline
post #11 of 41 Old 03-18-2012, 08:56 PM - Thread Starter
WiSounds's Avatar
The LMS-R was in a slot ported enclosure, and barely used. I have never had a driver do this before.
WiSounds is offline
post #12 of 41 Old 03-18-2012, 09:01 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5339 Post(s)
Liked: 4226
Nice gear, Wi. I especially like the open cab for the horns. I will be building something very similar for my JBL 2380's soon enough.
Scott Simonian is offline
post #13 of 41 Old 03-18-2012, 10:17 PM - Thread Starter
WiSounds's Avatar
First step of the mids part of the project was to load up a pair of B&C 8MDN51, and pair of Sundown NeoPro8 and give a heads up comparison in the same cabinets. The Sundowns are built more for IB midbass applications, and the B&C for ported alignments so the resulting SQ edge to the Sundown is not completely surprising. The NP8s sound exceptionally good in this configuration. These run 300-3.8k:
After the Sundowns won that comparison, I put them up against the previous sealed alignment to ensure I was indeed making progress. The advantage of the Sundown was quite significant in articulation, timbre, and dispersion:
So time to load up the 4 drivers and get them looking right, and install handles and feet:
Then I started cutting grilles. I have an idea or 2 for these on how to finish them, but that part is TBD:
This is the look I am starting to go for with semi final revision cabinets, the recessed flat front grille to hide the business end of things a bit.
The highs, mids, kicks on the sub:
Nice little glam shot of the NeoPros:
I had built the mid cabs to have the same dimensions as the highs, but I may someday build another set at the same width, but squeeze down the vertical dimension to the frames. Even fully assembled the mid cabinet is lighhhhhhhhhhht. .5 BB a handle and some feet are mint. I took a major leap of faith building these open back, and it paid off.
Once I get the 18Sound 21" and the grilles figured out I will be taking measurements with REW.
The B&C 8MDN51s are up for sale if anyone needs a set of 4. PE is $165ea, I'll take $135ea or $500 for the 4 plus shipping. If no one takes them I may turn them into a pair of high efficiency ported monitors.
WiSounds is offline
post #14 of 41 Old 03-21-2012, 11:28 PM - Thread Starter
WiSounds's Avatar
Today I got some Auralex pyramids and had a few ideas for damping the open back mids. I was able to fit a piece perfectly behind the drivers:
Running 300 up, this may help absorb any box reflections, but could it also make them behave like they are in an enclosure?
Also, on teh front of the cabinets there is the flat space where the baffle angles, and I can place 6 pyramids there like so:
Or I can cut it to 4 and place it in the corner. Think these are beneficial or excessive?
I plan to take measurements Friday. I'll test a couple of sub drivers and the new mid cabs with and without the damping.
I am taking delivery of a SoloX 18 for the other subwoofer cabinet, as well as the other 18Sound 21 and Zv3 18 should be here before the show on April 14th. I threw them all on a graph for kicks, and the results are pretty consistent:
Attachment 241305
WiSounds is offline
post #15 of 41 Old 03-22-2012, 07:28 AM
Jason kiDD's Avatar
Quoted: 23 Post(s)
Liked: 25
Which horn drivers are you using and what are your impressions?
Jason kiDD is offline
post #16 of 41 Old 03-22-2012, 08:48 AM - Thread Starter
WiSounds's Avatar
Selenium D3305ti:
http://www.parts-express.com/pe/show...number=264-226
They rock, loud and clean and soak up quite a bit of power.
WiSounds is offline
post #17 of 41 Old 03-22-2012, 09:27 AM
BP1Fanatic's Avatar
Is the sub in the stack the same sub in the SoloX 18 thread?
BP1Fanatic is offline
post #18 of 41 Old 03-22-2012, 09:55 AM - Thread Starter
WiSounds's Avatar
Yep, I built a pair of the sub cabinets, one will have the B&C 21" and one will have an adapter plate with the SoloX in it for this weekend. I have a renegade park show on Sunday, but that is for another thread
I'll have the B&C 21", the 18Sound 21", and the SoloX 18", and whichever one measures the best in the cabinet I'll pick up a mate for so the cabs match.
WiSounds is offline
post #19 of 41 Old 03-22-2012, 10:52 AM - Thread Starter
WiSounds's Avatar
Any thoughts on the Auralex damping?
If I have time Friday I'll try and take measurements with and without.
WiSounds is offline
post #20 of 41 Old 03-22-2012, 11:07 AM
pwz414's Avatar
Wi, I didn't know you picked up a B&C! How's it sound?!
pwz414 is offline
post #21 of 41 Old 03-22-2012, 11:09 AM
pwz414's Avatar
I should sent you a Misco! You could measure them A B.
pwz414 is offline
post #22 of 41 Old 03-22-2012, 11:10 AM - Thread Starter
WiSounds's Avatar
So far so good, we'll see how it measures in my cabinet.
I'd like to measure an isobaric pair of Miscos in the 2 different 21" cabinets I have built.
WiSounds is offline
post #23 of 41 Old 03-23-2012, 09:05 AM - Thread Starter
WiSounds's Avatar
Got my MDF adapter plate made for the SoloX:
Today should be a good and busy day!
WiSounds is offline
post #24 of 41 Old 03-23-2012, 09:38 AM
pwz414's Avatar
Have fun
pwz414 is offline
post #25 of 41 Old 03-23-2012, 03:47 PM - Thread Starter
WiSounds's Avatar
First thing I put my amp rack together today:
I made a fancy speakon termination plate that makes it a snap to hook up the system:
And prepped the other sub enclosure by building a 1.5" thick MDF adapter ring:
Some sanding, round over, and gasket, and the cabinet is ready for the SoloX 18:
I also finished cutting the grille material for the top cabs:
I'm on my way out the door to pick up the SoloX 18, and hopefully have it running tonight. There may be a bit of a mounting challenge as it has a few pieces, but I'll sort it out.
I'll have a thread with pics and video from Sunday's show with all this stuff out and going.
WiSounds is offline
post #26 of 41 Old 03-23-2012, 03:51 PM
Bass Enabler
Liked: 4226
post #27 of 41 Old 03-23-2012, 06:12 PM - Thread Starter
WiSounds's Avatar
Picked it up! This picture doesn't do it justice:
This one helps a little, immense motor:
WiSounds is offline
post #28 of 41 Old 03-23-2012, 07:16 PM
PassingInterest's Avatar
Quoted: 181 Post(s)
Liked: 493
My, what tiny hands you have.
Oh wait, scratch that.
Looking fantastic, as always Wi!
PassingInterest is offline
post #29 of 41 Old 03-23-2012, 10:04 PM - Thread Starter
WiSounds's Avatar
When they say almost 100lbs, they mean it. And especially when you have the adventure I just took on.
So just to make sure the thing works properly, I hooked it up freeair and ran some test tones:
At this point I disassembled the driver. It comes in 2 parts. The SPAIR(soft parts) and BAM(Basket and Magnet)
SPAIR:
BAM:
I set the BAM in for the first of probably 6 or 8 times and, oh noes:
It isn't the adapter ring that is creating the issue:
I reached an impasse, I thought about this for a solid 10 minutes and decided since it was a prototype cabinet screw it. I can always make another round adapter plate. This part pains me quite a bit, but it needed to happen:
In goes the BAM, finally fits:
Since I wasn't able to use the corner mounting holes, I sealed them with a bit of gaff tape on the underside of the basket:
SPAIR loaded and ready to try out!
I had a small issue when I turned it on for the first time. At low volumes I had a nasty rub, turn it up and it went away. Off comes the SPAIR again and I found that there is a bit of play between the SPAIR and BAM. A gentle push on the cone will indicate if everything is aligned properly. If not, tweak it a touch and try again. When hooking it back up, I dropped the jumper wire to series the voice coils all the way down to the bottom of the enclosure, no way to reach that one:
To the rescue, a paint stick and duct tape:
Rewire the SPAIR and set it back in:
Now, she is ready. No more rub:
The pair of stacks finally operational and ready for Sunday:
It was late when I finished for the day so no large signal testing, and I was unable to measure anything today, but I did manage to get everything ready to go for Sunday, load em up and go.
WiSounds is offline
post #30 of 41 Old 03-24-2012, 11:45 AM - Thread Starter
WiSounds's Avatar
Before I lef
WiSounds is offline
