4 LMS 5400s in my enclosures. Doable? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 79 Old 03-23-2012, 12:51 AM
LINEARX's Avatar
I ran my LMS facing up for 6 month's with no noticeable problems. Mine has the titanium cone, slightly heavier.
LINEARX is offline
post #32 of 79 Old 03-23-2012, 07:44 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
TC actually spec the new ones at 47.6 mm and the old ones were 44mm. I always thought it seemed a little generous but never actually checked. 42 it is.
Ricci is offline
post #33 of 79 Old 03-23-2012, 08:16 AM - Thread Starter
pwz414's Avatar
Thanks, LINEARX
Yeah, Scott, I was worried too. I still am a bit worried actually. You can still hear faint mech noises from the spider area in some drivers more than others. One driver developed a bit of a scrape/clack when I tilted it a bit to clear the pole vent. I was so tired at that point I just said F' it and went to bed.
Even if all the drivers are good I'm a bit concerned that 1KW per driver will be too little. These things soaked up 250W free air with less than an inch of excursion at around 40Hz and clipped my Model Three. I moved them to my Hypex at 400 W and got just a couple Db more before that clipped. My Crown will do 1KW per driver all day long, but if it's clipping the drivers are at risk and that's just not acceptable.
pwz414 is offline
post #34 of 79 Old 03-23-2012, 08:46 AM
notnyt's Avatar
Quoted: 2152 Post(s)
Liked: 1981
Yeah apparently the spider support is shorter in the new ones. I'd worry about bottoming out the VC at that point though. I think I'd rather have the cone bottom on the spider support. Either way, at that excursion level, its like 1db difference if that. If the old ones were listed at 44, its possible. My measurement methods weren't the greatest.
However, I did notice on the forward stroke that I was only seeing about 33mm of movement before bad clanking noises on the back stroke. I wonder how linear things are at that level. I tested the same thing on 3 drivers and same result each time.
notnyt is offline
post #35 of 79 Old 03-23-2012, 11:53 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
Originally Posted by pwz414 View Post
Thanks, LINEARX
The big issue with this post is bolded above. Long throw drivers dont bottom out at 40Hz. Move that down an octave...
Ricci is offline
post #36 of 79 Old 03-23-2012, 12:56 PM - Thread Starter
pwz414's Avatar
It didn't bottom out. It was barely moving and it made a scrape/clack sound. I barely would have heard 20Hz. It was a clearly audible signal and it clearly scraped. I said to myself, this is BS and went to bed. I'll check again today.
pwz414 is offline
post #37 of 79 Old 03-23-2012, 01:34 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
that wouldnt be clipping then, but perhaps something that is lodged down in the motor structure, or possible the motor shifted and is not centered.
beastaudio is offline
post #38 of 79 Old 03-23-2012, 01:43 PM - Thread Starter
pwz414's Avatar
We're talking about two different occurrences. I apologize if that's not clear. The clipping occurred with different drivers (still LMSU's).
While we're at it. I see a flat spot on this coil. The shipping boxes were in pristine condition; even the motors.
I can sense where this is going. "The newb over punted his coverage and doesn't understand the intricacies of the LMS-U."
There is distortion emanating from the spider area of at least one driver at very low output levels, another driver scrapes when I tilt it, and the third appears to have a flat spot on its voice coil. There are high and low spots in every surround. However, none of the drivers exhibit scraping during manual manipulation.
pwz414 is offline
post #39 of 79 Old 03-23-2012, 02:16 PM - Thread Starter
pwz414's Avatar
Are you saying you're more concerned about them being under powered in the lower frequency range? Clipping can also cause thermal damage, right? So even at higher frequencies the clipping could result in the VCs getting too hot without the drivers bottoming out.
pwz414 is offline
post #40 of 79 Old 03-23-2012, 07:44 PM - Thread Starter
pwz414's Avatar
Thankfully I can't reproduce the scrape I'm not worrying about these things anymore until the enclosures are ready.
pwz414 is offline
post #41 of 79 Old 03-25-2012, 10:52 PM - Thread Starter
pwz414's Avatar
One cabinet is up and running. These things soak power! They sound nice though. My eq is set opposite to what they need. Boosted low and trimmed high.
Will these things be a little more efficient after break in?
No nasties, other than the room of course. One cabinet is equal to both cabs containing the 21s in the low end, but less efficient above about 40. To be expected.
Thanks for the help in deciding. I'm sure they'll just murder movie tracks.
pwz414 is offline
post #42 of 79 Old 03-25-2012, 11:22 PM
WiSounds's Avatar
Pics! Glad you got a couple of them up and running...
Originally Posted by Bill Fitzmaurice:
It's also the very sort of Voodoo Engineering that should never be done.
WiSounds is offline
post #43 of 79 Old 03-26-2012, 07:57 AM - Thread Starter
pwz414's Avatar
Here are some pics. Now my primary concern will be responsible break in and room treatments. We've just installed tile floors, the windows and heat exchangers rattle, but other than that the room has some nice perks. The lines run almost to the ceiling, room gain is high, and the subs have concrete on two/three sides (not yet, was floating near the center of the structure last night during play time).
The Crown will clip easily with two of these per channel. It is seemingly more likely to do so in higher frequencies. The infrasonic T Rex stuff from "The Fantasy Adventure Album" and the low stuff from Xzibit are nowhere near clipping, were as punchy stuff like Black Rob: "Whoa" and kick drums are more likely to clip. Interesting stuff.
Do you guys think when these things loosen up they be a little easier to drive?
pwz414 is offline
post #44 of 79 Old 03-26-2012, 11:25 AM
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
After a few weeks of use, i had to turn mine down a bit so that they were level matched again. They definitely loosened up for me.
edoggrc51 is offline
post #45 of 79 Old 03-26-2012, 02:46 PM - Thread Starter
pwz414's Avatar
Good to know. The 21s were a bit quicker to clip the Crown at first, but that stopped almost entirely over a couple months. They sounded dramatically better and more effortless after a bit of time too.
pwz414 is offline
post #46 of 79 Old 03-26-2012, 11:03 PM
WiSounds's Avatar
Did you use the 10-19hz to break them in at all?
WiSounds is offline
post #47 of 79 Old 03-27-2012, 07:31 AM - Thread Starter
pwz414's Avatar
No, the basement is under construction. People, traffic, and particulates everywhere. The only amp that will tolerate the sustained 2 ohm load is restricted to the basement by power requirements. I didn't feel comfortable leaving them unattended down there. When construction is finished I'll take them out a couple at a time and give them a couple hours of break in.
pwz414 is offline
post #48 of 79 Old 03-27-2012, 07:44 AM
WiSounds's Avatar
They are d2, should be able to do series them 4 ohm stereo. 50v should be adequate. Do a pair at a time
WiSounds is offline
post #49 of 79 Old 03-27-2012, 09:38 AM - Thread Starter
pwz414's Avatar
Yeah, you're right. I'll figure something out. Don't you get nervous at the thought of leaving them unattended?
pwz414 is offline
post #50 of 79 Old 03-27-2012, 10:01 AM
WiSounds's Avatar
No worries once you set it up. Just be sure to secure them, and learn from my mistake... don't hang them from the ceiling. I have let drivers run for a couple of days before. Once you set a safe but effective voltage level just let them settle in.
WiSounds is offline
post #51 of 79 Old 03-27-2012, 10:11 AM - Thread Starter
pwz414's Avatar
How much excursion on the lowest AF?
pwz414 is offline
post #52 of 79 Old 03-27-2012, 10:21 AM
WiSounds's Avatar
I'll usually set it up to a couple of gain knob clicks below the start of mechanical noise for clean stroke, and then double check voltage. Some say 30v at 20 hz is enough but it all depends on amp and woofer combo.
I use the 10-19 bit I sent you and one of my old FTX-2001 for break in, it can do 1kw at 8ohm mono so it does the job.
WiSounds is offline
post #53 of 79 Old 03-27-2012, 10:49 AM
Point Source
beastaudio's Avatar
Liked: 2826
At those frequencies the excursion is enough to basically "self-cool" the sub even if you leave it in the box. I usually run a solid 20hz sine to break in. Wi, what file is that that you run 10-19hz?
post #54 of 79 Old 03-27-2012, 10:57 AM
WiSounds's Avatar
PM me your email
WiSounds is offline
post #55 of 79 Old 03-27-2012, 11:53 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
downfiring these drivers long term I am not so sure about. I've never done it but I would avoid it if I could. the assembly weighs over 500 grams so you would have to assume that over time that weight will eventually pull the suspension away from center.
Ricci is offline
post #56 of 79 Old 03-27-2012, 01:17 PM - Thread Starter
pwz414's Avatar
Thank you very much, Ricci
pwz414 is offline
post #57 of 79 Old 03-29-2012, 09:55 AM - Thread Starter
pwz414's Avatar
If these boxes are halved to accommodate a front facing vertically mounted alignment, how much bracing should be added? The internal dimensions would be 27” x 27” x 16.5”.
In this position they would have 6" between the pole vent and the rear panel.
They will be laid on their sides for a period of time before committing to cutting.
The positioning advantages of four "small" enclosures are exciting, but the thought of losing the noise cancelling of dual opposed sucks.
Thoughts?
pwz414 is offline
post #58 of 79 Old 03-29-2012, 10:01 PM - Thread Starter
pwz414's Avatar
Holy s***!
pwz414 is offline
post #59 of 79 Old 03-29-2012, 10:23 PM
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Holy s***!
Huh???
post #60 of 79 Old 03-29-2012, 10:28 PM - Thread Starter
pwz414's Avatar
These things are ridiculous.
pwz414 is offline
