Normal to turn sub all the way up for music? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 03-20-2012, 06:00 AM - Thread Starter
djdcm0722's Avatar
Just recently finished my 15" HF build and have a question. I have the sub hooked up to a XLS1000 (which is dead silent, thanks for the suggestion over the Behringer). The gain is turned to max on the amp. When listening to movies with a LFE track the subwoofer is set to -12 on the avr per Audyssey settings. There is more than enough bass to get things shaking. However, when listening to 2 ch music I have to bump the sub up to +7 to +12 to get it to hit hard. Is this normal? At -12 the sub doesn't even move. I listen to everything through a HTPC using XBMC and have tried playing audio in Winamp. Same issue.
djdcm0722 is offline
post #2 of 24 Old 03-20-2012, 06:04 AM
Bill Fitzmaurice's Avatar
Liked: 5620
Movie LFE tracks tend to be mixed at higher levels than music.
Bill Fitzmaurice is online now
post #3 of 24 Old 03-20-2012, 08:11 AM
Point Source
beastaudio's Avatar
Quoted: 4001 Post(s)
Liked: 3308
Funny that I get the exact opposite. where is your sub crossed over to your mains?
FS: BossoBass A-14K amplifier
beastaudio is online now
post #4 of 24 Old 03-20-2012, 08:16 AM
Wrager's Avatar
Quoted: 193 Post(s)
Liked: 114
I too notice a large drop in bass when listening to music. That's why I loved the SMS-1 with the preset feature. Unfortunately it won't effectively handle multiple subs in multiple location...so onto the MiniDSP.
Wrager is offline
post #5 of 24 Old 03-20-2012, 08:25 AM
Kal Rubinson's Avatar
Quoted: 748 Post(s)
Liked: 520
You guys either just like a lot of bass or you are so used to the boom of room modes that you think it is part of the music. There is no loss of bass with Audyssey (assuming you did it right). There is the elimination of modal peaks and a flattening of the FR. If you prefer otherwise, that's your prerogative.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #6 of 24 Old 03-20-2012, 10:29 AM
Point Source
beastaudio's Avatar
Liked: 3308
This is quite true, the normal response you are used to in a decent car audio setup is peaky and usually has a nice spike around 40-45hz IIRC to accentuate the bass notes, it may be you are just listening to nice flat bass for once. Then again, you may not like it
post #7 of 24 Old 03-20-2012, 10:34 AM
notnyt's Avatar
Quoted: 2651 Post(s)
Liked: 2426
I run my subs way hot for lots of music.
notnyt is offline
post #8 of 24 Old 03-20-2012, 11:42 AM - Thread Starter
djdcm0722's Avatar
Subs low pass is @ 80hz and the speakers at 60hz and 80hz. I listen to a lot of electronic and rap so they are very bass heavy. Before the sub I would still have to boost the bass to get the effect I wanted with music. I was just suprised that now having a sub I have to boost it so much. I am also sure I ran Audyssey right as I said earlier movies play fantastic.
As a side note, I have The Walking Dead from iTunes which is 2ch AAC and the bass is decent at -12. So maybe it is an issue with the FLAC and MP3 codec?
post #9 of 24 Old 03-20-2012, 12:06 PM
Point Source
beastaudio's Avatar
Liked: 3308
I use a low level "restorer" function on my denon 3311 to bring back some of the low end. This seemed to help a lot getting the bass back into the music, and isnt boomy or as an intense raise as something like dynamicEQ would do. Perhaps also your sub sets up differently when you are in 2ch stereo mode. I know on my AVR that there is a seperate place to adjust for 2 channel playback completely seperate from the audyssey and standard XO and adjustments menu.
For instance, I COULD set my receiver to not use a sub for music and to switch my L/R's to full range, but when I switch back to dolby or other multichannel modes, it switches the mains back to be LP'd at 80hz and the sub to come back on... There are other combinations that could contribute to not hearing as pronounced bass. I know this specific example above isnt what you are experiencing since when you turn the sun up, it gets louder. If the above were true, that wouldnt happen.
Im just saying perhaps peruse around your AVR menus to make sure you arent missing somthing in stereo mode.
post #10 of 24 Old 03-20-2012, 12:25 PM
Gooddoc's Avatar
Quoted: 3017 Post(s)
Liked: 2253
Of course you do. There's no way you could stare at that wall of drivers and not. Just looking at it in photos is enough to induce a trance-like state that has me reaching for the remote to turn it up:-)
Gooddoc is online now
post #11 of 24 Old 03-20-2012, 01:10 PM - Thread Starter
djdcm0722's Avatar
Will do. Its not a big deal to have to turn the sub up. I was just curious to know if something was messed up. I'll play around with it later tonight and see what I come up with.
post #12 of 24 Old 03-20-2012, 04:17 PM
DustinF's Avatar
Quoted: 47 Post(s)
Liked: 65
What software are you using to watch the movies? Perhaps it has its own gain control that is separate from the system.
Have you tried listing to music from another source?
DustinF is offline
post #13 of 24 Old 03-20-2012, 05:51 PM - Thread Starter
djdcm0722's Avatar
I use XBMC for movies. Define "other source". As in another player? I have tried in Winamp as well as MPC and same same results. Haven't tried in iTunes and probably won't as I use XBMC for everything. Having to turn up the bass for music isn't a big deal. More of a minor annoyance.
post #14 of 24 Old 03-20-2012, 05:55 PM
N8DOGG's Avatar
Quoted: 1094 Post(s)
Liked: 1195
If you are playing mp3's and stuff like that, they generally take a hit in the low end department vs flac or any other type of lossless music. I know on my system, flac is good but mp3's do sound pretty crappy even at 320kbps.
N8DOGG is offline
post #15 of 24 Old 03-20-2012, 07:31 PM
Audiophile34's Avatar
I totally agree I notice a huge difference when playing from Cd/vs mp3.
My first DIY project. A dual, dual opposed setup
www.avsforum.com/avs-vb/showthread.php?t=1345494
Audiophile34 is offline
post #16 of 24 Old 03-20-2012, 07:57 PM
notnyt's Avatar
Liked: 2426
Was just listening to some justice remixes... just dance remix with mos def at 0db with +21db of subwoofer boost. good times.
notnyt is offline
post #17 of 24 Old 03-20-2012, 08:00 PM
if you can boost +21db, then you must be a God, oh wait, this is notnyt, he is, THE God.....
bowing in honor..
post #18 of 24 Old 03-20-2012, 08:08 PM
notnyt's Avatar
Liked: 2426
bowing in honor..
Doesn't really mean anything, as you don't know what the peaks in that track are at... but still, it's a lot =]
notnyt is offline
post #19 of 24 Old 03-20-2012, 08:24 PM
MKtheater's Avatar
Quoted: 1706 Post(s)
Liked: 1238
Depends on the source or CD. I play a CD and 0 dBs would usually hit peaks of 108 dBs from the speakers so 129 dBs if 21 dBs hot. Basically you should be getting ear plugging up sensations that loud.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is online now
post #20 of 24 Old 03-20-2012, 09:21 PM
N8DOGG's Avatar
Liked: 1195
129dB's isn't ear plugging! Thats just barely getting things going!!
N8DOGG is offline
post #21 of 24 Old 03-21-2012, 01:18 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1139
I've never ever felt the need to increase the bass once the system is well set up, for music. However, it may be in part a genre thing for some. Some of the links I've seen to demo music I wouldn't listen to. Probably wouldn't even define some of it as music.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #22 of 24 Old 03-21-2012, 03:36 AM - Thread Starter
djdcm0722's Avatar
Figured out the problem. Played around with the crossover settings on the speakers and they were crossed way to low. Bass is much louder now. I still have to run it a little hot for music but that's how I like it
post #23 of 24 Old 03-21-2012, 10:14 PM
BassThatHz's Avatar
Quoted: 2296 Post(s)
Liked: 2038
Pro-audio is more regulated to known values than "home audio" equipment.
So in pro-audio terms, my DEQ2496 runs between -3 and -6db from 0Ref on peaks in +15dbu mode.
To that, my input structure on my Itech-8000 is 36.9db/1.86Vrms in +15dbu mode, I then apply a 29db eq boost below 200hz, with an input gain of -20db for music and -32db for movies.
But it all cases, the input stages and output stages (almost) never clip (ideally).
So I guess you could say that I'm running roughly ~12db hot for music.
But really...
The only thing that truely matters is the output voltage and amperage.
The upstream input stuff is just a means to an end, and may at-best, only indicate how close to clipping the input or output stage you might be on dynamic material (potentially). Each system will be different because we all use different electronics with different gain structures, reference values and sensitivities etc; so comparing them is almost meaningless.
As I said, you'd be better to put a voltmeter on the output of the amp into a known nominal ohm load if you want to have a better chance at comparing apples to apples. (Even then, there is still woofer-T/S differences etc etc.)
BassThatHz is online now
post #24 of 24 Old 03-22-2012, 05:11 AM - Thread Starter
djdcm0722's Avatar
But really...
Thanks for the reply, but honestly... I have no clue what you are saying.
