Ep4000 + 2x eD 13av2's. Questions... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 03-20-2012, 09:02 PM - Thread Starter
Hrimnir's Avatar
Im looking at picking a couple of these drivers up to run in a new home theater in the house my roommate is buying.
I want to configure them in seperate ported enclosures, similar to what the P7-650 sub from eD is.
Basically like a 15x15 footprint, downfiring, and as tall as they need to be for the proper amount of displacement.
What im trying to figure out is if an ep4000 is too much amp for the two of them. I was thinking of running one off each channel, but wasnt sure if i should order them as dual 2ohm or dual 4ohm voice coils.
Klipsch RF-62 L/R, RC-62 C, Energy C-100 SL/SR, HSU VTF-15H, Marantz SR7008.
"All speakers sound good when you're on a coke binge in the middle of an orgy." - Heebdawg16
Hrimnir is offline
post #2 of 18 Old 03-20-2012, 10:01 PM
qx56's Avatar
I would call and ask Alex at ED tomorrow. He would know best.
qx56 is offline
post #3 of 18 Old 03-20-2012, 10:05 PM
notnyt's Avatar
Quoted: 2711 Post(s)
Liked: 2494
These aren't exactly great HT drivers. Any reason you want to run them? If you really want that footprint, I'd suggest using a 15" driver, perhaps one of the SSD XCON 15s or whatever the latest 15" rage is. There are many threads going on, as these drivers will have a good deal more displacement than the 13av.2
As for your question, an EP4000 will be able to bottom them out or smoke the coils if pushed too hard, but you don't have to run them hot. Same with any amp with a lot of power, it's better to have the headroom and not use it.
notnyt is offline
post #4 of 18 Old 03-21-2012, 12:30 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
These are on sale right now making them a pretty good deal. They can handle 1000 watts in a properly designed ported enclosure, the ep4000 puts out 650 x2 @4ohm. You will need something like a minidsp to set a hpf. Output isn't the greatest due to low sensitivity, but it's still good.
Jay1 is offline
post #5 of 18 Old 03-21-2012, 01:12 AM
notnyt's Avatar
Liked: 2494
I've personally roasted a 13av.2 in a sealed enclosure with half of an LT1300. Go figure. If it's on sale though, might be worth it.
notnyt is offline
post #6 of 18 Old 03-21-2012, 01:32 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I can't speak on if they actually meet their rated power handling, but a sealed box can amplify issues as I'm sure you're well aware (Mal-X).
With 1000 watts and an 18hz HPF. 15" x 15" x 50" box with a 1.5" x 13.5" x 33.5" slot port. With 650W it peaks at 20.5mm
Jay1 is offline
post #7 of 18 Old 03-21-2012, 04:56 AM
tgse3's Avatar
I too have owned multiple 13av.2s for HT use. I wouldn't try to use more than 650watts per driver either. Notnyt is referring to the awful sound they make when running out of excursion sealed. At their current price I see no problem purchasing them. Their output gets a little over hyped, but keep in mind they are essentially a 12" driver so don't expect earth rattling output from a tiny package. If you want more output run them ported.
tgse3 is offline
post #8 of 18 Old 03-21-2012, 07:55 AM
MKtheater's Avatar
Quoted: 1717 Post(s)
Liked: 1251
I will let you know as I am testing some out soon. Notnyt ran 120 dB sweeps with them which was probably a bit too much for 4 of them in his room. They do have great displacement for a small driver and the new price makes them much better. I would have never tried them at the regular price due to DIY options but at the current price I am trying them out.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
post #9 of 18 Old 03-21-2012, 09:18 AM
notnyt's Avatar
Liked: 2494
The sweeps of them may have been inaccurate as well not sure.
notnyt is offline
post #10 of 18 Old 03-21-2012, 09:21 AM
MKtheater's Avatar
Liked: 1251
I would agree. According to the specs it would take 2.5 of the 13's to equal one of the LMS5400 as displacement is concerned. Now, there are other factors than just displacement.
Marantz 7702 Atmos
post #11 of 18 Old 03-21-2012, 09:28 AM
notnyt's Avatar
Liked: 2494
They could measure flat to low frequencies in sealed boxes, they just could not get that loud below 35hz without bottoming out. I think if whoever assembles them takes a bit more care with the tinsels, you may be able to avoid some of the noise they make before reaching their xmax.
notnyt is offline
post #12 of 18 Old 03-21-2012, 09:32 AM
MKtheater's Avatar
Liked: 1251
I am trying out a few of them myself to compare against what I have now, it should be interesting. These were designed for small boxes to use their full potential so bigger HT boxes will tax them faster.
Marantz 7702 Atmos
post #13 of 18 Old 03-21-2012, 09:37 AM
notnyt's Avatar
Liked: 2494
It was in eD's own box that I was having issues. I've learned much since then. The subs did well 35hz and above, but lacked displacement for meaningful output below there.
notnyt is offline
post #14 of 18 Old 03-21-2012, 09:58 AM
MKtheater's Avatar
Liked: 1251
I will let you know how they do in my room.
Marantz 7702 Atmos
post #15 of 18 Old 03-21-2012, 09:59 AM
notnyt's Avatar
Liked: 2494
A fart would pressurize your room. Still, I look forward to your impressions.
notnyt is offline
post #16 of 18 Old 03-21-2012, 10:09 AM
MKtheater's Avatar
Liked: 1251
True, but I still lose 12 dBs at my seat from the subs and I am on concrete. The pressure is easy, the moving of the hair and such is not. How much do you lose from the subs to the seats? Also, now with a accurate mic my room gain is about 10 dBs at 10hz .
Marantz 7702 Atmos
post #17 of 18 Old 03-21-2012, 03:40 PM
rlj5242's Avatar
Quoted: 58 Post(s)
Liked: 47
They are definitely a 12" driver. I have four baskets from these subs that I'm making into LMS drivers and Sundown 12" cones fit perfectly.
rlj5242 is offline
post #18 of 18 Old 03-21-2012, 03:56 PM
rr14's Avatar
Quoted: 46 Post(s)
I bought one of the drivers not long ago. Off the top of my head, my internal measurements were 14 by 14 although I don't recall the height. It ended up at around 3 cu ft and was ported to 20hz. I don't have enough amp yet to push it but I will soon. There is definitely a lot deeper output than my 15" crewing vega but that's not much of an example compared to any real sub you'd find on here.
I too modeled mine after the p7-650.
rr14 is offline
