High res LMS 5400 Ultra pics and video(free air to xmax) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-22-2012, 12:30 AM - Thread Starter
notnyt's Avatar
Quoted: 2151 Post(s)
Liked: 1980
Since I had my ultra woofer out to check on clearances for science and such, I figured I'd take some pics and vid with the wife's awesome camera.
So, here is a gallery with 24mp pics of one of these as well as some HD(1080p) video.
PIC Gallery
Video
notnyt is offline
post #2 of 14 Old 03-22-2012, 12:47 AM
scomed99's Avatar
Nice pics and video!
LMS5400 is THE woofer, end!
scomed99 is offline
post #3 of 14 Old 03-22-2012, 01:28 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5278 Post(s)
Liked: 4163
Nice pics and I love the vid. Thanks, Not!
Scott Simonian is offline
post #4 of 14 Old 03-22-2012, 06:49 AM
Kanaris's Avatar
Nice!! If I need some demolition work that will fit in just right.
What kind of camera,Nikon D3x?
Kanaris is offline
post #5 of 14 Old 03-22-2012, 07:58 AM - Thread Starter
notnyt's Avatar
Liked: 1980
notnyt is offline
post #6 of 14 Old 03-22-2012, 09:49 AM
pwz414's Avatar
Nonyt, are the fp14000s forced air? Can you hear them? Based on your setup changes over time I'm guessing you got one for each woofer enclosure?
pwz414 is offline
post #7 of 14 Old 03-22-2012, 09:54 AM - Thread Starter
notnyt's Avatar
Liked: 1980
One per enclosure, yes you can hear them, with fan replacements, they're pretty quiet and not noticeable unless the room is dead silent. You will hear everything in my room, since its treated and there aren't many noise sources.
notnyt is offline
post #8 of 14 Old 03-22-2012, 10:00 AM
pwz414's Avatar
Gotcha. Man, that's a huge investment in low frequency! May I ask what you did to eliminate resonance in your heat exchangers?
pwz414 is offline
post #9 of 14 Old 03-22-2012, 10:02 AM - Thread Starter
notnyt's Avatar
Liked: 1980
Installed them myself and tightened the ***** out of everything. The annoying bit was the window springs. Pulled those out and stuffed em in a closet =]
notnyt is offline
post #10 of 14 Old 03-22-2012, 10:09 AM
pwz414's Avatar
I can imagine! Those things vibrate like no other. Windows and heat exchangers are my big issues. Tile also, ugh. Did you hear noticeable improvements after you put up your wall treatments? I'm thinking of using floor to ceiling drapes.
pwz414 is offline
post #11 of 14 Old 03-22-2012, 10:24 AM - Thread Starter
notnyt's Avatar
Liked: 1980
treatments made a huge difference. The room used to ring like crazy.
notnyt is offline
post #12 of 14 Old 03-22-2012, 03:45 PM
Steve_Vai_rules's Avatar
Drapes will not replace well designed and positioned acoustic treatments.
Matt
"The main reason Santa is so jolly is because he knows where all the bad girls live." - George Carlin
Steve_Vai_rules is offline
post #13 of 14 Old 03-22-2012, 05:21 PM
bodhisafa's Avatar
notnyt,
What kind of wire is that you used on the drivers, linky... please sir.
bodhisafa is offline
post #14 of 14 Old 03-22-2012, 05:38 PM - Thread Starter
notnyt's Avatar
Liked: 1980
Originally Posted by bodhisafa View Post
notnyt,
I think it's just monoprice 10 gauge wire. Might have come from parts express. I don't remember. It's copper 10 gauge wire, as long as its not crap wire, it will do the job just fine. If anyone tells you otherwise, they're being silly.
I used it for the runs from my amps as well, so I'll go take a look when I go into there later.
notnyt is offline
Tc Sounds Lms Ultra 5400
