What's the biggest sound from smallest box? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 03-22-2012, 07:15 AM - Thread Starter
Subjga's Avatar
As I'm wrapping up my fridge-sized 15" sub build, I'm wondering what is the biggest sound from the smallest enclosure that you can buy or build?
For example, I have the Logitech z3 computer speaker. That' the little sub-that-could! I really can't believe how much bass it puts out with corner loading. And it's only a 4" driver with an 8" passive radiator.
Subjga is offline
post #2 of 20 Old 03-22-2012, 07:22 AM
Bill Fitzmaurice's Avatar
Liked: 5623
Don't believe what you think you hear. What your ears are interpreting as bass is actually an octave higher, midbass. The laws of physics, Hoffman's Iron Law for one, are non-negotiable.
Bill Fitzmaurice is online now
post #3 of 20 Old 03-22-2012, 08:46 AM
Bigus's Avatar
Quoted: 397 Post(s)
Liked: 384
Small sealed enclosure with capable high excursion driver(s) and gobs of amp power.
Bigus is offline
post #4 of 20 Old 03-22-2012, 12:12 PM
kgveteran's Avatar
Quoted: 437 Post(s)
Liked: 165
JL 10W7AE-3 in a 12"x12"x18" sealed box powered by a QSC 5050 bridged, EQ'd by a Balanced MiniDSP...Done !
kgveteran is offline
post #5 of 20 Old 03-22-2012, 12:34 PM
JackNC's Avatar
Quoted: 140 Post(s)
Liked: 39
I've got 2 pairs of TC Sounds Epic 10's dual opposed in a 14.5" x 14.5" x 18" enclosures. After Linkwitz Transform via MiniDSP and before room gain and boundary reinforcement, Unibox shows each pair provides 104.5 db SPL at 20 hz when touching xmax at 13 hz w/o an HPF. I'm using themtight against the wall near corners, which should give me at least another 9 db, + 6db for the 2nd pair. Haven't pushed it that high yet; the walls shake satisfyingly at much lower levels!
JackNC is offline
post #6 of 20 Old 03-22-2012, 12:42 PM
dbldare's Avatar
Maybe this???
Tornado Siren
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #7 of 20 Old 03-22-2012, 12:43 PM
dbldare's Avatar
Seriously - If you are trying to conceal the large sub boxes, maybe look into an IB setup.
dbl
dbldare is offline
post #8 of 20 Old 03-22-2012, 01:13 PM - Thread Starter
Subjga's Avatar
Very specific - excellent!
Why is it so hard to find the specs and T/S numbers for this sub?
Subjga is offline
post #9 of 20 Old 03-22-2012, 01:14 PM - Thread Starter
Subjga's Avatar
Can you post pics of these? Sounds very interesting.
Subjga is offline
post #10 of 20 Old 03-22-2012, 01:37 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
RSS390HO-15 work well in a 50l enclosure.
Mrkazador is offline
post #11 of 20 Old 03-22-2012, 02:29 PM
Quoted: 992 Post(s)
Liked: 520
Depends on bandwidth expected, though.
If one is willing to limit low-end bandwidth to, say 15-20Hz, then the answer is a small passive radiator enclosure with capable high excursion driver(s) and gobs of amp power.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #12 of 20 Old 03-22-2012, 02:32 PM
Danislous's Avatar
A box with the tympani LAT driver probably...
Danislous is offline
post #13 of 20 Old 03-22-2012, 02:34 PM
Danislous's Avatar
Tymphany LAT 700 subwoofer driver to be specific
post #14 of 20 Old 03-22-2012, 03:50 PM
JackNC's Avatar
Quoted: 140 Post(s)
Liked: 39
I must have done something wrong. I modelled the LAT 700 in unibox. It need a huge, 276L box for QTC=.7 and then hit xmax at 35 hz, producing only "112"db. That might be a big sound (despite needing an HPF at 35 hz to protect the woofer) but its not a small box!
JackNC is offline
post #15 of 20 Old 03-22-2012, 03:56 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
If you aren't trying to go below 30hz you can do pretty well with a tiny PR box. A Dayton RSS315HO in 1ft3 with a NS390-PR can take full power from an EP4000 with the 30hz HPF engaged, without even breaking a sweat. That actually sounds kind of appealing to have a tiny pair of subs like that wreak somebody's expectations
Jay1 is offline
post #16 of 20 Old 03-22-2012, 04:02 PM
JackNC's Avatar
Quoted: 140 Post(s)
Liked: 39
Thanks for asking I have a few build shots but none showing a finished product because I've yet to veneer it. In the one picture, its sitting on 18" tiles and has a 12" sonotube sitting on top - a quick and dirty enclosure for a used/legacy JBL2214H mid woofer I picked up on Ebay.
In the contest for most punch per cubic foot, the Epic 10 does well because it only needs .42 cu.ft. of Vbox, has huge extension (22mm Xmax, 31 mm Xmech) and can take more than 500W w/o exceeding Xmax.
Jack
JackNC is offline
post #17 of 20 Old 03-22-2012, 08:38 PM
Bigus's Avatar
Quoted: 397 Post(s)
Liked: 384
True enough but for most drivers I think the cutoff would be a bit higher with a "tiny" enclosure.
Then again, you can always just put two drivers in the same enclosure you had the driver and pr in and have the same spl capability above the pr knee and much more below. All you need is even more gobs of amp power. At some point not melting the vc becomes the nagging limit I guess.
Bigus is offline
post #18 of 20 Old 03-23-2012, 06:04 AM
LTD02's Avatar
Quoted: 2461 Post(s)
Liked: 2780
"If one is willing to limit low-end bandwidth to, say 15-20Hz, then the answer is a small passive radiator enclosure with capable high excursion driver(s) and gobs of amp power."
lms-r 12" driver
1.2 cubic foot enclosure
2 x 12" vmp passive radiators with 900 grams added, 1500 grams for the less efficient lower tune (2nd pic)
3500 watts in first, 3000 watts in second gets the driver to xmax in theory
this is similar to the old 'earthquake' sub, but much more capable than that one.
Listen. It's All Good.
LTD02 is online now
post #19 of 20 Old 03-23-2012, 01:53 PM
JackNC's Avatar
Quoted: 140 Post(s)
Liked: 39
Here is a graph comparing the TC Sounds family members on more or less an even footing in the small sealed paradigm. QTCs are all in the .6 to .7 range. Note that the dual Epic10 edges out the LMS-R12 but that 4 Epic 10's fall 2 db short of a single LMSR-Ultra in the same total box volume. Note also that the LMS-R12 costs $369 while I got my Epic10's on sale for $139 each.
JackNC is offline
post #20 of 20 Old 03-23-2012, 02:14 PM
DL86's Avatar
Not really related
http://www.roland.com/products/en/CUBE-80XL/
But damn those things crank out some serious sound for such a small size.
To improve the black level performance of your projector: Shine bright light into your eyes every 5 minutes.
DL86 is offline
