I decided to take some measurements on some of my LMS ultra drivers, as they did not seem to be reaching the advertised excursion levels.
With the driver free air, I was able to see that on the inward stroke, it would easily hit the spider support which is just over 1.5" from the cone. However, on the outward stroke, I was not seeing much more than 1.25" of excursion.
Is the stroke just non linear at this range?
My measurement system was crude, but fairly effective. I set a measuring tape on a fixed surface and aimed it towards the center of the driver. I then took a pencil with a soft eraser and marked it, so that I could see where on the measuring tape the pencil would touch the cone when the sub wasn't moving. I set it up so that it was at 3" on the tape. Next, I played a low frequency test tone so that I could hear the cone was tapping on the spider support. I slowly moved the pencil, eraser side first, towards the moving cone to see where it would impact. From these tests, I was unable to see outward excursion of over 1.25"
xmax on this driver is listed at 38mm with xmech being just slightly beyond that.
That was in an enclosure with a second LMS 5400 ultra, which wasn't being powered at the time. You can hear it hitting the spider support, which is over 1.5" of inward travel, but not moving more than 1.25" outward.
I'm a bit confused... your first post says free air, but the subsequent posts say it is in the enclosure and that you aren't doing free air testing. Also, I see the vid but can't see the links of the two measurements. The vid shows how you get outward excursion, but how are you measuring inward excursion with that method?
I'm wondering if you have changed something to get more free air conditions that I'm missing. If not, since you have two drivers in a shared enclosure, you could either remove the other driver to leave a large open hole, or wire the other driver out of phase. Both conditions would approximate a free air test, the second perhaps a bit more so and easier to do.
Ricci has the geometric xmax at 33mm on Data Bass. That's roughly 1.3 inches. I thought I remember hearing the xmech was eerily close to the xmax on all TC LMS drivers.
When it was open I measured the inward stroke, you can see its hitting the spider support. The video shows measuring while it was in the enclosure with the second driver disconnected. I tested with it connected as well.
All of the ultras I have are the current version. I have not physically measured the clearance like Notnyt did in the pic above since they have all been in enclosures for a long time now. I haven't gotten the sealed test finished. I keep bumping other stuff with less of a track record ahead of it.
Truthfully...you have already established what the physical xmech limit is. The cone can't move any further. We know that the motor will get it there. All there is left is how much noise the motor and suspension make on its way there. As far as your pencil test I have a feeling that the excursion is equal on the inverse and outward strokes. You can't see the back of the woofer so it is difficult to say whether it is contacting the spider spacer for sure. It may just sound like it. Weird things happen sometimes so who knows. When I get a chance I will look at one of mine.
When I talked with Nathan over at Funk Audio a few weeks ago, he mentioned to me that the 5400 with 38mm of linear travel is hamstrung by 32mm mechanical travel, which is somewhat easy to bottom out/damage. He also told me that the LMS has a listed mechanical travel of 47mm but is simply not so. That number is the clearance in the motor, but the suspension limits at 32mm. The cone contacts the spider landing at 32mm. That's one of the reasons they started their own design/building of their TSAD drivers. Just to note, Nathan has quite a bit of experience with LMS subs. He's listened, tested and sold quite a few of them. So it looks like Notnyt tests/results are very close to Nathan's, no?
I actually ran it until it was hitting the spider, at about 42mm. I could tell because I put the little tab of cardboard there and I could feel it. There is just over 1.5" (42mm) between the spider and the cone. Actually the last roll of the spider is all hard from glue, and that is what hits the cone.
It seems like the way they're built that the roll surround limits the outward excursion to about 32mm. The inward stroke is limited to 42mm, which is the published xmax.
If my measurements are correct, it would have at least been nice to have accurate published specs to work off of when designing the enclosures. Granted, I can't really complain, these drivers are rarely pushed that hard, but for the price the specs could at least be accurate
Apparently the newer LMS drivers shrunk the spider support so they have more clearance. I still don't see how that helps outward excursion which I think may be limited by the surround at around 32mm.
After my LMS-R 12" suspension completely detached and I was told to super glue it back to the frame or pay to ship the top assembly back for them to glue, even within the warranty period, I'm out of TC world.
I'll put a Zv3 18" up against an LMS-U any time for half the price.
I'll put a Zv3 18" up against an LMS-R any time for half the price.
Linear x-max by 70% BL is ~25mm one-way, the motor bottom is 47.5mm -- the suspension can handle a bit over 40mm one-way.
The 15 also models badass in quite tiny sealed enclosures. I have a frame for the 15 getting some chrome as we speak
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
