RSS390HO 6.5ft^3 20Hz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-23-2012, 12:09 PM - Thread Starter
lowarkhog's Avatar
How does this look? Do I have the filters set properly in WINISD for the Bash300? Thanks.
Should I be concerned with port noise?
psn: lowark
lowarkhog is offline
post #2 of 5 Old 03-23-2012, 01:40 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
You should change cone excursion to mm and air velocity to m/s.
Looks like you would need 2 4" ports, 23" long to keep port noise low.
Mrkazador is offline
post #3 of 5 Old 03-23-2012, 02:24 PM - Thread Starter
lowarkhog's Avatar
Didn't think to change those. Thanks.
psn: lowark
post #4 of 5 Old 04-15-2012, 09:13 PM
03roadking's Avatar
lowarkany progress on the build?
03roadking is offline
post #5 of 5 Old 04-16-2012, 12:04 AM
Subjga's Avatar
Good question about the filters. I'd like to know the same thing (is it set right?)
Subjga is offline
Dayton Audio Rss390ho 4 15 Reference Ho Subwoofer 4 Ohm
