First subwoofer build - progress thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 03-25-2012, 02:38 PM - Thread Starter
Vaison's Avatar
I came to these forums at the end of 2011 and the DIY section caught my eye. I saw all of the really cool subwoofer box builds and thought it was something that I could do. I was also in the process of building a media room (a first for me also) and figured that I would have gained enough skill to be able to make a simple wood box. Or so I thought...
I chose a project which I thought would be fairly easy, considering I have almost no woodworking skills or any knowledge of speaker building other than what I have read here. Like many others, I posted threads asking lots of beginner questions and I was fortunate enough to have gotten a lot of great responses. I started ordering materials and as I went along, I realized that I didn't have a lot of the tools necessary to complete such a project. So, I had to buy them, borrow them, and even paid someone to make the circle cutouts for my driver and port tubes. Now that I have almost everything and wouldn't have to incur many of the the nickle and dime costs of building.
Then, LTD02 came along and has been there for every question that I've had. Without his numerous responses to PM's and earlier threads of mine, I would have never been able to get as far as I have. I can't thank him enough for his guidance and if I screw up this project, it is no fault of his as he has been great.
Anyway, my media room has been completed and my focus is to building the subwoofer box. I took very few photos at this point, but I will post what I have so far. I will continue to post as I complete the project. Like I have said to LTD02 - I welcome and suggestions and criticisms. Don't be afraid to hurt my feelings if you see something that I did wrong.
Vaison is offline
post #2 of 21 Old 03-25-2012, 02:51 PM - Thread Starter
Vaison's Avatar
After numerous threads and advice from others, I decided on a BASH 500 amp and a TC Sounds 12" Epic that I got from PE. I am using 3/4 MDF. The interior box dimension are 22.25H x 27.25L x 18.25W, with the bracing accounted for, the box volume is roughly 6.3 F3.
Here are a few photos so far.
Very first steps, cutting the MDF. As you can see I did this while I was still constructing my room.
The TC Sounds 12" Epic driver
The front baffle cutouts that I had to pay someone to do for me since I couldn't find anyone who had a plunge router and a jig.
Checking to see if the driver fit well into the cutouts. Seems okay so far.
Current progress. Box nearly assembled.
I intend to use wood filler for all of my gaps and then a 1/4 router to trim all of the edges. Then I will probably just do a brushed on sealer, sanding, and a few brushed on coats of black paint. I haven't really researched what I should be looking for when I buy these materials. But I intend to search trough the posts to see what others have done. It also looks like I am going to use some sort of polyfill for the interior of the box. I need to get some of that too.
Okay, more to come as I complete each step. Thanks for looking.
Vaison is offline
post #3 of 21 Old 03-25-2012, 02:57 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Looking good! For ported enclosures lining the walls with open cell foam is easier to deal with then polyfill. You dont want to block airflow from the driver to the ports. A cheap foam mattress topper will work.
Jay1 is offline
post #4 of 21 Old 03-25-2012, 05:13 PM
maxcooper's Avatar
Quoted: 13 Post(s)
Looks great! Thanks for sharing your story and pics. I love to read threads like this and see what people are building, and how they are building it.
-Max
maxcooper is offline
post #5 of 21 Old 03-26-2012, 08:24 PM - Thread Starter
Vaison's Avatar
A little help here, if anyone doesn't mind...
I bought 3 pillowcases full of polyfill at Walmart tonight. $2.50 a piece. I've been reading through posts on the polyfill and I now wonder if I would remove the fill from the pillows or just put the pillows in the box. I see that many use loose fill. But I also see some that complain that the polyfill gets caught in their ports.
Additionally, I have quite a bit of fiberglass insulation leftover from my room build. I saw that some people use insulation instead of the polyfill. If the insulation is fine, I would return the pillows and save a few bucks. Those walmart pillows are really cheap, so I would never use them for anything else than stuffing a sub box.
Vaison is offline
post #6 of 21 Old 03-27-2012, 02:56 AM
maxcooper's Avatar
Quoted: 13 Post(s)
Using fiberglass in a ported sub seems like it would lead to itching. I would not do that.
-Max
post #7 of 21 Old 03-27-2012, 06:41 AM
mi bill's Avatar
fiber fill, walmart pillows are good for sealed subs, not for ported subs
open cell lining like mattress pad is good for ported subs.
mi bill is offline
post #8 of 21 Old 03-27-2012, 07:10 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
"...now wonder if I would remove the fill from the pillows or just put the pillows in the box."
for a ported sub, remove the fill from the pillows. fiberglass is tricky with a ported sub as the fiber can sometimes blow out of the port, so to be safe, use the polyfill.
Listen. It's All Good.
LTD02 is offline
post #9 of 21 Old 03-27-2012, 01:19 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
Nice box so far.
Use the polyfill and cover it with some highly breathable fabric to secure it way from the port and driver. I used lace for mine.
http://www.avsforum.com/avs-vb/showt...7#post21741097
duc135 is online now
post #10 of 21 Old 03-29-2012, 10:48 AM - Thread Starter
Vaison's Avatar
I have a flared port question. I bought a flared port kit and extension tubes. Even though all parts are designed for a 4" system, they are not exactly compatible. The coupler rings will fit the extension tubes, but not the tubes from the kit. Right now I have the front of the tube flared, but the back is just flat. Is it okay to leave the back without the flare or should I figure out a way to flare the back? Thanks.
Vaison is offline
post #11 of 21 Old 03-29-2012, 01:45 PM
Jstslamd's Avatar
You might be able to flare the back end with a heat gun and a large wine bottle. I know it works with PVC I don't know what kind of plastic the port tube that you have is. It wouldn't Hirt having the rear section flared as long as the length stays the same.
Jstslamd is offline
post #12 of 21 Old 03-29-2012, 05:08 PM - Thread Starter
Vaison's Avatar
Jstslamd - I have the flared parts, I just need to find a coupler ring of some sort that will fit around both tubes. I'm going to try to hit Lowes this weekend to see if I can rig something up.
In the meantime, I finally hooked up the amp and driver to give it a test run. It sounds pretty weak without a box. Its the first time I've ever had a driver out like this. I hope I got my wiring correct.
Vaison is offline
post #13 of 21 Old 04-04-2012, 07:32 PM
Jstslamd's Avatar
Any updates ?
Jstslamd is offline
post #14 of 21 Old 04-05-2012, 12:33 PM - Thread Starter
Vaison's Avatar
Originally Posted by Jstslamd View Post
Any updates ?
Well, I knew I wouldn't be able to get much done this week due to some of the charity work I do around the holidays. So to appease myself, I put the driver, port tubes and amp in the unfinished box just to give it a trial run. I watched tv and listened to music on it for about 3 days. I didn't stuff it with the polyfill or anything like that. I didn't do much adjusting with the amp (simply because I don't really know how to yet). But, the movies sounded really great. I was shaking the walls, air returns, and floor above my room. At times, it was too much because the sound of the wall vibrating wasn't appealing. The music, well, it sounds pretty muddy to me with the way I had it set up for those days. Hopefully I will get that sorted out. Anyway, I had a little time today and put wood filler in all the seams. Sanded it down and used a router for the edges of the box. I hope to get the sealer, painting and full assembly completed in about a week or so. (My wife is a teacher and on spring break all next week so my free time is probably gone, so I'm not optimistic about getting done)
Vaison is offline
post #15 of 21 Old 04-07-2012, 02:57 PM
poormanq45's Avatar
The brace should not be directly in the middle as it may cause standing waves.
poormanq45 is offline
post #16 of 21 Old 04-07-2012, 03:03 PM
tundrSQ's Avatar
Huh"
Tim
tundrSQ is offline
post #17 of 21 Old 04-07-2012, 03:36 PM
poormanq45's Avatar
Originally Posted by tundrSQ View Post
Huh"
The brace being equal distance from the front and back can cause a resonance. IIRC, the frequency will be the quarter wave length equal to the distance between the brace and the two sides that it separates.
post #18 of 21 Old 04-07-2012, 05:34 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
I could be wrong, but I don't think that would apply with subs. I think low frequency wave lengths are far longer than the typical sub enclosure for that problem to make a difference. Again, i could be wrong as usual.
post #19 of 21 Old 04-07-2012, 06:45 PM - Thread Starter
Vaison's Avatar
Well, it is a little late now to change that. But, it isn't exactly in the middle if that helps some. It's more toward the rear.
Vaison is offline
post #20 of 21 Old 04-07-2012, 07:34 PM
LTD02's Avatar
Liked: 2576
the brace isn't going to create standing waves.
LTD02 is offline
post #21 of 21 Old 08-31-2012, 07:50 AM
saabracer23's Avatar
Liked: 29
Any updates on the build?
Dan
saabracer23 is offline
