Passive radiators ???? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-27-2012, 08:38 PM - Thread Starter
jmit115's Avatar
I going to build a sub box 17x17x17 sealed 10in front firring driver and thinking of using a down fire 12in passive radiator. good/bad?
Also: was thinking of using auto paint w/ clear coat. will it look the same as lacquer?
jmit115 is offline
post #2 of 5 Old 03-28-2012, 01:43 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5285 Post(s)
Liked: 4173
Don't do it that way with the PR firing up and down. That's bad. Have the active driver bottom firing with the PR facing out.
Scott Simonian is online now
post #3 of 5 Old 03-28-2012, 06:43 AM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
"Don't do it that way with the PR firing up and down. That's bad. Have the active driver bottom firing with the PR facing out [one of the sides, the front, or the back]."
+1
"Also: was thinking of using auto paint w/ clear coat. will it look the same as lacquer?"
if you really know what you are doing. however, since you are asking...
Listen. It's All Good.
LTD02 is offline
post #4 of 5 Old 03-28-2012, 09:36 AM - Thread Starter
jmit115's Avatar
I was going to build with the pr down, I have a REL R328 w/10in active front and a 12in pr down.
.... so what is the reasoning for it being "bad". IDK
... "since I was asking" about the paint was, The look, depth and gloss.
I work at a Ford dealer, so I have friends the shoot cars every day.
jmit115 is offline
post #5 of 5 Old 03-28-2012, 09:56 AM
John_E_Janowitz's Avatar
Quoted: 26 Post(s)
Liked: 81
I always link people to the PR FAQ. This will give you a basic understanding of what you need from a PR system.
http://www.aespeakers.com/PRFAQ.php
John
John E. Janowitz
Acoustic Elegance, LLC
"Learn from the mistakes of others... you can't possibly live long enough to make them all yourself"
John_E_Janowitz is offline
